| Explorer4x4 | Sportrucks | EF Arcade | Forums | Elite Membership | Product Reviews | Explorer Photo Gallery |
| Notices |
| Modified 1995-2001 Explorers Questions related to modified 1995-2001 Explorer, Mountaineer, Ranger and 2002+ Sports (2dr). |
Thread Tools |
#1 |
Wannabe Elite Explorer
long island ny
351 swap 4wd to 2wd?
Is it hard to convert a 2000 mounty to 2wd from 4wd. Also I was wondering is it hard to fit a 351w it the engine bay. Cause I'm watching a 408 with 950 holley and pro fogger setup
| Sponsored Links (Less Ads) |
#2 |
Jerz
97 Sport
Yes to the first question. a 351W will fit, but you will need to modify the oil pan to fit into the frame and everything. It's possible, but will be hard.
Justin |
#3 |
Elite Canuck
selkirk, manitoba
98 sport
there is another thread about putting a 351w into a second gen. the time and money that would be spent trying to make it work, you would be better off putting a 347 stroker in.
__________________
If It Has Tits Or Tires, It's Gonna Give You Problems evils elite registry roll pan build for 1st and 2nd gen explorers door switch LED convention |
#4 |
Houston, TX
soon: '98 EB
Oil pan and the motor's width are going to be your biggest issues. 347 is definetly the way to go. Also, the 2wd to 4wd conversion isn't hard. No cutting and welding, but you do need a LOT of parts.
#5 |
Pole Dancer
Humboldt, KS
1998 Mountaineer MX4 O/R
351 swap sounds good--
Here is something to prepare for it http://www.explorerforum.com/forums/...d.php?t=150095 http://www.explorerforum.com/forums/...d.php?t=160704 http://www.explorerforum.com/forums/...d.php?t=158144 I believe after all this work he "threw in the towel"
__________________
"I set my standards low, that way I am not easily disappointed" 98 MX4 OFF ROAD 93 with sky light Explorerforum license frames here |
| Bookmarks |
| Thread Tools | |
