| Explorer4x4 | Sportrucks | EF Arcade | Forums | Elite Membership | Product Reviews | Explorer Photo Gallery |
| Notices |
| Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Sport Trac and Sport use the 1995-2001 forum. |
Thread Tools |
#1 |
Wannabe Elite Explorer
Bluegrass St.
2003 XLT Sport Trim
This has been happening for a year. It doesn't always do it but occasionally will on the initial start up and drive of the day and be fine the rest of the day.
I will be driving it down the road then have to come to a stop. Then when it's stopped it will die. Sometimes it surge before it dies and I have to hold the brake so it won't hit a car in front of me or put me in traffic. Anyone had this issue? Could it have something to do with the IAC? |
| Sponsored Links (Less Ads) |
#2 |
Bay Point, CA
2003 XLT 4.6 4X4
Does it happen when you're going straight or when slight turn ( curve)? Had similar problem and had PCM flashed and no more problem. Idle speed was too low. Mines stalled out on slight right curve and usually when vehicle was not fully warmed and happens only once.
#3 |
Louisville, KY
2003 Mountaineer Premier
Had the same problem recently ended up being a whole in the 90 degree vacuuming hose elbow on the top part of the engine. Ran fine when i slowed down it would hesitate and then stall.
__________________
03 Premier 4.6 V8, CAI, 6K Hids, Tinted Tails |
#4 |
Gardner Kansas
02 XLS 4.0
But does the v6 have this same 90 degree hose I've looked for it but have came up with no luck as mine is doing the same thing as described above.
__________________
2002 Explorer brown wire mod sold |
#5 |
Bluegrass St.
2003 XLT Sport Trim
No this will be on a straight shot.
I have the 4.6L V8 btw. |
#6 |
Bluegrass St.
2003 XLT Sport Trim
Bump..........
#7 |
Bluegrass St.
2003 XLT Sport Trim
Anyone?
#8 |
Ashburn, Virginia
2002 Explorer Limited
Mine occasionally stumbles when at a stop. Or when i go from reverse to drive. I am figuring its the IAC or maybe a clogged fuel filter. I plan on cleaning the IAC sometime soon and see if it helps, you may want to try that also.
#9 |
Louisville, KY
I can have a pic of it for you (the elbow) also check your intake make sure nothing is lose. Mine was lose when i installed my k&n and it would stumble at stop lights the pcm was reading to much air and was trying to control it.
Will
__________________
#10 |
Louisville, KY
__________________
| Bookmarks |
| Thread Tools | |
