| Explorer4x4 | Sportrucks | EF Arcade | Forums | Elite Membership | Product Reviews | Explorer Photo Gallery |
| Notices |
| Explorer, Ranger, A/C & Heater systems HVAC Ford Explorer, Ranger, Mountaineer, Bronco II, Air Conditioning and Heating Systems. |
Thread Tools |
#1 |
Wannabe Elite Explorer
Honolulu HI
97 Eddie Bauer
A/C problems
I noticed several people having prolems with their A/C. My A/C is one of the ones that blows only on high and 60 degrees. I also noticed a ticking sound near the floorboard when I first start my car. Also does anyone's A/C turn off when the wipers are on intermittent? Any suggestions? Thanks.
| Sponsored Links (Less Ads) |
#2 |
Nashville, TN
'97 Eddie Bauer 4.0 SOHC
same problem with 97 eddie bauer explorer
My a/c only works on 60 degrees + MAX A/C has to be pushed in also
#3 |
Honolulu HI
97 Eddie Bauer
Did you find any ideas on the problem? I heard that it could be some realy or resitor in the engine compartment. I jsut have no idea which one. Let me know if you find anything. Thanks
#4 |
Florida Gulf Coast University, Fort Myers, Florida
'95 Sport
The resistor is bad. Most of the info on the boards points to the resistor being where the relay is, but that is not the case. The resistor is near the back of the engine bay on the passenger side under th blower motor. They get all corroded and die, replaced mine and my AC blows nice now.
#5 |
Brewster, NY
1999 XLS
Fan only blows on Hi = Blown Resistor
A/C only works on MAX = Broken Blend Door
__________________
Tom Lynch '99 XLS 4 wonderful very used (80K miles) but still like new Michelin XC LT4 tires "Forget world peace. Visualize using your turn signal." |
#6 |
Village Idiot
Trenton, MI
98 ExSport, '00 F-150
Indeed, here's what happens to the resistors and the connector:
![]() ![]() ![]() ![]() ![]() ![]() I thought I had pics of the repair, but I guess not. They're on the computer at home. The repair costs $30 in parts. $15 for the resistor, $15 for the pig-tail. I soldered and shrink-tubed the connectors, then wrapped it with eiectrical tape. I injected some polyeurethane sealant into the outside of the connector where the wires go in to keep the elements out, and injected the connector side with dielectric grease to do the same. It's working great now! -Joe
__________________
-98 Explorer Sport, 4.0 SOHC, K&N drop-in, LEMON in progress! -'00 F-150, mucho mods, Photo gallery Here "We need to allow Darwinism take it's course and let the idiots weed themselves out of existance." ~ Rick Horwitz We must believe in free will — we have no choice. ~ Isaac Bashevis Singer I'm not smart, just a resourceful idiot. ~ Me |
#7 |
Honolulu HI
97 Eddie Bauer
Wow that is messed up!!! The good thing is that it did not cost you too much. Did the Ford dealer had it in stock or did you have to wait? I would hate to tear my A/C apart then wait for the resistor. I guess I'm calling my dealer tomorrow to see what they got. Thanks for the pictures...good shot of the part numbers. I'll let you know what I find.
#8 |
Village Idiot
Trenton, MI
Most stealerships should have them in stock. They're a common failure item for fleets, so they're one of the few pig-tails Ford made available separately. Poor design if you ask me... they left all the connections completely exposed to the elements. That's just askin for trouble unless you live in the desert.
-Joe
__________________
#9 |
youngstown ohio
2002 xls
my ac kicks on and off every few seconds. Do you think this might be my problem?
#10 |
Village Idiot
Trenton, MI
Doubt it. Short-cycling of the compressor is usually indicative of a low freon charge. You'll need to have the system leak-tested and re-charged to fix it.
-Joe
__________________
#11 |
youngstown ohio
2002 xls
what part of the AC would be leaking?
#12 |
Village Idiot
Trenton, MI
Any part.
__________________
#13 |
youngstown ohio
2002 xls
how can i find out what is leaking? im sorry i don't know much about trucks.
#14 |
EF Tranny Guru
Sacramento, CA 95827
1992 XLT
Check out the useful threads on AC. In order, leak points are usually... valves for recharging HI or LOW... Accumulator, garter joints with O rings and compressor seal. DIY dye checking is about your own option... shops have "sniffers.
Great pic posts Gi ! |
#15 |
Honolulu HI
97 Eddie Bauer
Okay I don't have the resistor in my truck...not at least I can see. I did find that I have one of those A/C controllers (same loacation as the resistor in other posts)...costs about 150 bucks from the Ford stealership. One of the good things is that I found an easier way to get to the controller. I went from underneath through the right wheel well. Removed 4 bolts and 4 screws...took about 5 minutes with an air ratchet and phillips screwdriver. A lot easier than removing the windshield washer and radiator resevoir. Just something I wanted to add in case anyone else was going to replace this part...and from what I can see, there will be others.
Ish |
#16 |
winter park, FL
1996 Limited 4x4
so is it true that if you have the eddie bauer or limited model explorer, then you do not have the resistors? and instead have the A/C controller? My blower does not work at all, at any setting. I took it to aamco today and they told me it was the resistor. however, i drive a "limited" and everything i'm reading says that the limiteds have the controller. and if i had resistors, and they went bad, shouldn't it still work on high? because mine does not work at all.
please help, because i'm supposed to take it back to aamco in the morning to have a new resistor put in, and don't wanna waste money. thanks, todd.
__________________
1996 Explorer Limited(4x4): SCT Xcalibrator, Milemarker E9000 3" PA Body Lift/2" TT and Custom Leaf Pack 33x12.50 Pro-Comp MT's on 15x10 rockcrawlers. a whole bunch of metal... http://www.cardomain.com/id/toddious |
#17 |
Westminster, MD
06 xlt, 97 ranger 4.0
Yes, the blower should still work on high if the resistor is bad. If you have no speeds, I would suspect a bad motor, switch, or fuse.
#18 |
Village Idiot
Trenton, MI
On a 96, If you have the manual temperature controls, you'll have the resistors. If the blower does not work at all on any settings, you'll want to start with the basics:
Interior fuse panel #6 (7.5A) Power Distribution Block #6 (50A) Aux. relay block #2, blower motor high speed relay Aux. relay block #2, blower motor relay It's possible that it's the resistor pack too.... that'a VERY common problem. The connector under the hood is exposed to the elements, and the terminals corrode away. (I have pictures of that in the gallery linked in my signature) Now, if you have the electronic automatic temperature controls (which I suspect was standard on a Limited) it's a whole different ball of wax. Power Distribution Box, Fuse #6 (50A) Interior fuse panel: #6 (7.5A), #18 (15A), and #9 (10A) (all feed the EATC module) Check the blower motor relay in aux relay box #2. The EATC uses a blower motor speed controller instead of a resistor pack. I'm not sure if it's located in the same position as the resistor pack would be or not. At any rate, if you have the EATC, Aamco will NOT be replacing the resistor pack, regardless of what they said. Also, if you have the manual controls, and the resistors are bad, the motor will work if and only if the high speed relay is good and the motor itself is still good. -Joe
__________________
#19 | |
winter park, FL
1996 Limited 4x4
Quote:
__________________
#20 |
Ottawa, Ont
96 XL
The blower motor can readily be "started" and run in one speed by grounding one of the leads coming from it to the "AC speed controller".... in essence, that's all that the controller does plus "adding a thing or two" for speed control / adjustment... which may or may not be solid state (I doubt it). Anyways, that's probably how they tested to see if the motor works. It is likely that your "speed control" is done and needs replacement... I don't know if it can be "bench fixed".
| Bookmarks |
| Thread Tools | |
