| Explorer4x4 | Sportrucks | EF Arcade | Forums | Elite Membership | Product Reviews | Explorer Photo Gallery |
| Notices |
| Explorer, Ranger, A/C & Heater systems HVAC Ford Explorer, Ranger, Mountaineer, Bronco II, Air Conditioning and Heating Systems. |
Thread Tools |
#1 |
Wannabe Elite Explorer
Houston, TX
'94 Sport
94 explorer ... evaporator core
hi all,
sometime last year i had to replace my compressor (the pulley froze) and i went ahead and replaced the dryer as well and it worked great for months. now i have a leak in my evaporator core and am wondering how hard it is to replace. how do i get to it? and what all is involved? do i have to pull the dash? any help would be greatly appreciated as i live in houston and it's starting to warm up down here haha.. casey |
| Sponsored Links (Less Ads) |
#2 | |
Houston, Tx
94 XLT
Quote:
Besides being cramped for space, is there any tricks or problems to look out for? |
#3 |
Moderator-Stock 91-94
Vail, Arizona
1992 XLT 4x4
I haven't pulled mine, but I did look at the instructions to do it when I re-did our A/C(I skipped changing it, I just blew it out with flush)..
If I remember correctly, you have to remove the cover which is under the hood and it comes out from the engine bay, not from within the vehicle. I got the info from a combo of haynes and chiltons books (I no longer trust either, so both have to have the same info before I believe it). ~Mark
__________________
Click HERE to see our Explorer Specs Get your Serious Explorations Explorer4x4, Explorerforum and ExplorerSportruck T-shirt |
#4 |
Houston, Tx
94 XLT
I just don't want to have to take part of the dash out to find a couple of hidden screws. I changed one of these on an old 74 Ford wagon years ago and it all came out under the hood. It was a real pain, but it was eventually doable. This one looks very similar - cramped and hard to get to, but it has to come out under the hood. Just getting over some health issues (herniated disc) I am being careful what kind of jobs i tackle.
Charles |
#5 | |
Huffman, Texas
'92 Explorer XLT 4X4
Quote:
Not really that hard to change a on 1st. gen. Explorer. While you have the system open consider replacing all the o-rings with new ones - not that expensive. If you do change the evaporater core it would be a good time to convert to r134a if you have not already done so. If you do the 134a conversion be sure to change the complete system to a compatable oil. Before you charge the system pull a good vaccuum on the system for a few minutes and check for leaks (system will not pull a vaccuum and maintain said vaccuum if it is leaking). Also be wise of federal regulations regarding the discharge of freon into the atmosphere. Charles |
#6 | |
Houston, Tx
94 XLT
Quote:
Charles P, Houston |
#7 | |
Huffman, Texas
Quote:
At todays prices $25 was not a bad price. Just to change the parts above, I would guess about 2 hrs. at most, but that depends on a persons mechanical abilities & tools & interruptions. If you do your own evacuation and charging you are looking at more time. Obviously, the more you do the more time involved. If you have never done A/C repairs consider buying a book on AUTOMOTIVE A/C from the parts house - they are about $15-$20 and can answer alot of questions you might have as to what and why. Does your system have r12 or r134a freon? I'm not sure when Ford made the change - the '96 ranger I once owned had r134a. My '92 Explorer has been converted to 134a but my wifes '91 Explorer still has r12. Good luck with your repairs. Charles A, (east side Lake Houston) |
#8 | |
Vancouver, WA
'94 XLT, 4dr
Quote:
PS...don't forget to add PAG oil. |
| Bookmarks |
| Thread Tools | |
