| Explorer4x4 | Sportrucks | EF Arcade | Forums | Elite Membership | Product Reviews | Explorer Photo Gallery |
| Notices |
| Ford Explorer - Ranger Tires & Wheels Want to know what size tire or wheel combo will work with your Ford Explorer or Ranger based vehicle? Interested in Beadlocks or Dubs? Learn all about them here. |
Thread Tools |
#1 |
Unregistered
If I was to get a set of 32/9.50 or 33/9.50 would they fit under a 95 explorer sport. Fully stock. I am scared to go with the 10.50. My dad won;t let me do anything to it. No body lift. No window tint. No deep dish rim so that I can fit 11.50 under it. nothing. He is afraid that it will ruin the warranty. If it was mine I would give it a 5.5 inch body lift. 33.12./50 tires a supercharger and new exhaust and other things.
| Sponsored Links (Less Ads) |
#2 |
Unregistered
James -
Wow, a '95 and still under warranty? Don't do any mods unless you're ready to spend a lot of money upgrading the vehicle. From the look of things, it doesn't look like your dad is going to open up his check book for any improvements to the vehicle. The one improvement you can make to your Explorer without any cost is the airbox modification. Check it out. Even replacing the tires with larger ones could end up costing you/your dad a lot of money because a) new lower gears may be needed to retain the performance of the vehicle or it may drive like a snail, b) the possibility of breaking your rings and pinions increases because of the additional stress, c) increase wear and tear (hence, replacement costs) on your bearings, etc. By the way, there is no 5.5" body lift, only 2" or 3" body lift kits. Suspension lift kits are available in 2.5", 3", 4", 5.5", and custom. They run from the hundreds to the thousands, depending on options. Installation cost is extra of course, add another $1,000 for suspension kit or so for professional installation. You could easily spend $2,000 - $20,000+ just in the mods. It's a lot of money once you start with the modifications. Don't take this the wrong way, I'm not trying to slight you by any means, but hold off on making modifications to the vehicle unless and until YOU (not dad or anyone else) can afford to pay for all the mods, maintenance, and repairs yourself. Of course, this is only after any and all other financial responsibilities you may have. Meanwhile, enjoy the vehicle as is, read-on in this web page for tips on maintaining the vehicle and learn to do them yourself. If this sounds like it's coming from an old fart, it is!!! [This message has been edited by kvo (edited 05-10-99).] |
#3 |
Unregistered
The original question was will 32/9.50 or possibly 3/9.50 fit under a stock 95 explorer sport. or even 32/10.50 or 33/10.50. I have a 3.08 rear end, which pulls my 30/9.50's good. will they fit? what about the gears. will they pull it. I drive 122 miles every weekday. will this effect my gas mileage.
#4 |
Unregistered
Big tires will definitely affect gas mileage. I seriously doubt 32's of any kind will fit under a stock setup. I imagine they would rub under compression. Go will 31's, save some money. 31's still look good.
ps. 3.08 gears will be sorely inadequate with 32's or bigger. Cheers Dale |
#5 |
Unregistered
ps. 3.08 gears will be soring inadequate with 32's or bigger. Cheers Dale |
#6 |
Unregistered
You could put 33s on but you would always have to go straight and very slow.
![]() ------------------ Paul Gagnon www.geocities.com/baja/canyon/8253 |
| Bookmarks |
| Thread Tools | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Do I need a lift or can I sqeeze on bigger tires? | Codeno1 | Explorer - Ranger Shocks, Suspensions, Lift Kits | 4 | 07-07-2003 10:17 PM |
| URGENT! Those who replaced Wilderness AT with tires not on the ford tire list | 97 Eddie Bauer v8 | Ford Explorer - Ranger Tires & Wheels | 21 | 10-04-2001 10:49 PM |
| Faulty Firestone Tires kills over 21 people? | Cameron | Ford Industry News | 58 | 08-20-2000 09:15 PM |
| bigger tires | rocky | Offroad 4x4 Runs Planning and Discussion | 5 | 03-26-1999 01:15 AM |
