Ford Explorer Sport Trac Ford Ranger Mazda Navajo Mercury Mountaineer, Ford Aerostar Message Board®
Ford Explorer, Sport Trac, Mercury Mountaineer, Mazda Navajo, Ford Ranger, Ford Aerostar SUV Enthusiast Forums
Join the "Elite Explorers Today!"
Explorer4x4 Sportrucks EF Arcade Forums Elite Membership Product Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Repair - Tech - Modifications & Detailing Forums > Ford Explorer - Ranger Tires & Wheels
Notices
Ford Explorer - Ranger Tires & Wheels Want to know what size tire or wheel combo will work with your Ford Explorer or Ranger based vehicle? Interested in Beadlocks or Dubs? Learn all about them here.
Reply
Thread Tools
Old 06-21-1999, 01:04 AM   #1
FordManiac
Unregistered
Posts: n/a
Vehicle Specs
I have a 91 sport, and I've read lots of different things on this site about the biggest tires you can fit on that particular truck with no lift or fender trimming. My question is, is the clearance problem with the width of the tire or the heigth? In other words, will I run into trouble with an increased diamter of increased tire width? The reason why I ask if this; I'm going for a wider, more aggressive stance for my Explorer, and I've been salivating over some deep dish rims and 30x15.5(!!!) M/Ts. Please tell me that these will fit, or if the rubbing problem is a result of tire width, how can that be easily overcome? Thanx.
Sponsored Links (Less Ads)
Old 06-25-1999, 09:36 AM   #2
AARON FINE
Unregistered
Posts: n/a
Vehicle Specs
I am not sure if I can help much but let me just tell you what I have and my problem. I have a 91 EB and Ford tucked those two stock tires under there with no room to spare at stock hight. I got a 4-inch supension, and a 3-inch body with 33-12.50s sitting on 15x10s and my front tires rub pretty bad. It rubs at the rear of the wheel well where the well stops and angles out and the rocker panel panel starts. I also get a little on my sway bar up front. It is possible it's the tires that are the problem (Super Swamper Thornbirds) and a fender trim that looks decent is $400 a side. I think its mostly trial and error. Next time I will go with BFG M/Ts because I see them on lots of explorers on this site with no hang-ups. Good luck.
I buried my 88 Toyota, RIP
[This message has been edited by AARON FINE (edited 06-25-1999).]
Old 06-25-1999, 02:56 PM   #3
tiessen
Unregistered
Posts: n/a
Vehicle Specs
Width is usually the killing. I have a stock ht. Exploder with 31x10.5's and no maybe rubbing. Maybe a bit on the sway bar. 11.5's however, I think, would cause a problem. I would recommend against 15.5's!! but if you really want to know get a reputable tire shop to try them out on a front corner to test things.
Good Luck.
Reply
Top of Page
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Help with computer code 14 d_bigdog Under the Hood 13 05-15-2003 12:49 PM
TRANSMISSION PROBLEM (again) Stompah Under the Hood 6 01-09-2002 10:56 PM
Tire clearance problem PhxExplorer Explorer - Ranger Shocks, Suspensions, Lift Kits 2 08-08-2000 04:41 PM
Search ExplorerForum
US Flag
We Support Our Troops!
Explore the site!
Contact Us
This web site is not affiliated with or endorsed by the Ford Motor Company.
Ford Explorer is a registered Trade Mark of the Ford Motor Company
The names of actual companies and products mentioned herein may be the trademarks of their respective owners.
All tips and information provided on this site by either "Serious Explorations®" or it's contributors are for use at your own risk and discretion.
Modifying the suspension on any vehicle will cause changes to it's handling characteristics.
Some modifications described within this website may void your factory warranty.
Copyright 2009 - 1996 Rick Horwitz Photography
