| Explorer4x4 | Sportrucks | EF Arcade | Forums | Elite Membership | Product Reviews | Explorer Photo Gallery |
| Notices |
| Ford Explorer - Ranger Tires & Wheels Want to know what size tire or wheel combo will work with your Ford Explorer or Ranger based vehicle? Interested in Beadlocks or Dubs? Learn all about them here. |
Thread Tools |
#1 |
Unregistered
Can anyone, in english, explain what this is and how it can be avoided and what can be done to help it?
thanks *lovin' my explorer and new tires* skittles ------------------ I'm just a girlie girl who *smiles* and *giggles* alot... *smiles* |
| Sponsored Links (Less Ads) |
#2 |
Unregistered
It is when the drive shaft is out of balance (caked up with dirt or if it is bent). It is the same concept as an out of balanced tire. Simple check, look under the vehicle, check the drive shaft to see if it is clean, if not, wipe clean or spray with water. To check to see if the drive shaft is straight, use a straight edge or a level, place it along the drive shaft, there should not be any gap between the level and the driveshaft, check all around.
You really can't avoid it and about the only thing you can do to protect it is be careful where you go and know where it is so you don't hit any obstacles with it. My $0.02. |
#3 |
Unregistered
I had a similar problem on my '92. Turns out, it was just bad U-joints. The front was a rusted and not pivoting (hence, the vibration). Try that first.
Cheers! |
#4 |
Wannabe Elite Explorer
I was getting the 'vibes' too. Just changed out the rear driveshaft u-joints with greaseable one's (like Ford SHOULD have put in), and will be doing the 3 on the front shaft next week. Hopefully this will eliminate the vibes I get between 60-70 mph.
I'll also be looking at new shocks since I'm close to 50K miles, and will keep reading the posts on those. ------------------ Don't Worry about things you can control... Don't Worry about things you cannot control. 96 Eddie Bauer AWD V8 |
| Bookmarks |
| Thread Tools | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Boot drive change??? Help | bonnich | Exploring Computers!! | 13 | 01-16-2003 01:55 PM |
| AWD Noise in front drive train | garyt | Under the Hood | 6 | 12-09-2002 04:17 PM |
| Drive shaft damage and more. | zensius | Under the Hood | 4 | 10-20-2001 11:29 PM |
| Drive line vibration after rear lift | Paul Gagnon | Explorer - Ranger Shocks, Suspensions, Lift Kits | 2 | 06-06-1999 01:42 AM |
