| Explorer4x4 | Sportrucks | EF Arcade | Forums | Elite Membership | Product Reviews | Explorer Photo Gallery |
| Notices |
| Ford Explorer - Ranger Tires & Wheels Want to know what size tire or wheel combo will work with your Ford Explorer or Ranger based vehicle? Interested in Beadlocks or Dubs? Learn all about them here. |
Thread Tools |
#2 |
Wannabe Elite Explorer
Lay the wheel face down on the ground, take a straight edge that will go across the wheel (edge to edge), measure down to the face at the center where the lug holes are and get your measurement in inches... That's your back spacing...
Ivan |
#3 |
Northport, NY
2003 VW Jetta
OK I measured the backspacing and got 4.5". The wheels that i was thinking about getting are 3.632". Now I have 15X7's and the ones I want are 15X8's. So would the 15X8's with a backspacing of 3.632" fit close to the 15X7's with a backspacing of 4.5".
Thanx Keith |
#4 |
I'd say stay with a 7 inch wheel for several reasons with stock back spacing. First off, if you go with a 30x9.50 or a 31x10.50 tire you'll get better protection for your wheels as the tire will extend beyond the wheel on a 7" wheel. Also, with 7" wheel you'll get a slightly "high profile" height wise from your tire because it will not spread out as much as on an 8" wheel. Now let's build upon those theories above with your wheel spacing for 8" wheels at 3.6 inches. At 3.6" of backspacing, what that means is that your wheels will stick out further and you could wind up rubbing the fender flair or inside the wheel well. Picture if you will those dorky looking Honda Civics with almost no backspacing.. ok you get my point. With less backspacing, this also means you won't be able to stuff the tire up into wheel well while off roading, hence the rubbing I mentioned. Also, by going with a lessor backspacing of 3.6 inches, you could reduce the life of your wheel bearings because the loads are extended out beyond stock and for what they were designed for. Now, if you go beyond a 31" tire, you will more than likely need to get a suspension lift or a body lift to get desired clearances, so something more to condsider there, but it all depends what you are after. Bottom line... get the wheels style you want, but with as stock as possible backspacing... Hope this helps... good luck on your wheel hunt...
Ivan |
| Bookmarks |
| Thread Tools | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| jigga backspacing and bolt patter question | eXploderXLT93 | Ford Explorer - Ranger Tires & Wheels | 7 | 12-15-2003 10:39 PM |
| question on wheel specs | sean4385 | Ford Explorer - Ranger Tires & Wheels | 3 | 10-16-2003 07:31 PM |
| backspacing question?? | agoric875 | Ford Explorer - Ranger Tires & Wheels | 2 | 04-05-2003 05:28 PM |
| 33x12.5" tires - recommended wheel backspacing? | malcolmzilla | Ford Explorer - Ranger Tires & Wheels | 11 | 08-28-2002 09:51 AM |
| question on backspacing | phillip perez | Ford Explorer - Ranger Tires & Wheels | 9 | 03-28-2001 10:27 PM |
