Ford Explorer Sport Trac Ford Ranger Mazda Navajo Mercury Mountaineer, Ford Aerostar Message Board®
Ford Explorer, Sport Trac, Mercury Mountaineer, Mazda Navajo, Ford Ranger, Ford Aerostar SUV Enthusiast Forums
Join the "Elite Explorers Today!"
Explorer4x4 Sportrucks EF Arcade Forums Elite Membership Product Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Repair - Tech - Modifications & Detailing Forums > Ford Explorer - Ranger Tires & Wheels
Notices
Ford Explorer - Ranger Tires & Wheels Want to know what size tire or wheel combo will work with your Ford Explorer or Ranger based vehicle? Interested in Beadlocks or Dubs? Learn all about them here.
Reply
Thread Tools
Old 07-02-1999, 02:05 PM   #1
tiessen
Vancouver, BC
'92 XLT
Vehicle Specs
Post
I am planning a 3" suspension, 1" body lift for my 92 Explorer. Stock, I have 31's on right now with no rubbing. What are the chances I could run a 33x10.5 (BFG AT KO) with that amount of lift? I don't mind a little fender trimming...
tiessen is offline   Reply With Quote
Sponsored Links (Less Ads)
Old 07-02-1999, 02:16 PM   #2
Rick
Admin
Pumpkin Pilot
Wayoutin, Aridzona
Rick's Avatar
'93 XL
Vehicle Specs
Post
I would say a pretty good chance it will work fine. Jack Lobdell is running a 4" suspension lift with 33x12.50's with no rubbing at all.
Rick Horwitz
explorer@4x4central.com
Editor
www.4x4central.com
[This message has been edited by Rick (edited 07-02-1999).]
Rick is offline   Reply With Quote
Old 07-02-1999, 09:05 PM   #3
Paul Gagnon
Poseur SUV
Sherwood Park, Alberta eh?
Paul Gagnon's Avatar
1992 XLT
Vehicle Specs
Cool
I have one little question for you. If you have not yet done any lift at all on your truck, why wouldn't you just do a 4 inch suspension lift? It would end up being a lot easier and cheaper to do.
Paul Gagnon
"No Brain, No Pain"
www.geocities.com/baja/canyon/8253
Paul Gagnon is offline   Reply With Quote
Old 07-05-1999, 12:13 PM   #4
tiessen
Vancouver, BC
'92 XLT
Vehicle Specs
Post
Well that was a consideration...but the cost of 4" was higher...I order a JD lift which is 2.5-3" ($400US), adding 0.5" spacers up front ($25) and re-arching the rear with the add-a-leaf (removing the overload) ($30 a side) to get a bit more lift in the rear...for the body lift, I'm doing a custom 1"...same as KyleK did, which will cost me $0. The Trailmaster 4" lift is ~$1500 with new rear springs...and you and others advised against a spring over (which would have been cheaper). So this is where I'm at...JD lift in on the way (paid for) and hopefully going in on the weekend.
Cheers
Dale
Old 07-05-1999, 03:14 PM   #5
bachelor25
Surrey, BC, Canada
'96 XLS 4DR 4x4
Vehicle Specs
Cool
Yeah Dale, you go ahead and put in that lift and then you get those 33x10.5" tires, and I'll pretend I'm not jealous at all!
(Wishing I could have 33x10.5 right now too, but got some 31x10.5" to wear out first)
Cheers,
Andrew B.
1996 Ford Explorer 4x4 (slightly modified)
BC, Canada
bachelor25 is offline   Reply With Quote
Old 07-08-1999, 08:03 AM   #6
paulpellini
Vehicle Specs
Question
I originally planned on throwing some 31x10.5 on my stock 99 Explorer but I changed my mind and I want to do a suspension lift to get some 33's under there. HOwever, every so called truck gu-ru down here in Miami FL tells me I cant buy a suspension lift for the 99, and that they only make them for the 97 and older. Is that true? If not, where can I get my hands on a 3 or 4 in suspension lift kit????
Paul
paulpellini is offline   Reply With Quote
Old 07-09-1999, 11:20 AM   #7
bachelor25
Surrey, BC, Canada
'96 XLS 4DR 4x4
Vehicle Specs
Post
Paul,
Unfortunately your "guru" is mostly accurate. His inaccuracy is in the fact that you can't buy a suspension lift for '95 or newer Explorers (front suspension was changed to IFS in '95). None of the suspension companies have tackled the complicated IFS, although Trailmaster is rumored to have a 4" lift almost completed.
It's not all bad news though! What you can do is a simple torsion bar/add-a-leaf lift which is relatively cheap, and gives you approximately 2" of lift, more than enough to comfortably fit up to 32s. I've done the lift on my '96, and have gained 2" front/2.5" rear. I have submitted a procedure write-up, Rick should have it in the "Explorer Tips" section in a couple days.
Cheers,
Andrew B.
BC, Canada
Old 07-10-1999, 04:45 PM   #8
EXPLORER SPORT
Vehicle Specs
Post
I'm sure you can fit them on. The link i have here of my truck has a 3" body lift and 31" but i had 33" superswampers on it too No rubbing but with the lugs on superswampers, turning can be a problem. I would go an inch higher to be sure like 4". From my pic you can see what 31" tires look like on a 3" lift. In the next month or two i'm going to get 32" tires so i'll post a new pic then. I do more street, snow driving, weekend 4x4ing so i feel 32"s will fit my driving style better. Hope this helps some. Later...
albums.photopoint.com/j/View?u=38196&a=247316&p=10777378
EXPLORER SPORT is offline   Reply With Quote
Reply
Top of Page
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Any one running BFG 33x10.5 A/T's? Zukster Ford Explorer - Ranger Tires & Wheels 8 04-14-2002 12:02 PM
33x10.5 on stock 7 inch rims JayR Ford Explorer - Ranger Tires & Wheels 13 10-18-2000 06:13 PM
Search ExplorerForum
US Flag
We Support Our Troops!
Explore the site!
Contact Us
This web site is not affiliated with or endorsed by the Ford Motor Company.
Ford Explorer is a registered Trade Mark of the Ford Motor Company
The names of actual companies and products mentioned herein may be the trademarks of their respective owners.
All tips and information provided on this site by either "Serious Explorations®" or it's contributors are for use at your own risk and discretion.
Modifying the suspension on any vehicle will cause changes to it's handling characteristics.
Some modifications described within this website may void your factory warranty.
Copyright 2009 - 1996 Rick Horwitz Photography
