Ford Explorer Sport Trac Ford Ranger Mazda Navajo Mercury Mountaineer, Ford Aerostar Message Board®
Ford Explorer, Sport Trac, Mercury Mountaineer, Mazda Navajo, Ford Ranger, Ford Aerostar SUV Enthusiast Forums
Join the "Elite Explorers Today!"
Explorer4x4 Sportrucks EF Arcade Forums Elite Membership Product Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Repair - Tech - Modifications & Detailing Forums > Ford Explorer - Ranger Tires & Wheels
Notices
Ford Explorer - Ranger Tires & Wheels Want to know what size tire or wheel combo will work with your Ford Explorer or Ranger based vehicle? Interested in Beadlocks or Dubs? Learn all about them here.
Reply
Thread Tools
Old 08-09-1999, 01:25 AM   #1
Jeff
Vehicle Specs
Post
The original Goodyears are just about gone and most of my research on new tires is almost done but there are a couple of questions about the two sizes that I need some help on. What is the real world difference between them? Will the 30x9.5 affect my speedometer? Waste of money? My Explorer mostly sees freeway driving, no offroad except to the mountains for skiing/backpacking.
Jeff is offline   Reply With Quote
Sponsored Links (Less Ads)
Old 08-09-1999, 07:58 AM   #2
sbrawner
Vehicle Specs
Post
Jeff-
There's an excellent site called http://www.4lo.com that has a tire radius calculator, with adjustments for speedo, gear ratio. Check it out.
sbrawner is offline   Reply With Quote
Old 08-23-1999, 04:06 PM   #3
DOGMAN
Mission, KS
91 XLT
Vehicle Specs
Post
Jeff,
I used to run 30x9.50-15's on my 91 XLT. The real world difference between the two depends on which manufacturer you go with and which style and model of tire. I happen to have the specs for Bridgestone Dueler A/T's handy so here goes(different specs for different tires from different manufacturers, but they are all fairly similar):
235/75-15
tire diameter- 28.9"
tread depth - 14/32"
section width- 9.1"
tread width - 6.9"
30x9.50-15
tire diameter- 29.6"
tread depth - 16/32"
section width- 9.8"
tread width - 7.3"
So you can see that the 30x9.50's are .7" taller than the 235/75's. This is not much but you will notice a drop-off in power slightly. Any time you increase the height of your tires without changing your gearing, the vehicle will act more sluggish. My experience with the 30x9.50's was that I liked the additional ground clearance but did't like that decrease in performance. It all depends what is important to you.
The 30x9.50's will affect your speedometer, it will read slower than actual speed. This is easily remedied though through the changing of the speedo gear. It is located where the speedo gear cable goes into the transfer case. It is easy for anyone to change, but if you don't want to bother, the dealer can do it for you. You will want to increase the number of teeth the gear has probably by one. To recheck accuracy after the change I time my vehicle between mile markers on the interstate. This works well.
If you're looking for opinions, mine is that if you are not looking for more ground clearance or just bigger tire looks, stay with the 235's. Your performance will stay the same as it was. If you put on 30x9.50's, your performance will suffer slightly.
Good luck with your decision.
DOGMAN
DOGMAN is offline   Reply With Quote
Reply
Top of Page
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
235 75 15 or 31x9.5 15 Big Bear Bob Ford Explorer - Ranger Tires & Wheels 5 05-10-2002 10:27 PM
Tire size for stock XLT 235 75r 15 vs. 30.95 15 Big Bear Bob Explorer Related Polls 1 04-21-2002 11:21 PM
235/75 R15 or 30x9.5 GenLee01 Ford Explorer - Ranger Tires & Wheels 8 11-02-2001 10:36 AM
Search ExplorerForum
US Flag
We Support Our Troops!
Explore the site!
Contact Us
This web site is not affiliated with or endorsed by the Ford Motor Company.
Ford Explorer is a registered Trade Mark of the Ford Motor Company
The names of actual companies and products mentioned herein may be the trademarks of their respective owners.
All tips and information provided on this site by either "Serious Explorations®" or it's contributors are for use at your own risk and discretion.
Modifying the suspension on any vehicle will cause changes to it's handling characteristics.
Some modifications described within this website may void your factory warranty.
Copyright 2009 - 1996 Rick Horwitz Photography
