Ford Explorer Sport Trac Ford Ranger Mazda Navajo Mercury Mountaineer, Ford Aerostar Message Board®
Ford Explorer, Sport Trac, Mercury Mountaineer, Mazda Navajo, Ford Ranger, Ford Aerostar SUV Enthusiast Forums
Join the "Elite Explorers Today!"
Explorer4x4 Sportrucks EF Arcade Forums Elite Membership Product Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Repair - Tech - Modifications & Detailing Forums > Ford Explorer - Ranger Tires & Wheels
Notices
Ford Explorer - Ranger Tires & Wheels Want to know what size tire or wheel combo will work with your Ford Explorer or Ranger based vehicle? Interested in Beadlocks or Dubs? Learn all about them here.
Reply
Thread Tools
Old 08-02-1999, 05:09 PM   #1
Kentucky Renegade
Vehicle Specs
Post
OK Fella's,
I'm looking to turn my stock 94 XLT family grocery getter into my hunting vehicle. It has around 93,000 on it now and the second set of shocks are pretty much worn out. What is the minimum I need to do to run a set of 31" tires without fear of them rubbing. Most places I go by the way are fairly improved gravel roads. I am on a budget so I need to thing reasonable here, but I don't want to sacrifice durability either. What benefits will replacing the body bushings and such provide me? All responses are welcome. Thanks!
Kentucky Renegade is offline   Reply With Quote
Sponsored Links (Less Ads)
Old 08-02-1999, 05:23 PM   #2
Todd
Southwest MO
93 XLT (Sold)
Vehicle Specs
Post
Well, there is not a very definitive answer to your inquiry. The problem lies in the fact that some Explorers can run 31's right out of the box, while others require modification. Take for example, my explorer, I had very, very slight rubbing when I switched to 31's without any suspension modification. I did not like any rubbing at all, so I decided that it was time to modify. All that I did was put a 1.5" add-a-leaf in the rear and a 1" coil spacer up front underneath the coils. Either way, it was not too difficult. Hope that this helps a little.
Take care and happy exploring!
Todd Metzger
tmetz@umr.edu
'Off-Road and More!'
93 "Ford X 4" XLT
Todd is offline   Reply With Quote
Old 08-02-1999, 10:29 PM   #3
Kentucky Renegade
Vehicle Specs
Smile
Todd,
Thanks for the information. What kit did you use to add the lift and about how much does it cost? I'm looking at keeping the cost down because I see an engine or maybe a transmission rebuild somewhere in the immediate future. I need to keep the extra money for the more serious repairs.
Thanks Again!
Old 08-03-1999, 09:26 AM   #4
Todd
Southwest MO
93 XLT (Sold)
Vehicle Specs
Post
Well, I put the kit together myself. The 1" spacers were machined by a friend(for free) and the rear add-a-leafs were purchased separately for approximately $50. This is an OK fix to fit larger tires if that is all that you are trying to do. You must also remember that, by the adding the new leaf, the rear end is going to be much stiffer. So, you will have to live with it. Now, if you were wanting to purchase an actual kit, skyjacker provides a very affordable 1.5" lift that retails around $140. It comes with new front coils and a set of add-a-leafs for the rear. I was originally going to order this lift, but was dissauded by a tech at Rocky Mountain Suspension(granted, after a recent incident, I wouldn't trust them with my worst enemy's vehicle). The tech told me that it would become unalignable with that amount of lift. After I researched a little, I found several people on this board that are running this lift without a problem. So, I don't see too much of a problem. Alignment may still be an issue, but not too, too bad.
As for myself, I recently purchased a 2.5" lift from James Duff and can't wait to install it. I just have to get through the next 2-3 weeks and then up on the rack it is going.
Anyway, hope this helps a little. Take care and happy exploring!
Todd Metzger
tmetz@umr.edu
93 "Ford X 4" XLT
Old 08-03-1999, 10:42 AM   #5
j
Vehicle Specs
Thumbs up
Todd is right on! Just go to your tire store and try ONE tire on the front end, then get that wheel up on a rock or tall curb and twist every way you can. If you don't rub, you fit. If you don't fit, go for a 1.5" lift...you always have to realign after anay lift, but let it settle in a couple of hundred miles first. Be sure you go to an alignment place that will make minor realignment follow-up for free within a month after doing it the first time. Replace your shocks if you need to (the cheapest good ones are NAPA Sens-tracs (the same as the Monroes, rebadged and just less $$$). Watch for shimmy....that will call for a front stabilizer shock, about $50 installed. Hapy hunting.
j is offline   Reply With Quote
Old 08-03-1999, 10:04 PM   #6
Kentucky Renegade
Vehicle Specs
Smile
Thanks Everyone! I appreciate the advise. Wish me luck!
Old 09-21-1999, 06:24 PM   #7
Mando
Matamoros, Tamaulipas, Mexico
1992, 2-door Explorer XL
Vehicle Specs
Post
Todd:
Would you provide me the specs of your coil spacers? I can also get them machined for free, but I need the specs.
Thanks,
Mando
Mando is offline   Reply With Quote
Reply
Top of Page
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Gerald Jarrett - Simpsonville, SC GJarrett Explorer Registry 68 08-05-2009 01:10 PM
Tire jurors hear from Firestone chief Dolphan Ford Industry News 0 08-18-2001 12:38 PM
Low Heat Rating Found in Tires on Ford SUVs Dolphan Ford Explorer - Ranger Tires & Wheels 0 09-23-2000 02:30 PM
How deep is Ford in? Stephen Ford Industry News 2 08-26-2000 01:14 PM
Search ExplorerForum
US Flag
We Support Our Troops!
Explore the site!
Contact Us
This web site is not affiliated with or endorsed by the Ford Motor Company.
Ford Explorer is a registered Trade Mark of the Ford Motor Company
The names of actual companies and products mentioned herein may be the trademarks of their respective owners.
All tips and information provided on this site by either "Serious Explorations®" or it's contributors are for use at your own risk and discretion.
Modifying the suspension on any vehicle will cause changes to it's handling characteristics.
Some modifications described within this website may void your factory warranty.
Copyright 2009 - 1996 Rick Horwitz Photography
