| Explorer4x4 | Sportrucks | EF Arcade | Forums | Elite Membership | Product Reviews | Explorer Photo Gallery |
| Notices |
| Explorer, Ranger, A/C & Heater systems HVAC Ford Explorer, Ranger, Mountaineer, Bronco II, Air Conditioning and Heating Systems. |
Thread Tools |
#1 |
Wannabe Elite Explorer
WS, North Carolina
97 XLT, 03 Mnt Premier
AC Compressor Leaking
I have a 1997 Explorer with the 5.0 V8 AWD WITH 206,000 miles on it.
The AC compressor has been replaced twice once for leaking and once for total failure (locked up) this time its leaking again from the front seal of the compressor. I have put in the dye and checked it for leaks with a blacklight. The leak is terible,I do a full charge and its empty within 10-15 days. It is defin the front seal on the compressor! My question is Ford says the front seal is not available and i must buy a new compressor. Is this true or does anyone know it the front seal can in fact be replaced? Thanks... |
| Sponsored Links (Less Ads) |
#2 |
CT
96 LTD V8 AWD
__________________
We shall not cease from exploration And the end of all our exploring T.S. Eliot. www.pcsad.biz www.pcsad.com |
#3 |
Fort Collins, CO
'92 Eddie Bauer
get rid of it!
i took mine out and keep my windows rolled down, still keep cool and get better gas mileage
#4 |
EF Tranny Guru
Sacramento, CA 95827
1992 XLT
The 97 uses the FS-10 compressor. The seal is replaceable, but the tools required are not readily available to the DIY'er. Seal replacement on these is not easy, nor reliably done in the field. That is why FORD does not do them.
I have the tools, and yet I'd elect to replace the compressor. Nuff said? ps. These seals work through black magic, I swear. So much as touching the sealing surface with a finger can cause the seal not to do it's job! I have come to the conclusion seal replacement is a clean room item best done at a reman facility. But you did get a link to a source for the fs-10 seal. But...you cannot improvise the tools necessary to install it... and several are required. |
#5 |
WS, North Carolina
Thanks for the input folks!
I wound up replacing the compressor & orifice tube (old tube was very clean) Got it all charged up with R-134A and it will cool to 38-39 degrees at idle but only cool down to 44-45 while driving the vehicle. Is this normal? I though you would get the lower temperature in motion with all the air flow through the front of the vehicle. I am getting these temps with the AC on MAX and the blower speed on the next to the highest setting. Thanks for any Input! |
#6 |
EF Tranny Guru
1992 XLT
It's possible you have either too much refrigerant and are flooding the evaporator at speed, or too little and it's starving. I'd maybe start by removing a few ounces and drive checking it, it it is the same or worse, add an amount double what you just put in and retry.... you may need to fine tune it.
| Bookmarks |
| Thread Tools | |
