Ford Explorer Sport Trac Ford Ranger Mazda Navajo Mercury Mountaineer, Ford Aerostar Message Board®
Ford Explorer, Sport Trac, Mercury Mountaineer, Mazda Navajo, Ford Ranger, Ford Aerostar SUV Enthusiast Forums
Join the "Elite Explorers Today!"
Explorer4x4 Sportrucks EF Arcade Forums Elite Membership Product Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Repair - Tech - Modifications & Detailing Forums > Under the Hood > Explorer, Ranger, A/C & Heater systems HVAC
Notices
Explorer, Ranger, A/C & Heater systems HVAC Ford Explorer, Ranger, Mountaineer, Bronco II, Air Conditioning and Heating Systems.
Reply
Thread Tools
Old 05-05-2006, 12:22 PM   #1
ExplorerDMB
Moderator/Technician
Mechanicsville, Virginia
2004 Acura TL
Vehicle Specs
Exclamation Caution: A/C Systems and Very High Pressures
This is really just a safety thread for you DIYs. A/c systems can be easy (sometimes- with the right tools) to work on, but you must be careful around the stuff. Through those lines and in the compressor is highly compressed gasses/fluids and you need to understand that they are heavily pressurized. Even when you pull vaccum or pull the system down, STILL take precautions when taking lines off.
For Instance; I was helping another tech on a Evaporator core (which is in the dash), and we had to pull down the system. When we do cores, we replace the dryer as well. So, while he was messing inside, I started messing with getting the lines loose at the compressor and at the firewall. Well, as I was unscrewing the bolt for the line on the compressor, I thought to myself, "I wonder if it got all of it out". So I held up the line a little to give the seal on the compressor some air and it started to leak out pretty quickly and at a violent rate.
What I am saying is just be careful. In the above story, the system also had dye in it, so freon AND dye in your eye, mouth, etc. probably isn't the best thing in the world and may cause issues later. Just be careful!
-Drew
__________________
My Useful Threads (38 Entries and Growing)
ExplorerDMB is offline   Reply With Quote
Sponsored Links (Less Ads)
Old 05-05-2006, 07:28 PM   #2
Glacier991
EF Tranny Guru
Sacramento, CA 95827
1992 XLT
Vehicle Specs
I ALWAYS recommend wearing eye protection when working on a charged system and fooling around with fittings etc. Refrigerant in your eye isn't a potential problem later, it is a certain BLINDNESS or serious vision problem RIGHT NOW ! Corneal replacements are not fun, cheap, nor easy to come by. Safety glasses may not be fun but they are cheap and easy to come by. Blindness sucks.
Thanks Drew. I always try and stress this in my threads on AC, but a separate thread is a good idea.
Glacier991 is offline   Reply With Quote
Reply
Top of Page
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Search ExplorerForum
US Flag
We Support Our Troops!
Explore the site!
Contact Us
This web site is not affiliated with or endorsed by the Ford Motor Company.
Ford Explorer is a registered Trade Mark of the Ford Motor Company
The names of actual companies and products mentioned herein may be the trademarks of their respective owners.
All tips and information provided on this site by either "Serious Explorations®" or it's contributors are for use at your own risk and discretion.
Modifying the suspension on any vehicle will cause changes to it's handling characteristics.
Some modifications described within this website may void your factory warranty.
Copyright 2009 - 1996 Rick Horwitz Photography
