| Explorer4x4 | Sportrucks | EF Arcade | Forums | Elite Membership | Product Reviews | Explorer Photo Gallery |
| Notices |
| Explorer, Ranger, A/C & Heater systems HVAC Ford Explorer, Ranger, Mountaineer, Bronco II, Air Conditioning and Heating Systems. |
Thread Tools |
#1 |
Wannabe Elite Explorer
fresno
94 Xlt
A/C high side connector leaking.. Question
Alright I have a leak on my brothers 94 explorer and its comming from the high side test port. I know typically the valve has a schrader like a bicycle valve, but when i look down in the valve it justt looks like a black ball and doesn't look replaceable. Also looking at the valve it's not looking like the valve is replacable either and the hole hose going to the compressor has to be replaced. Am I retarded or does the entire hose need to be replaced?
| Sponsored Links (Less Ads) |
#2 |
Moderator/Technician
Mechanicsville, Virginia
2004 Acura TL
Moving to A/C section
__________________
My Useful Threads (38 Entries and Growing) |
#3 |
Milford, CT
1994 XLT
It does not have a schrader valve. Assuming the system is empty, the whole fitting itself can be unscrewed from the hose and replaced. I'm not sure how to describe this exactly, but if you look closely at the fitting, you'll see some flats on it-- use a wrench on the flats and unscrew it from the metal "t-fitting" (for lack of a better word) that is attached to the hose. I was not able to find the fitting at the local Carquest, but I've read about people here buying them at a dealership. I've also seen something similar as part of a retrofit kit at autozone. I didn't bother to follow up with this though-- the guys at carquest felt bad that they didn't have a new fitting, so they gave me a new plastic cap with a rubber seal in it. I put that on tighly about two years ago and haven't had a problem with it since.
__________________
Not by might, nor by power but by my Spirit. What are you, O great mountain? -God |
| Bookmarks |
| Thread Tools | |
