Ford Explorer Sport Trac Ford Ranger Mazda Navajo Mercury Mountaineer, Ford Aerostar Message Board®
Ford Explorer, Sport Trac, Mercury Mountaineer, Mazda Navajo, Ford Ranger, Ford Aerostar SUV Enthusiast Forums
Join the "Elite Explorers Today!"
Explorer4x4 Sportrucks EF Arcade Forums Elite Membership Product Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Repair - Tech - Modifications & Detailing Forums > Under the Hood > Explorer, Ranger, A/C & Heater systems HVAC
Notices
Explorer, Ranger, A/C & Heater systems HVAC Ford Explorer, Ranger, Mountaineer, Bronco II, Air Conditioning and Heating Systems.
Reply
Thread Tools
Old 05-18-2006, 07:50 PM   #1
dreamr
Hiding..... somewhere
Shoreline WA
dreamr's Avatar
99 XL / 4x4 / 4.0 ohv
Vehicle Specs
Quick A/C Charge question
So just a quick question. Vehicle info is under that picture to the left.,....
My A/c quit blowing cold air toward the end of last fall. I didn't really care as winter was approaching. Now that it is summer I picked up a charge kit from the local Schucks Auto Supply. When I hooked the kit up to my warmed up truck with the A/C on high it read that I had around 18 psi in the system. I ran about 3/4 of the can (19 oz) in and was getting a reading of right at 45 psi. I disconnected the can and let it run for a sec. The air inside was nice and cold
Just to make sure all was good I hooked the gauge back up to the low side port. I was now getting a reading of 25psi. I left it hooked while the compressor kicked on and off a few times. The reading did not change. I figured well it "settled" a bit and pulled the trigger to add more r-134a. The gauge instantly jumped up to 45 and stayed there.
So my question is this. Since it is cold air and all, do I just say good enough, or do I need to mess with it more? Sorry this is the first time I have ever recharged A/C. All my cars except the VW have run r-12 so were serviced professionally. The VW never needed it.
dreamr is offline   Reply With Quote
Sponsored Links (Less Ads)
Old 05-20-2006, 02:40 AM   #2
Glacier991
EF Tranny Guru
Sacramento, CA 95827
1992 XLT
Vehicle Specs
The low side should pull down to about 25 psi or so and then the compressor will cycle. The FORD system SHOULD cycle except in very hot weather. Your compressor should not run all the time. Cycling times will depend on a number of factors. In Florida on a HOT day it may cycle little. In Colorado at 85 degrees it may cycle a lot.
Those little pressure gauges are misleading. A gauge set is much better. pressures in AC are not like tire pressures. In a FORD orifice valve system they will fluctuate based on a number of factors. It is NOT like readng your tire air pressure and saying you are low. And pressures MUST be read with the system operating.
If your compressor is constantly running you probably have too much refrigerant in the system. (Not a good thing)
When giving system operation info, some things that are ALWAYS helpful are ambient outside air temp, and vent temp at the time of the test.... if you have a gauge set hi side and low side pressures are also helpful.
Glacier991 is offline   Reply With Quote
Old 05-20-2006, 03:22 AM   #3
dreamr
Shoreline WA
dreamr's Avatar
Vehicle Specs
It was a nice warm day that day, but I have no clue what the ambient temp was. The compressor is kicking on and off as always and things are working normally. I suppose I should have the neighborhood garage test it for me the right way....
I would buy proper gauges rather than the cheapy kit...but my X is the only vehicle I have running a/c now. The Kia is to cheap for air, and I ripped it out of the Mustang rather than converting to 134a...
Thanks for the info Glacier..
Old 05-20-2006, 08:53 PM   #4
Glacier991
EF Tranny Guru
1992 XLT
Vehicle Specs
If you are compressor cycling on occasion and the vent temps are good... I'd rest that all is ok.
You may have other more pressing needs and I understand, but I am starting to see the gauge sets on sale at harbor freight for about $40.
Old 05-21-2006, 02:33 PM   #5
dreamr
Shoreline WA
dreamr's Avatar
Vehicle Specs
Quote:
Hmm I might just have to drive up there I need to get a new timing light and where else is stuff cheaper
Thanks Glacier
Reply
Top of Page
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Search ExplorerForum
US Flag
We Support Our Troops!
Explore the site!
Contact Us
This web site is not affiliated with or endorsed by the Ford Motor Company.
Ford Explorer is a registered Trade Mark of the Ford Motor Company
The names of actual companies and products mentioned herein may be the trademarks of their respective owners.
All tips and information provided on this site by either "Serious Explorations®" or it's contributors are for use at your own risk and discretion.
Modifying the suspension on any vehicle will cause changes to it's handling characteristics.
Some modifications described within this website may void your factory warranty.
Copyright 2009 - 1996 Rick Horwitz Photography
