Ford Explorer Sport Trac Ford Ranger Mazda Navajo Mercury Mountaineer, Ford Aerostar Message Board®
Ford Explorer, Sport Trac, Mercury Mountaineer, Mazda Navajo, Ford Ranger, Ford Aerostar SUV Enthusiast Forums
Join the "Elite Explorers Today!"
Explorer4x4 Sportrucks EF Arcade Forums Elite Membership Product Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Repair - Tech - Modifications & Detailing Forums > Under the Hood > Explorer, Ranger, A/C & Heater systems HVAC
Notices
Explorer, Ranger, A/C & Heater systems HVAC Ford Explorer, Ranger, Mountaineer, Bronco II, Air Conditioning and Heating Systems.
Reply
Thread Tools
Old 05-29-2006, 07:21 AM   #1
Randy1999
Toronto, Ontario
1999 XLT
Vehicle Specs
A/C on all the time
It seems that most postings deal with A/C not working. However in my case it is the opposite. I have a '99 Explorer XLT. It seems that my A/C is on all the time even though I have not selected A/C or Max A/C. Does anyone have any idea as to what this is and how to correct it? Thanks.
__________________
1999 Explorer XLT
Randy1999 is offline   Reply With Quote
Sponsored Links (Less Ads)
Old 05-29-2006, 09:24 AM   #2
budwich
Ottawa, Ont
96 XL
Vehicle Specs
I assume that you mean that the compressor clutch turns on (for a bit) even though you don't select the "AC" based positions on your heater / AC control... right? Ford's idea is that A/C will also be used to "dry air" in other positions.... those positions are where the air goes to both top and floor vents. The A/C will come on for just a bit (dependent on the temperature position... more red less A/C, more blue more A/C). If you select either floor only, or upper vent only then no A/C is applied. I think it is spelt out in your manual.
If you mean that your A/C compressor never disengages, then you have a problem.
budwich is online now   Reply With Quote
Old 05-29-2006, 12:36 PM   #3
xartic
Brazil, Indiana
02 awd v8 mounty
Vehicle Specs
I have the same problem. I could put it on defrost with cold air, and the ac compressor still turns on.
xartic is offline   Reply With Quote
Old 05-29-2006, 01:14 PM   #4
Randy1999
Toronto, Ontario
1999 XLT
Vehicle Specs
I didn't think about the "dry air" thing, but it seems not to disengage, but I'll test it further to make sure that it is clearly a disengaging problem and not what you have suggested. If it is a disenganing problem, what's involved in fixing it?
Thanks, budwich.
__________________
1999 Explorer XLT
Old 05-29-2006, 01:15 PM   #5
budwich
Ottawa, Ont
96 XL
Vehicle Specs
I was also a "bit off".... as the AC also comes on for the "defog" cycle to help dry the air to aid in the defogging (I assume you mean defog and not defrost). In terms of shutting off your compressor, you can try unplugging the energizing circuit at the compressor. That should totally stop the clutch from engaging. If it doesn't, then you have a clutch mechanical problem and that need attention otherwise you will likely cause yourself a compressor problem ($$$$). If it does stay disengaged (with the plug removed), you need to find out why there is an operating voltage on the circuit. That will take a bit further investigation. I assume that you are in the "cycling" camp and that its probably "normal" for your settings.
Old 06-06-2006, 08:05 PM   #6
rgoers
Rochester, NY
2000 Sport
Vehicle Specs
Exactly what mine does... that's "normal"???
... compressor clutch turns on (for a bit) even though you don't select the "AC" based positions on your heater / AC control... those positions are where the air goes to both top and floor vents. ... If you select either floor only, or upper vent only then no A/C is applied.
I just charged my (previously non-working) A/C system a couple weeks ago. I've only run it a few times, and it seems to still be cold.
However, I noticed the A/C clutch engaging this AM, when I had it at the vent/floor setting. When I go to vent only, the air seems to warm a bit, but at vent/floor, it's like having the A/C full "on". Ford deems this to be "normal" operation??? Are they on drugs? No wonder they get such wonderful gas mileage... doh!!???
I know about it on the defrost setting, because most manufacturers do that, but C'mon, you're kidding about this being normal, right? Is it April 1st today? I must have a wiring problem... What's the purpose of the A/C and A/C Max positions then?
rgoers is offline   Reply With Quote
Old 06-07-2006, 12:19 PM   #7
Brock94
Milford, CT
1994 XLT
Vehicle Specs
I have a dodge truck that's the same way. I prefer the 1st Gen Explorer that lets you select A/C (or not) in whatever vent mode you want.
If you wanted to get creative, it wouldn't be too hard to disconnect the A/C wires from your control head and connect them to a new switch that would give you total control.
__________________
Not by might, nor by power but by my Spirit.
What are you, O great mountain?
-God
Brock94 is offline   Reply With Quote
Old 06-07-2006, 01:50 PM   #8
Ranger379
middle of nowhere, PA
'99 XLT 4X4 4.0 OHV Auto
Vehicle Specs
you guys are lucky, mine dont work at all... lol
__________________
1999 Ford Explorer XLT 4x4 4.0 OHV Auto
-Lifted! TT, AAL's and custom shackles
RIP: 1996 Ford Explorer XL 4x4 4.0 OHV 5 Speed
- 2inch TT, Shackles and AAL's- American Eagle Alloy Series 58 15x8 Rims = Wrapped with Yokohama Geolander A/T-S 32x11.50's
Ranger379 is offline   Reply With Quote
Old 06-07-2006, 04:16 PM   #9
budwich
Ottawa, Ont
96 XL
Vehicle Specs
Rgoers.... not sure if you are "kidding" me about "kidding" you.... but no, having A/C on the vent/floor setting is in the manual. As a previous GM owner, I too was rather taken back by this, especially since my A/C on the Ex wasn't fully charged when I bought it used. The result was a significant cycling of the compressor which I only noticed when I happen to walk up to my truck when my wife was getting set to drive off. I yelled at her with "why are you running the AC?" this was in april (last year). She said wasn't.... that's when my investigation led me to the manual..... before my compressor was hosed.
Old 06-08-2006, 06:35 PM   #10
rgoers
Rochester, NY
2000 Sport
Vehicle Specs
Thanks!!!
.... I too was rather taken back by this, especially since my A/C on the Ex wasn't fully charged when I bought it used. The result was a significant cycling of the compressor which I only noticed when I happen to walk up to my truck when my wife was getting set to drive off. ...
Thanks for the additional explain! I did the same thing - bought my EX w/o working air. I drove it all fall and winter that way. I charged it this spring, and was as surprised as you when I heard the clutch cycling on non-A/C settings. I'm an engineer, so it *really* amazes me why anyone would intentionally design it that way. No wonder I can't get over 20 MPG...
Again - thank you for convincing me that it is operating "normally".
Reply
Top of Page
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Search ExplorerForum
US Flag
We Support Our Troops!
Explore the site!
Contact Us
This web site is not affiliated with or endorsed by the Ford Motor Company.
Ford Explorer is a registered Trade Mark of the Ford Motor Company
The names of actual companies and products mentioned herein may be the trademarks of their respective owners.
All tips and information provided on this site by either "Serious Explorations®" or it's contributors are for use at your own risk and discretion.
Modifying the suspension on any vehicle will cause changes to it's handling characteristics.
Some modifications described within this website may void your factory warranty.
Copyright 2009 - 1996 Rick Horwitz Photography
