Ford Explorer Sport Trac Ford Ranger Mazda Navajo Mercury Mountaineer, Ford Aerostar Message Board®
Ford Explorer, Sport Trac, Mercury Mountaineer, Mazda Navajo, Ford Ranger, Ford Aerostar SUV Enthusiast Forums
Join the "Elite Explorers Today!"
Explorer4x4 Sportrucks EF Arcade Forums Elite Membership Product Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Repair - Tech - Modifications & Detailing Forums > Under the Hood > Explorer, Ranger, A/C & Heater systems HVAC
Notices
Explorer, Ranger, A/C & Heater systems HVAC Ford Explorer, Ranger, Mountaineer, Bronco II, Air Conditioning and Heating Systems.
Reply
Thread Tools
Old 05-30-2006, 01:04 PM   #1
bls2dpj
Wichita, Kansas
1997 XLT
Vehicle Specs
US A/C died need advice
I have a '97 Explorer 122,000 miles V6 SOHC.
My accumulator rusted and has died. The shop said my evaporator core is leaking too. I was told $1000 to replace parts and recharge.
I am thinking about replacing the parts myself (about $200) and then taking it back to the shop to pressurize & recharge. Any thoughts on this? Should I suck it up and pay the grand for them to do it?
Parts I would replace:
evaporator
accumulator
orifice tube
misc o-rings
any advice??
DJ
bls2dpj is offline   Reply With Quote
Sponsored Links (Less Ads)
Old 05-30-2006, 01:10 PM   #2
Gatorblazer
Baby on the Way!
Moody, AL
Gatorblazer's Avatar
Looking for another SUV
Vehicle Specs
http://www.explorerforum.com/forums/...d.php?t=159964
Join the fun here. If you have never done any AC work, I wouldnt attempt it. Too many risks for contamination
__________________
Remember, some people are alive simply because it is illegal to shoot them.
www.birminghambassclub.net
Gatorblazer is offline   Reply With Quote
Old 05-30-2006, 01:28 PM   #3
Brock94
Milford, CT
1994 XLT
Vehicle Specs
Quote:
Originally Posted by Gatorblazer
[url] If you have never done any AC work, I wouldnt attempt it. Too many risks for contamination
I would say if you're a decent DIYer and want to take the time to read up a little about the project you can fix it, vacuum it and recharge it yourself. If you don't want to take the time to read up on it and do it right and safely, you're better off going with a shop. There's great info on this site, so it's up to you.
You would need to buy or borrow a couple special tools-- especially if you plan to evacuate and recharge it yourself, but the cost of those tools is well within the $800 you'll save doing this.
__________________
Not by might, nor by power but by my Spirit.
What are you, O great mountain?
-God
Brock94 is offline   Reply With Quote
Old 05-30-2006, 02:54 PM   #4
bls2dpj
Wichita, Kansas
1997 XLT
Vehicle Specs
US
Well, I usually do my own work but my explorer has never needed anything other than the usual maintenance. I have no problem doing the work but just want to make sure that its a do-able project. The accumulator basically blew a hole in the side of the cansister so I don't have any pressure to deal with and the system has been exposed to the elements.
I am thinking about replacing the parts and then having the shop vaccum the system, re-oil and charge it, since, I don't have the tools for that part of the project.
Any other advice,
DJ
Old 05-30-2006, 08:25 PM   #5
Glacier991
EF Tranny Guru
Sacramento, CA 95827
1992 XLT
Vehicle Specs
If all that has happened is that you had an accumulator rust out.... and lost the charge, the open system prolem would be fixed by the new accumulator. If you are on a tight budget, you COULD just replace the accumulator (those garter spring connectors can be a PITA ,but very DIY capable with the spring lock tools) and take it in to have the system pulled into a deep vacuum and then recharged. I'd put 2 oz of PAG oil in the accumulator when you install it.
I'll correct your usage of the term vacuumed...I am sure you meant evacuated but so many folks think evacuating a system is like vacuuming carpet. Of course it is not. You have a closed system that you pull into a very low vacuum state. Any moisture will boil in a vacuum (remember seeing that in physics in High School?) And after about 30-45 minutes the mnoisture will have boile away and been drawn out of the system, at which point refrigerant (134a in this case) will be introduced in the proper quantity.
I am doubtful anything else in your system is likely bad.... it WOULD be nice to check the orofice tube, but not do or die in your situation.
Glacier991 is offline   Reply With Quote
Old 05-30-2006, 10:40 PM   #6
bls2dpj
Wichita, Kansas
1997 XLT
Vehicle Specs
US
The springs you mentioned, is there a tool to help remove them? Do you happen to know if someone has documented the procedure, other than the lousy Clymer/Haynes manuals? maybe someone on the forum? I think if the orifice tube is easy to get to, I might as well replace it while its down. Any other suggestions of what to and not to replace? Are there many o-rings that need replacing? Sorry for all the questions.
DJ
Old 05-31-2006, 12:13 AM   #7
Glacier991
EF Tranny Guru
1992 XLT
Vehicle Specs
this may help....
http://www.explorerforum.com/forums/...0&highlight=AC
Reply
Top of Page
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Search ExplorerForum
US Flag
We Support Our Troops!
Explore the site!
Contact Us
This web site is not affiliated with or endorsed by the Ford Motor Company.
Ford Explorer is a registered Trade Mark of the Ford Motor Company
The names of actual companies and products mentioned herein may be the trademarks of their respective owners.
All tips and information provided on this site by either "Serious Explorations®" or it's contributors are for use at your own risk and discretion.
Modifying the suspension on any vehicle will cause changes to it's handling characteristics.
Some modifications described within this website may void your factory warranty.
Copyright 2009 - 1996 Rick Horwitz Photography
