Ford Explorer Sport Trac Ford Ranger Mazda Navajo Mercury Mountaineer, Ford Aerostar Message Board®
Ford Explorer, Sport Trac, Mercury Mountaineer, Mazda Navajo, Ford Ranger, Ford Aerostar SUV Enthusiast Forums
Join the "Elite Explorers Today!"
Explorer4x4 Sportrucks EF Arcade Forums Elite Membership Product Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Repair - Tech - Modifications & Detailing Forums > Under the Hood > Explorer, Ranger, A/C & Heater systems HVAC
Notices
Explorer, Ranger, A/C & Heater systems HVAC Ford Explorer, Ranger, Mountaineer, Bronco II, Air Conditioning and Heating Systems.
Reply
Thread Tools
Old 05-31-2006, 04:08 PM   #1
vam
Brooklyn, NY
1997 Eddie Bauer 4WD
Vehicle Specs
Recharging A/C
Hi all,
I have a 1997 Explorer, Eddie Bauer Edition v8. Can someone tell me where I can find an engine diagram so i can located the lower valve in the AC unit. I purchased an AC recharger kit and they are telling me to connect to the lower valve.
Thanks,
victor
vam is offline   Reply With Quote
Sponsored Links (Less Ads)
Old 05-31-2006, 04:54 PM   #2
Brock94
Milford, CT
1994 XLT
Vehicle Specs
I'm not sure exactly where they are on your 97 (I have a 94), but there are only two service ports on the A/C system. Each of them has a plastic cap that unscrews (they should anyway). If you follow the hoses of your A/C system around, you will find the two service ports. The low side port on my 94 is actually on the receiver/drier (the tank-like thing). The low-side port is much smaller in diameter than the high side, so that will make it obvious which is which.
That's all to answer your question, but I'm not a big fan of the recharge kits because they oversimplify the charging and A/C repair process and you risk doing damage to your system that could be more costly than getting it professionally repaired.
Read the sticky post in this forum on Recharging A/C-- it outlines the proper procedure so you can contrast that to what is provided in your kit. You risk overcharging and destroying your compressor, not to mention that the kit will not repair a leak. The sticky post on converting from R-12 to R-134a also has a good discussion on the use of kits (and the best way to use them if you must).
So you know, it would be best not to use a kit with "stop-leak" in it. Most shops test for this stuff and will not repair your system later if it has this in it. (Stop-leak damages their recovery equipment.)
All that said, if you are interested in learning how to fix your system right, there is good info here and people here will be glad to walk you through it. The last two times I took a car to the A/C shop it cost me $600-$700-- with manifold gauge sets for $40-$100 and vacuum pumps for $180 (or less if you find a place that rents), you can easily save a ton of money and still do the repairs the right way.
__________________
Not by might, nor by power but by my Spirit.
What are you, O great mountain?
-God
Brock94 is offline   Reply With Quote
Old 05-31-2006, 10:12 PM   #3
vam
Brooklyn, NY
Vehicle Specs
Thanks for the info Brock, I'm going to take your advice and have it professionaly done.
Old 06-01-2006, 09:27 AM   #4
Brock94
Milford, CT
1994 XLT
Vehicle Specs
Quote:
I didn't mean to discourage you from doing it yourself-- just from using the $30 miracle kit. Of course you should use your judgment about what you're willing/able to take on, but my main point is that the special A/C tools you need to buy to do it right will usually pay for themselves on the first repair and you'll still have the tools for next time.
__________________
-God
Reply
Top of Page
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Search ExplorerForum
US Flag
We Support Our Troops!
Explore the site!
Contact Us
This web site is not affiliated with or endorsed by the Ford Motor Company.
Ford Explorer is a registered Trade Mark of the Ford Motor Company
The names of actual companies and products mentioned herein may be the trademarks of their respective owners.
All tips and information provided on this site by either "Serious Explorations®" or it's contributors are for use at your own risk and discretion.
Modifying the suspension on any vehicle will cause changes to it's handling characteristics.
Some modifications described within this website may void your factory warranty.
Copyright 2009 - 1996 Rick Horwitz Photography
