Ford Explorer Sport Trac Ford Ranger Mazda Navajo Mercury Mountaineer, Ford Aerostar Message Board®
Ford Explorer, Sport Trac, Mercury Mountaineer, Mazda Navajo, Ford Ranger, Ford Aerostar SUV Enthusiast Forums
Join the "Elite Explorers Today!"
Explorer4x4 Sportrucks EF Arcade Forums Elite Membership Product Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Repair - Tech - Modifications & Detailing Forums > Under the Hood > Explorer, Ranger, A/C & Heater systems HVAC
Notices
Explorer, Ranger, A/C & Heater systems HVAC Ford Explorer, Ranger, Mountaineer, Bronco II, Air Conditioning and Heating Systems.
Reply
Thread Tools
Old 06-03-2006, 03:08 PM   #1
Wallace5
Bethel Park PA
98 Eddie Bauer
Vehicle Specs
US auto temp control malfunction
My 98 Explorer has the Auto Temperature control feature, and is stuck on high heat only reguardless of digital reading. Are there any sudgestions for trouble shooting?
Wallace5 is offline   Reply With Quote
Sponsored Links (Less Ads)
Old 12-07-2007, 11:35 AM   #2
chrnio
Vehicle Specs
I had a similar problem. It turned out to be the blower relay was stuck on. A new relay for $6 fixed the problem. The relay is in the power distribution box on the drivers side, by the fire wall. When you open the box, it's the relay all the way up by the fire wall, and all the way towards the engine.
chrnio is offline   Reply With Quote
Old 12-07-2007, 01:38 PM   #3
btexpress
Westminster, Colorado
2000 Ranger XLT 4X4
Vehicle Specs
If you mean there is no temp control, only hot, this is commonly a blend door issue, either the blend door itself is broken, or the actuator is inop. The actuator can be changed easily, it is behind the glove box. If the door is broken, the preferred repair is replacing the plenum, however there are kits available that offer a cheaper alternative. Replacing the plenum requires removing the instrument panel.
In the case of high blower only, could be the blower controller .
btexpress is offline   Reply With Quote
Reply
Top of Page
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Search ExplorerForum
US Flag
We Support Our Troops!
Explore the site!
Contact Us
This web site is not affiliated with or endorsed by the Ford Motor Company.
Ford Explorer is a registered Trade Mark of the Ford Motor Company
The names of actual companies and products mentioned herein may be the trademarks of their respective owners.
All tips and information provided on this site by either "Serious Explorations®" or it's contributors are for use at your own risk and discretion.
Modifying the suspension on any vehicle will cause changes to it's handling characteristics.
Some modifications described within this website may void your factory warranty.
Copyright 2009 - 1996 Rick Horwitz Photography
