Ford Explorer Sport Trac Ford Ranger Mazda Navajo Mercury Mountaineer, Ford Aerostar Message Board®
Ford Explorer, Sport Trac, Mercury Mountaineer, Mazda Navajo, Ford Ranger, Ford Aerostar SUV Enthusiast Forums
Join the "Elite Explorers Today!"
Explorer4x4 Sportrucks EF Arcade Forums Elite Membership Product Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Repair - Tech - Modifications & Detailing Forums > Under the Hood > Explorer, Ranger, A/C & Heater systems HVAC
Notices
Explorer, Ranger, A/C & Heater systems HVAC Ford Explorer, Ranger, Mountaineer, Bronco II, Air Conditioning and Heating Systems.
Reply
Thread Tools
Old 06-08-2006, 10:30 AM   #1
t-roy707
reno, nv
94 xlt
Vehicle Specs
i can smell my radiator fluid
after i've been driving for about twnty minutes i can smell my radiator fluid. i have a 94 explorer. i thought maybe my thermostat was going bad so i replaced it. but i can still smell it. my temp. gauge never worked before but when i replaced the thermostat, it works now. what else could it be?
t-roy707 is offline   Reply With Quote
Sponsored Links (Less Ads)
Old 06-08-2006, 10:49 AM   #2
Rick
Admin
Pumpkin Pilot
Wayoutin, Aridzona
Rick's Avatar
'93 XL
Vehicle Specs
Heater core going bad and leaking into the passenger compartment. That's my guess if you are smelling it inside the truck. Check the carpet and it's backing material under the glove compartment for moisture.
__________________
Rick Horwitz, AB7FH "Serious Exploration's" Admin
Rick's '93/'98 Explorer
Dodge Dart 512 Resto/Race
2004 Mustang Mach 1
2003 Dodge Ram/Cummins Dually
Rick is offline   Reply With Quote
Old 06-08-2006, 11:15 AM   #3
dogfriend
Human-Animal Hybrid
Carmichael, CA
dogfriend's Avatar
'97 Sport 4x4
Vehicle Specs
^^^ What he said.
I vote for heater core leak also. If I recall correctly, there is a drain so that the coolent may drip outside, but you will be able to smell it as air flows over the heater core.
dogfriend is offline   Reply With Quote
Old 06-08-2006, 03:08 PM   #4
marragtop
balt, md
91 xlt, 92 xlt, 95 xlt
Vehicle Specs
Before pulling the core out, make sure the heater hoses at the firewall are tight and aren't cracked or split.
__________________
'88 F150 4x4
'91 Explorer XLT 4x4
'92 Explorer XLT 4x4
'95 Explorer XLT 4x4
If it don't = 16 (4x4), it ain't worth driving...
marragtop is offline   Reply With Quote
Old 06-08-2006, 04:13 PM   #5
thewishkah
Brooklyn New York
1994 explorer xlt
Vehicle Specs
I would go with heater core as well. I just replaced mine about a month ago, not a hard job at all but it would be easier with a helper holding the inlet/out let tubes while you are trying to close under the dash back up. It shouldnt of leaked into the carpet , my 94 has a drain to let it leak out the fire wall to the street. good luck, Jon
__________________
Its all fun and games, till someone gets hurt..... then it's hysterical.
thewishkah is offline   Reply With Quote
Old 06-08-2006, 04:23 PM   #6
Glacier991
EF Tranny Guru
Sacramento, CA 95827
1992 XLT
Vehicle Specs
I took the liberty to move this to the AC and HEATERs section. In the stickies at the top of this forum is a thread about replacing the heater core on a 1st Generation Explorer you will find helpful. Like others have said you more than likely have a leaky core.
Glacier991 is offline   Reply With Quote
Old 06-11-2006, 09:19 PM   #7
t-roy707
reno, nv
94 xlt
Vehicle Specs
i don't really smell it inside. its when i get out of my x and i walk around the front of the caris when i smell it. or when im at a light and i drive off i smell it come through my driver window.
Old 06-11-2006, 11:29 PM   #8
dogfriend
Human-Animal Hybrid
Carmichael, CA
dogfriend's Avatar
'97 Sport 4x4
Vehicle Specs
I would either get a shop to test with a radiator pressure tester or rent or buy a tester to test the system under pressure. You should be able to find the source of the leak under pressure.
If you smell coolent while you are driving, it still seems most likely to be the heater core, though.
Reply
Top of Page
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Search ExplorerForum
US Flag
We Support Our Troops!
Explore the site!
Contact Us
This web site is not affiliated with or endorsed by the Ford Motor Company.
Ford Explorer is a registered Trade Mark of the Ford Motor Company
The names of actual companies and products mentioned herein may be the trademarks of their respective owners.
All tips and information provided on this site by either "Serious Explorations®" or it's contributors are for use at your own risk and discretion.
Modifying the suspension on any vehicle will cause changes to it's handling characteristics.
Some modifications described within this website may void your factory warranty.
Copyright 2009 - 1996 Rick Horwitz Photography
