| Explorer4x4 | Sportrucks | EF Arcade | Forums | Elite Membership | Product Reviews | Explorer Photo Gallery |
| Notices |
| Explorer, Ranger, A/C & Heater systems HVAC Ford Explorer, Ranger, Mountaineer, Bronco II, Air Conditioning and Heating Systems. |
Thread Tools |
#1 |
EF Tranny Guru
Sacramento, CA 95827
1992 XLT
My 1st Gen Heater Core Replacement Diary
[Preamble: Ok.. I know it is no big deal, not much harder than changing a spark plug, but ya know, we all started someplace in our auto repair, and this one is a good "starter" job for a newbie mechanic.
So.... that said, here we go: Ah, summer, the time when a young man's heart turns to.... heater cores? Usually this time of year is when the AC threads start up, but a heater core failure is no respecter of seasons. If you have never had a heater core failure, they often show up in a way that scares the bejesus outta ya.... a puff of what looks like smoke appears at the vents! Whoa nellie, get out the fire extinguisher! Not. The leaks usually are so ssmall they atomize antifreeze and it shows up looking for all the world like smoke or steam. Relax, well sorta relax, you have a leaky heater core. Is all. No big deal for us 1st Gen Explorer owners, as you will see. Now the heater core is a pretty simple device, a little radiator really.... and in summer you COULD just disconnect the two hoses going to it, and using a hose connector and clamps just hook em together and wait til fall - I know, been there done that. But I decided to just go ahead and replace mine, and do a photo thread of the process. In the years I have been doing car stuff I have replaced a "few" heater cores (including this one! More on that later) and I gotta tell you... FORD hit it out of the park on the first generation Explorers in this department. It is a very easy job, 4 screws and 2 hose clamps - that's IT. No dropping the dashboard (81 Cougar, an ALL day job) or wierd contortions to get to it. Ok let's get at this task. The heater core is in a little chamber under the glovebox, and the hoses connect on the firewall just behind the glovebox, here: The "box" (if you like $5 words I think it might be properly called a plenum chamber) is in 2 "clamshell" halves.. it looks like this as it just sits there: and 4 screws hold the box together... I'll show you the first 3, the 4th is just in the back on the center hump side.. here is 1 and two and 3 These screws are 5/16's. the back most ones need something short, a 1/4 drive socket is perfect for them. There is one more I didn;t show, it is near the back. With all 4 removed it is easy to take off the front of the "box". Look at the AF in this one, think I had a leak? You will notice it has a drain so it won't leak into the passenger compartment should it fail.. nice touch! Once the front is removed, you are AT the core... (sounds like a bad sci fi movie, eh?) From the looks the leak was somewhere near centerline.... Remove the hoses (sometimes easy sometimes you need to cut them off, don't worry, you have enough extra to do that) and you have just the ends of the core tubes sticking out.. pull the core into the passenger compartment until the hose connectors clear the firewall, then down and out. EASY ! Disassembly COMPLETE ! Looking at the core, it appears this one started leaking at the top seam... upside down since it was less than 4 years old good chance of electrolysis (more on this later). The new one is more or less identical. This is a place where a helper can be nice. I did it without one, but there is nothing holding the core in place but the hoses. Reinstallation is just reverse of taking it out.. carefully up then thru the firewall. A helper can apply pressure on the core while you work the hoses on. Tighten the clamps, put the box half back on and add the 4 screws, and YOU ARE DONE ! Whoever figured this one out at FORD ought to get a bonus. Unfortunately later Explorers do not have it this easy. Now about the core. The core that went I picked up a few years at Autozone for under $20. The new one I bought at CarQuest for close to twice that. Side by side they look nearly identical. Was the Autozone one bad? Well maybe, maybe not. If a heater core fails in short order, suspect electrolysis. How to check ? Put a voltmeter probe in the antifreeze and one on the battery ground. Anything around .2 volts or higher is BAD news. I had replaced the radiator, flushed the system and added new AF since the heater core was installed, so of course it checked out ok - NOW. But, I could have had electrolysis before. So no verdict. The Carquest core was "made in the USA". We'll see. Anyway, now you can have heat in your Explorer this summer. In Minnesota it will be a blessing. Ok you guys in Florida can stop laughing now. |
| Sponsored Links (Less Ads) |
#2 |
Wannabe Elite Explorer
Germantown, TN
92 XLT
Awesome! When you replaced either of the heater cores, did you notice any debris buildup? Leaves, dust, dirt, hair, etc?
#3 |
EF Tranny Guru
1992 XLT
No nothing of that sort. Not sure with the Explorer setup if they could get in there in any event.
#4 |
New York, Wading River (that's on Long Island)
'91 Eddie Bauer
Easy, just like the old days. Too bad in many cars the are so buried. They go bad often enough that they should be as accessible as this.
Nice pics considering where you are working.
__________________
Hoffm_t@tdipower.com 1975 CJ5 with fiberglass body and 350/345Hp chevy power:bought it in '79 1985 chevy stepside pickup, 300K on the clock: Original Owner 1989 Volvo 240 295K on the clock: Original Owner the 1991 X is my newbie with 325K on the clock: bought OCT.'03 with 183K http://home.lyse.net/brox/TonyPage4.html |
#5 |
Endicott, NY
1994 XLT & 2002 Limited
Thanks Glacier. Another well explained article.
#6 |
Topeka, KS
00 V8 Mountaineer
Nice write up, i remember when mine went it scared the hell out of me, and I was even more scared when people kept telling me horror stories about replacing the heater core's in their cars, It was a big relief when I finished in 15minutes, I just with this thread had been around then.
#7 |
Humboldt, CA
93 XLT
I hate to dig up an old thread, but I just inherited a 93 that is on its 4th heater core in 6 years. This Exploer is destined to be my beater trail/beach rig. I have two quetions:
1. What could cause the heater core to keep going out? 2. What would be the consequences of not having a heater core, and just connecting the two tubes together. Winter was mentioned, but I do not live in a cold area, and I would rarely drive this rig in the Winter anyways. |
#8 |
'91 Eddie Bauer
The only thing I can imagine is Stressing the tubes during installation will cause them to fail.
Just Bypass it if you don't need it. No negative affect on the engine.
__________________
#9 |
sacremento,ca
93 eddie bauer 2 door
another good trick is to put the caps from the new hc in the old one befor you pull it out so you dont spill af all over your carpet. ( i found that out the hard way)
__________________
93 2 door eddy Bauer HP44 and Big bearing 9 and 4.88 My elite registryhttp://www.explorerforum.com/forums/...d.php?t=153392 sas thread http://www.explorerforum.com/forums/...d.php?t=165147 sas registry http://www.explorerforum.com/forums/...d.php?t=244780 |
#10 |
Richmond, VA
91 sport
This is just what I needed to see. I need to replace mine and I had bad feelings about spending a whole Saturday doing it. I may go buy a new one today. Yea ha.
#11 |
If I only had a brain...
Charlotte, NC
'92 Sport 4x4
I probably should do this also. How much do these heater-cores usually go for? $30?
__________________
#12 |
EF Tranny Guru
1992 XLT
Yeah around that. Brigrat, 4 cores that fast certainly suggests electrolysis. But this is so cheap and so easy why not flushand replace your coolant and then the heater core and be done with it for now? This is truly a 30 min job. Why be without heat for that little effort?
PS. Put a new 12 gauge wire from the engine to the battery Negative terminal while you are at it. |
#13 |
Los Angeles CA
92 XLT & 91 3000GT VR-4
Am I the only one that had issues getting my hoses to seal on to the new heater core?
I did this about 3-4 months ago and had one hell of a time getting the hoses to seal properly. I replaced the clamps with better ones the the stock ones, cranked them down nice and tight but still had leakes...I am not sure what i did to get it to stop, but it did.
__________________
1992 Ford Explorer XLT 4x4 Factory Tow Package with Trany cooler, oil cooler and 3.73 LSD rear end All stock with 190,000 on the clock and still running strong ![]() 1991 3000GT VR-4 335HP DOHC 3.0L Twin Turbo V-6
#14 |
Lynnwood, WA
'92 XLT
Glacier991, thank you for the detailed description with pictures. I just did mine last night. I was going to tackle it myself this weekend but got the help of a mechanic friend. A couple of other issues with this job: The new core's input/output tubes needed to be "adjusted" a bit so they were the right distance apart to fit thru the holes in the firewall, and we had to come up with some weatherstripping to put around the new core (the old one used foam tape, which we couldn't reuse on the new core). Also, be prepared for coolant to come gushing out for a few seconds when you remove those hoses. We also replaced the old-style hose clamps with a newer design. So nice to have this fixed so I can turn on the blower again and smell nice clean air.
#15 |
Gregory, MI
2006 Limited 4x4
2006 Explorer
What did you mean about it not being so easy on later Explorers? It looks like I might have to do this.
#16 |
Tooele,Ut
I'm changing the heater core in my 1990 Cherokee, which makes me appreciate the heater core in the early RBVs...
| Bookmarks |
| Thread Tools | |
