Ford Explorer Sport Trac Ford Ranger Mazda Navajo Mercury Mountaineer, Ford Aerostar Message Board®
Ford Explorer, Sport Trac, Mercury Mountaineer, Mazda Navajo, Ford Ranger, Ford Aerostar SUV Enthusiast Forums
Join the "Elite Explorers Today!"
Explorer4x4 Sportrucks EF Arcade Forums Elite Membership Product Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Repair - Tech - Modifications & Detailing Forums > Under the Hood > Explorer, Ranger, A/C & Heater systems HVAC
Notices
Explorer, Ranger, A/C & Heater systems HVAC Ford Explorer, Ranger, Mountaineer, Bronco II, Air Conditioning and Heating Systems.
Reply
Thread Tools
Old 06-13-2006, 10:31 AM   #1
flyncasafo
Syracuse, NY
flyncasafo's Avatar
'00 EB
Vehicle Specs
AC Compressor Questions
My AC will not blow cold. I have a 2000 EB that has never been charged. I noticed the compressor was not coming on at all when the ac was turned on. I filled the system will one can of freon and the compressor started cycling on and off. It still will not blow cold air. The pressure guage from the filling show that the system was full. Any ideas?
flyncasafo is offline   Reply With Quote
Sponsored Links (Less Ads)
Old 06-13-2006, 10:35 AM   #2
budwich
Ottawa, Ont
96 XL
Vehicle Specs
It is likely that the "less than accurate" gauge that you have (probably came with the cans... right?) isn't telling you the whole story. If you system wasn't cycling before, one can is probably not going to make it happen. Lot's of post on AC stuff both here and in the AC / heater forum.
budwich is online now   Reply With Quote
Old 06-13-2006, 10:45 AM   #3
flyncasafo
Syracuse, NY
flyncasafo's Avatar
'00 EB
Vehicle Specs
Yup, it came with the can. Do I need more freon?
Old 06-13-2006, 11:50 AM   #4
budwich
Ottawa, Ont
96 XL
Vehicle Specs
Probably but again read the stuff in the AC forum.
Old 06-13-2006, 03:58 PM   #5
ARTURPOLAND
POZNAN, POLAND
'97 HIGHCLASS
Vehicle Specs
there is a freon pressure sensor near the filling end. use a jumper wire and connect both wires of the connector wire. turn on AC. if clutch engage it means there is a problem with freon pressure. It might be lekeage but in such a case I would reccomend to go to professionals.
Archie
ARTURPOLAND is offline   Reply With Quote
Old 06-13-2006, 04:29 PM   #6
Glacier991
EF Tranny Guru
Sacramento, CA 95827
1992 XLT
Vehicle Specs
The clutch should cycle. How often is it cycling? Resist the urge to overfill the system, it will damage the compressor. If the on/off times are 2-3 times a minute you should be getting cold air.
Also you will get more help if this is in the AC forum so I am moving it there.
Glacier991 is offline   Reply With Quote
Old 06-13-2006, 09:01 PM   #7
flyncasafo
Syracuse, NY
flyncasafo's Avatar
'00 EB
Vehicle Specs
The compressor is cycling several times a minute. It will come on for about 5 seconds and then shut off. It is not blowing cold air at all.
Old 06-13-2006, 09:18 PM   #8
Glacier991
EF Tranny Guru
1992 XLT
Vehicle Specs
Ok. At 75 - 80 degrees it should cycle 2 to 3 times a minute. Every 5 seconds means the charge is low, still. Here's what I would do....
Add a little rerigerant and see how the cycling changes.... i.e. give it some refrigerant and let it run a few minutes... if more is needed add a little more in sucessive "bites" like this until your compressor is cycling like every 20 seconds or so.... as you do this monitor the vent temps.... once you get to a cycle of about 15 seconds of compressor "on" time you SHOULD be seeing cold air....or something else is wrong....
Try this and let us know how it goes.
Old 06-14-2006, 07:25 PM   #9
flyncasafo
Syracuse, NY
flyncasafo's Avatar
'00 EB
Vehicle Specs
Glacier, I am going to give your suggestion a try in the morning. I will let you know how I make out.
Thanks
Old 06-16-2006, 10:28 AM   #10
flyncasafo
Syracuse, NY
flyncasafo's Avatar
'00 EB
Vehicle Specs
I added another 12oz can and that has seemed to do the trick. Two cans total.
The compressor comes on for about 20 seconds. According to the cheap pressure guage I am only getting a very small drop in pressure when the compressor engages. Before, I had a very large drop. The air blows cold, instead of hot!
How much R134 can a empty system hold safely? How many cans?
Reply
Top of Page
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Search ExplorerForum
US Flag
We Support Our Troops!
Explore the site!
Contact Us
This web site is not affiliated with or endorsed by the Ford Motor Company.
Ford Explorer is a registered Trade Mark of the Ford Motor Company
The names of actual companies and products mentioned herein may be the trademarks of their respective owners.
All tips and information provided on this site by either "Serious Explorations®" or it's contributors are for use at your own risk and discretion.
Modifying the suspension on any vehicle will cause changes to it's handling characteristics.
Some modifications described within this website may void your factory warranty.
Copyright 2009 - 1996 Rick Horwitz Photography
