Ford Explorer Sport Trac Ford Ranger Mazda Navajo Mercury Mountaineer, Ford Aerostar Message Board®
Ford Explorer, Sport Trac, Mercury Mountaineer, Mazda Navajo, Ford Ranger, Ford Aerostar SUV Enthusiast Forums
Join the "Elite Explorers Today!"
Explorer4x4 Sportrucks EF Arcade Forums Elite Membership Product Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Repair - Tech - Modifications & Detailing Forums > Under the Hood > Explorer, Ranger, A/C & Heater systems HVAC
Notices
Explorer, Ranger, A/C & Heater systems HVAC Ford Explorer, Ranger, Mountaineer, Bronco II, Air Conditioning and Heating Systems.
Reply
Thread Tools
Old 06-21-2006, 10:11 AM   #1
dpom
Winthrop, MA
94 XLT
Vehicle Specs
AC Vacuum Pump
I am doing my first AC repair on my 94 XLT. I hooked up the gauges and there was no pressure in the system. I attempted to pull a vacuum and the gauge only went to about 19 in Hg. After closing the thumb valve the pressure stayed there for 10 minutes. I wasn't totally convince the vacuum pump is working the way it should, so I hooked the pump directly to the gauges and it pulled to 19 in Hg.
The pump works off of my air compressor at 75 psi, it should pull 29.9 in Hg. Is there something wrong with this pump? I don't hear any hissing. Should I buy/rent an electric one?
Thanks, Dave
__________________
94 XLT: Flowmaster 50 Cat back - IFab.net Cone AF - BFG ATs - Blaupunkt MP3000 - 12" Sub
dpom is offline   Reply With Quote
Sponsored Links (Less Ads)
Old 06-21-2006, 11:10 AM   #2
BrooklynBay
Aerostar Forum Moderator
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Check the CFM rating of your compressor, and compare it to the minimum CFM rating of your pump. You might have enough PSI, but not enough CFM.
BrooklynBay is offline   Reply With Quote
Old 06-21-2006, 02:54 PM   #3
dpom
Winthrop, MA
94 XLT
Vehicle Specs
The vacuum pump instructions say a constant source of 75 psi is required and the pump will consume 4.2 scfm and will pull a vacuum of 29.7 in at sea level.
The comressor says it does
6.6 scfm at 40 psi and
5.8 scfm at 90 psi
I will try raising the psi and see what happens.
__________________
Old 06-21-2006, 04:42 PM   #4
dpom
Winthrop, MA
94 XLT
Vehicle Specs
Cranked up the psi and it worked, thanks.
No whats the deal with the pressure staying at 19 in Hg after i disconnected the pump? Is it possible that the leak is so small it wouldn't cause air to come in it? I mean there has to be a leak since the system wasn't charged at all right?
I have a new accumulator but I don't want to put that on until I fix the leak right? How do I add the UV dye without replacing the accumulator?
Thanks, Dave
__________________
Old 07-07-2006, 12:45 AM   #5
Glacier991
EF Tranny Guru
Sacramento, CA 95827
1992 XLT
Vehicle Specs
My suggestion is that you pull a vacuum as best your pump can and let it sit overnight. If it stays the leak may have been some odd transient. BUT.... evacuation is not the best way to find a leak. You are only testing at atmospheric pressure.
The best way to find a leak is to put some refrigerant in the system... doesn't have to be much, the pressures will be 75 PSI or higher with a partial can in the system.... and either use a sniffer, or a black light.
Look for leaks at any place there is an O ring seal, at the compressor connections, and at the front compressor seal (hard to visualize with black light due to the pulley.) Also check out the valves, they tend to leak too... often producing a transient that seems to disappear after they have been opened and closed.
I'd suggest you put a can of dyed 134 in it and look that way first. Keep us posted.
Glacier991 is offline   Reply With Quote
Reply
Top of Page
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Search ExplorerForum
US Flag
We Support Our Troops!
Explore the site!
Contact Us
This web site is not affiliated with or endorsed by the Ford Motor Company.
Ford Explorer is a registered Trade Mark of the Ford Motor Company
The names of actual companies and products mentioned herein may be the trademarks of their respective owners.
All tips and information provided on this site by either "Serious Explorations®" or it's contributors are for use at your own risk and discretion.
Modifying the suspension on any vehicle will cause changes to it's handling characteristics.
Some modifications described within this website may void your factory warranty.
Copyright 2009 - 1996 Rick Horwitz Photography
