Ford Explorer Sport Trac Ford Ranger Mazda Navajo Mercury Mountaineer, Ford Aerostar Message Board®
Ford Explorer, Sport Trac, Mercury Mountaineer, Mazda Navajo, Ford Ranger, Ford Aerostar SUV Enthusiast Forums
Join the "Elite Explorers Today!"
Explorer4x4 Sportrucks EF Arcade Forums Elite Membership Product Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Repair - Tech - Modifications & Detailing Forums > Under the Hood > Explorer, Ranger, A/C & Heater systems HVAC
Notices
Explorer, Ranger, A/C & Heater systems HVAC Ford Explorer, Ranger, Mountaineer, Bronco II, Air Conditioning and Heating Systems.
Reply
Thread Tools
Old 06-27-2006, 08:54 PM   #1
bubbalewski
raleigh, NC
98 Sport
Vehicle Specs
Unhappy o no! a/c problem question
hey all... its getting hot here so my a/c blowing hot air is kinding getting to the point were i dont want to drive... well ok not that bad but heres the story... when i did my body lift, a hose (the one in the following picture) was cut by a belt that it came in contact with, luckily we noticed it and we went and got a couple connecting pieces along with some replacement hosing just for the cut part. I noticed my a/c blowing hot air about 2 weeks after the lift when it was hot outside and i decided to roll my windows up ( since i always ride with them down) and turn the a/c on, and sure enough it was blowing hot air... its blowing about 80 degrees. so my question is, Is it possible that since that hose was cut for over night, is that the hose the freon would have leaked out? if so, thats a plus because i can go get a can of freon from the store, and yes i no its not the best but it will hopefully do until i can get 125 dollars for a shop to do it.. and what is the right kind of that a/c recharge freon stuff i can buy? Thanks all for your help and hope i can get some quick responses since its bound to be hot again tomorrow.. heres the pic of the hose that was cut:
http://img382.imageshack.us/my.php?image=ex8dp.png
and no my ex is not that lime green... i was just messing around with the picture editor
bubbalewski is offline   Reply With Quote
Sponsored Links (Less Ads)
Old 06-27-2006, 09:04 PM   #2
Glacier991
EF Tranny Guru
Sacramento, CA 95827
1992 XLT
Vehicle Specs
Yeah your refrigerant is gone. I'll not belabor the "right" way to do it... 20-24 oz of 134A ought to get you cold IF your line repair holds.
Glacier991 is offline   Reply With Quote
Old 06-28-2006, 01:45 AM   #3
dogfriend
Human-Animal Hybrid
Carmichael, CA
dogfriend's Avatar
'97 Sport 4x4
Vehicle Specs
Quote:
Yes, and it doesn't require that you wait overnight for it to leak out. It probably was all gone within 5 or 10 minutes. :p
dogfriend is offline   Reply With Quote
Old 05-02-2007, 03:10 PM   #4
bubbalewski
raleigh, NC
98 Sport
Vehicle Specs
bump. still need this problem fixed! if i take it to a shop, whats the estimated cost i would be expecting from them?
Old 05-02-2007, 10:08 PM   #5
Glacier991
EF Tranny Guru
1992 XLT
Vehicle Specs
Probably $175 to $225 to completely evacuate and recharge would be my guess.
Old 05-02-2007, 10:28 PM   #6
dogfriend
Human-Animal Hybrid
Carmichael, CA
dogfriend's Avatar
'97 Sport 4x4
Vehicle Specs
Its been so long ago since I have had this done that I don't remember how much it cost, but they will probably charge for about an hour (or more) of labor plus the cost of the refridgerant. They may also recommend replacing the receiver/dryer.
It takes a while to pump down (evacuate) the system, but its necessary to get good cooling performance again.
Old 07-27-2007, 02:10 PM   #7
bubbalewski
raleigh, NC
98 Sport
Vehicle Specs
I was wondering if anyone could tell me if I purchase this hose - http://cgi.ebay.com/ebaymotors/ws/eB...m=140141004437 it would fix this problem.. the picture at the beginning of this thread should still work and show which hose is cut and needs to be replaced. Thanks
Old 07-27-2007, 05:53 PM   #8
shamaal
Friensdwood, Texas
91 Mazda Navajo
Vehicle Specs
I'll defer to someone else, but that looks like the hose for an expedition with the rear air conditioning. I think that's what the 'T' is for.
Does your current hose have two fittings (the ones with the red and black caps) coming off of the compressor to the condensor?
shamaal is offline   Reply With Quote
Old 07-30-2007, 05:49 PM   #9
ma96782
Vancouver, WA
'94 XLT, 4dr
Vehicle Specs
IMHO.....IF buying the "wrong" parts and returns are a concern.....don't buy mail order......buy locally. Money for shipping, often times, kills a deal really quickly.
Aloha, Mark
PS......
May '06......it was $65 (Summer special- check up) plus an additional $38 per pound of R-134a.
Another time: it was my AC hose $129, "O" rings $14, R-134a at $38 per pound, and Labor $175.
ma96782 is offline   Reply With Quote
Old 08-05-2007, 01:09 PM   #10
bubbalewski
raleigh, NC
98 Sport
Vehicle Specs
i got the hose and someone is going to help me put it in and then take it to a shop to get it evacuated and recharged.. just so i know what he's doin, what all are we goin to be havin to remove to be able to get the hose in there? thanks
Old 08-05-2007, 07:47 PM   #11
ma96782
Vancouver, WA
'94 XLT, 4dr
Vehicle Specs
It's a straight forward.....remove and replace job.
Don't forget to buy new green "o" rings.......they come in kits for a particular application. And get Nylog (ask the parts guy to get the correct one) to lube the "o" rings. Since the system is discharged.....why take a chance with a possible (leaky) old "o" ring........replace ALL of them.
Aloha, Mark
PS....since the system is open.....change the orifice tube (it's cheap) and the accumulator since it's over 5 years old and since system had been opened (it's not that expensive). Take your time replacing the "o" rings. When encountered, use two wrenches on the nuts (one to stabilize the fitting, one to remove). You may also run across a quick detach fitting......get the correct tool for this job.
When the old accumulator has been removed.......drain the oil out of it and note the amount.
The new accumulator will come with caps on the fittings, do not remove them, until you're ready to install it. AC oil (I used PAG 100) will need to be added to the accumulator prior to installation (1 oz., plus the amount measured). Once the new accumulator is in.....DON"T DELAY with the recharge of the system. Because, it's sucking moisture out of the air (even in system that has the lines re-attached). Set it up with the shop, to recharge, the day that you do the replacement.
Reply
Top of Page
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Search ExplorerForum
US Flag
We Support Our Troops!
Explore the site!
Contact Us
This web site is not affiliated with or endorsed by the Ford Motor Company.
Ford Explorer is a registered Trade Mark of the Ford Motor Company
The names of actual companies and products mentioned herein may be the trademarks of their respective owners.
All tips and information provided on this site by either "Serious Explorations®" or it's contributors are for use at your own risk and discretion.
Modifying the suspension on any vehicle will cause changes to it's handling characteristics.
Some modifications described within this website may void your factory warranty.
Copyright 2009 - 1996 Rick Horwitz Photography
