Ford Explorer Sport Trac Ford Ranger Mazda Navajo Mercury Mountaineer, Ford Aerostar Message Board®
Ford Explorer, Sport Trac, Mercury Mountaineer, Mazda Navajo, Ford Ranger, Ford Aerostar SUV Enthusiast Forums
Join the "Elite Explorers Today!"
Explorer4x4 Sportrucks EF Arcade Forums Elite Membership Product Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Repair - Tech - Modifications & Detailing Forums > Under the Hood > Explorer, Ranger, A/C & Heater systems HVAC
Notices
Explorer, Ranger, A/C & Heater systems HVAC Ford Explorer, Ranger, Mountaineer, Bronco II, Air Conditioning and Heating Systems.
Reply
Thread Tools
Old 06-30-2006, 01:57 PM   #1
daveleeander
Marietta, OH
02 XLT
Vehicle Specs
What pressure?-High side fluctuates
OK, I evacuated the system for 45 minutes after reaching 30", and let it sit for 15 and re-checked the pressure. It was holding, so I commenced to commencing. After adding a can and a half, the clutch started cycling slower, and I proceeded to put 2 & approximately 3/4 cans in (12 oz. cans). Sticker on car says 32 oz. for front air, 56 for front and rear. I wonder what is considered front and rear?. I have a rear outlet that comes out of the console, but nothing to control it other than on/off. Ford CD says 34 and 58. I'm close I think.
My pressure is 30 low side, 195 to 205 high side. The high side is pulsating. If you hold the red hose, you can feel it pulsing.
The air temp outside is 93 deg. F. The air coming out of the center vents is 40 deg. F. with the car idling and on max air. It certainly is colder than it ever has been.
Does this sound normal?
The clutch is not cycling like I thought it was supposed to.
Dave
daveleeander is offline   Reply With Quote
Sponsored Links (Less Ads)
Old 07-07-2006, 12:48 AM   #2
Glacier991
EF Tranny Guru
Sacramento, CA 95827
1992 XLT
Vehicle Specs
at 93 degrees it might not cycle. Especially without air over the condensor. I'd relax, it sounds like you are doing fine. Unless you have a separate rear cabin AC unit (with a 2nd evaporator) you did good.
Glacier991 is offline   Reply With Quote
Reply
Top of Page
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Search ExplorerForum
US Flag
We Support Our Troops!
Explore the site!
Contact Us
This web site is not affiliated with or endorsed by the Ford Motor Company.
Ford Explorer is a registered Trade Mark of the Ford Motor Company
The names of actual companies and products mentioned herein may be the trademarks of their respective owners.
All tips and information provided on this site by either "Serious Explorations®" or it's contributors are for use at your own risk and discretion.
Modifying the suspension on any vehicle will cause changes to it's handling characteristics.
Some modifications described within this website may void your factory warranty.
Copyright 2009 - 1996 Rick Horwitz Photography
