Ford Explorer Sport Trac Ford Ranger Mazda Navajo Mercury Mountaineer, Ford Aerostar Message Board®
Ford Explorer, Sport Trac, Mercury Mountaineer, Mazda Navajo, Ford Ranger, Ford Aerostar SUV Enthusiast Forums
Join the "Elite Explorers Today!"
Explorer4x4 Sportrucks EF Arcade Forums Elite Membership Product Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Repair - Tech - Modifications & Detailing Forums > Under the Hood > Explorer, Ranger, A/C & Heater systems HVAC
Notices
Explorer, Ranger, A/C & Heater systems HVAC Ford Explorer, Ranger, Mountaineer, Bronco II, Air Conditioning and Heating Systems.
Reply
Thread Tools
Old 07-16-2006, 01:57 PM   #1
bstone
Boston, MA
93 Explorer XLT 4wd 4dr
Vehicle Specs
AC recharge woes
With the help of this forum I found the Low Pressure connector. I hooked up the pressure gauge and got 0 PSI. I turned on the AC and the engine trying to get it to read something, but in the end I only got 0 PSI.
I have the recharge kits, but a friend tells me not to do this. Instead he says I must bring it in to "vaccume" the system. Is this for real? It's 104 F today and I really would like AC.
Thanks.
bstone is offline   Reply With Quote
Sponsored Links (Less Ads)
Old 07-16-2006, 03:03 PM   #2
shamaal
Friensdwood, Texas
91 Mazda Navajo
Vehicle Specs
Eventually your thread will end up un the A/C and heater subforum:
http://www.explorerforum.com/forums/...prune=-1&f=123
There are a number of stickies at the top that are highly informative and worth a night's reading.
To answer your question:
It boils down to doing it the right way and doing enough to get by.
The right way is to evacuate (vaccum) the system to remove moisture, hold vaccum for 15 minutes (check for leaks) and then fill with R134a.
If the moisture is not removed it reacts with the refrigerant to form hydrochloric acid which has a bad effect on the system.
Having said that, use of the cheapie kits assumes no leaks exist and no moisture in the system. Sometime it works and sometimes it don't. A minimum set of specialty tools to do your system is $150 - $200., free if you have A/C savvy friends and read this forum. Taking it into a servicing center costs $29 - $69. If competent you'll end up with a working system or a guess at what's wrong. Do the repair yourself and bring it back for service.
Hope this helps, feel free to ask questions.
shamaal is online now   Reply With Quote
Old 07-16-2006, 03:15 PM   #3
bstone
Boston, MA
Vehicle Specs
thank you. I do appreciate the information. I cannot tell you how valuable it is. Should I go to a regular shop or find a speciality shop?
Old 07-16-2006, 07:26 PM   #4
shamaal
Friensdwood, Texas
91 Mazda Navajo
Vehicle Specs
I am unfamiliar with the Boston area. For a routine top off, any special in the paper or at the dealer should do. As a minimum the shop should evacuate the system, hold the vacuum and charge the refrigerant. The $69 places generally include the refrigerant. The $29 places charge extra for the refrigerant and shop supplies.
If they cannot hold the vacuum or a leak is found what happens next is dependant upon the skill of the technician. As a minimum expect the accumulator to be replaced; this is good practice ($60 part and $60 labor). On top of this will be replacement of any faulty parts, o-rings, etc.
It has been my experience that, with the aid of this forum, one can replace every part of the air conditioning system and purchase the specialty tools for <$1000.
Reply
Top of Page
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Search ExplorerForum
US Flag
We Support Our Troops!
Explore the site!
Contact Us
This web site is not affiliated with or endorsed by the Ford Motor Company.
Ford Explorer is a registered Trade Mark of the Ford Motor Company
The names of actual companies and products mentioned herein may be the trademarks of their respective owners.
All tips and information provided on this site by either "Serious Explorations®" or it's contributors are for use at your own risk and discretion.
Modifying the suspension on any vehicle will cause changes to it's handling characteristics.
Some modifications described within this website may void your factory warranty.
Copyright 2009 - 1996 Rick Horwitz Photography
