| Explorer4x4 | Sportrucks | EF Arcade | Forums | Elite Membership | Product Reviews | Explorer Photo Gallery |
| Notices |
| Explorer, Ranger, A/C & Heater systems HVAC Ford Explorer, Ranger, Mountaineer, Bronco II, Air Conditioning and Heating Systems. |
Thread Tools |
#1 |
Wannabe Elite Explorer
Dover, PA
96 XLT; 97 XLT
a/c schrader valve guts
I have changed a fitting my (87 cougar) a/c that has been converted over to R134A a few years ago but the guts in the other connection are leaking/bubbling. Are the guts the same as a tire valve stem or are they different?
I put 2 12oz cans and stopped because the gauge that came in the kit showed that I was in the correct level. Today on the way home from work, the a/c didn't work very well. It blew cold and then changed to warm air and back and forth. I think that I need to add more. I didn't use a vacuum pump to evacuate the system because I don't have access to one. |
| Sponsored Links (Less Ads) |
#2 |
Friensdwood, Texas
91 Mazda Navajo
Yes, the schrader valve is like the one on tires. The core can be replaced, the autostores have kits in the A/C section. There are even tools that allow the core to be changed without discharge the system. I suspect they cost more than the refrigerant.
The R12 - R134a adapter, on the other hand, is an extension only and not sealed. They also are adjustable. |
#3 |
EF Tranny Guru
Sacramento, CA 95827
1992 XLT
I think my core replacement tools that let you change out the valve core on a fully charged system ran around $50. While the schrader valves are "like" the ones on tires, they are a slightly different size. Larger.
| Bookmarks |
| Thread Tools | |
