Ford Explorer Sport Trac Ford Ranger Mazda Navajo Mercury Mountaineer, Ford Aerostar Message Board®
Ford Explorer, Sport Trac, Mercury Mountaineer, Mazda Navajo, Ford Ranger, Ford Aerostar SUV Enthusiast Forums
Join the "Elite Explorers Today!"
Explorer4x4 Sportrucks EF Arcade Forums Elite Membership Product Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Repair - Tech - Modifications & Detailing Forums > Under the Hood > Explorer, Ranger, A/C & Heater systems HVAC
Notices
Explorer, Ranger, A/C & Heater systems HVAC Ford Explorer, Ranger, Mountaineer, Bronco II, Air Conditioning and Heating Systems.
Reply
Thread Tools
Old 07-19-2006, 02:20 PM   #1
gensic11
Have u seen my baseball?
Evansville, IN
gensic11's Avatar
1997 XLT
Vehicle Specs
A/C - This should be simple..
Ok I have asked this before, and done much searching, but to no avail. I have had a problem with my A/C for a while now. I got a new compressor like 2.5 years ago when I bought the car used.
Here is my problem..
I can hear the Compressor click on and try to cycle every 3-5 seconds. I am pretty sure the compressor is not bad. From my research on here it seems like i have "low coolant".. I know the pressure guages on the AutoZone cans aren't worth a damn according to everyone but I still put at least 2 whole cans in with no cold air to gain from it. I am doing the procedure correctly.. attached the nozzle - turned on the car, A/C to full blast and loaded in the can. I have a feeling something is clogged and is not letting the coolant to the compressor - or wherever it needs to go to end up through my vents! Has anyone had this similar problem? Do you know a cheap fix for it? I am dreading going to the dealer for them to tell me its gonna be a 500$ job when it could be much cheaper. I havent noticed any leaks or anything of that nature..
EDIT: another thing that seems to be common for my "situation" is the clogged orifice tube.. is there a write-up on where these things are and how to check them? I'm afraid if i start pulling tubes out i'm gonna damage something further..
Please help!! it's like 95degrees here and 100+ after humidity and i'm dying!! lol.
__________________
1997 XLT 4x4 v6 SOHC 86,XXXmi
Billit Grille, Rain/Bug Guards, Nerf Bars
Sony CD Player w/ 12" Sub, all new Infinity Speakers
OCU Baseball #11
http://www.oak.edu/athletics/baseball/frontpage.htm
gensic11 is offline   Reply With Quote
Sponsored Links (Less Ads)
Old 07-19-2006, 03:53 PM   #2
neverhit
AZ
97 XLT
Vehicle Specs
I just went through similar. Go buy a real manifold gauge set. I tried to rely on the 'gauge' on those cans and found out I had too much, so the system was protecting itself and shutting off.
neverhit is offline   Reply With Quote
Old 07-19-2006, 04:02 PM   #3
gensic11
Evansville, IN
gensic11's Avatar
1997 XLT
Vehicle Specs
where and how much?
__________________
OCU Baseball #11
Old 07-19-2006, 05:32 PM   #4
neverhit
AZ
97 XLT
Vehicle Specs
Kragen wanted $80, but I found one at Autozone for $45. It immediately told me what the pressure was and where it should be.
Old 07-20-2006, 09:26 AM   #5
gensic11
Evansville, IN
gensic11's Avatar
1997 XLT
Vehicle Specs
OK i went out and looked at the A/C under the hood.. everything looks to be OK except for the circular tube that you fill the freon into.. i noticed when i pulled back the "blanket" that it seemed to be rusted out and it looked a little oily around it.. i'm guessing this part has gone bad and needs to be replaced.. i'm not sure if that's the ONLY problem but that's what i saw from the looks of it.. anyone know how much this would cost to replace? i'm sure it needs to be vaccumed out and refilled and all but i DONT think my compressor is bad.. just most likely that tube piece
__________________
OCU Baseball #11
Old 07-20-2006, 10:22 AM   #6
gensic11
Evansville, IN
gensic11's Avatar
1997 XLT
Vehicle Specs
Well I guess im gonna go fork out a couple more hundred dollars and try to get my A/C fixed. I listed my symptoms above... and I will let everyone know what happens. I'm going to Midas to get my tires balanced (24.99) and they are doing an A/C diagnostic for 40$.. i guess that's not bad (37$) cheaper than what ford would diagnose for. Anyway i'll keep everyone updated to see what went wrong. Let's see how close i am . Check back here tonight around 6:30 or 7 and I should have the details and how much it's going to cost. Thanks guys
__________________
OCU Baseball #11
Old 07-20-2006, 05:57 PM   #7
Glacier991
EF Tranny Guru
Sacramento, CA 95827
1992 XLT
Vehicle Specs
That rusted out can is the accumulator. Cost between $50 and $75. You can replace it yourself, but you will need the special tool to release the fittings... a set costs around $8. I'd suggest you then take it to a shop to have it properly evacuated (not vacuumed, but evacuated) and recharged.
Glacier991 is offline   Reply With Quote
Old 07-20-2006, 07:33 PM   #8
gensic11
Evansville, IN
gensic11's Avatar
1997 XLT
Vehicle Specs
ok i just got the service done.. all they told me was that i was 2 lbs low and needed a recharge.. finally got it recharged and now it's blowing cold as hell.. wasn't too expensive either. i'm going to throw away my POS AutoZone measurer.. i am sure i have a leak somewhere.. the guy at midas told me it could be very small to big and they hooked it up to a "sniffer" and sai there were no leaks found.. so hopefully it's very small.. i just hope it stays that way.. but if not, i have about 3 months of leeway to get a free inspection if anything goes wrong.
I looked under the hood when i got back home and noticed the accumulator had a ton of persperation on it. i'm guessing its because it was so hot, and the accumulator got so cold it created the wetness.. is that correct? also i heard a hissing noise for about 15 seconds after the truck was turned off - sounded like air going through the lines.. is that normal?
__________________
OCU Baseball #11
Old 07-20-2006, 08:33 PM   #9
Glacier991
EF Tranny Guru
1992 XLT
Vehicle Specs
You are right about the condensation. In older versions the can was insulated and the moisture was causing a rusting out problem there.
The hissing is most likely the high side and low side equalizing.. that's normal.
Old 07-20-2006, 08:36 PM   #10
gensic11
Evansville, IN
gensic11's Avatar
1997 XLT
Vehicle Specs
yeah i definitely can see that it's rusting.. which is what's leading me to believe there may be a slow leak on the accumulator somewhere - i'll have to keep an eye on it i guess. i'm just glad that seems to be my only problem - which is a fairly cheap fix if it was indeed the problem.
thanks glacier!
__________________
OCU Baseball #11
Old 07-20-2006, 09:05 PM   #11
insane3082
Chicago
2000 XLT
Vehicle Specs
hmmmmm i was tyrying the same thing i know my compressor works but it seems that when i tried to fill it up it was just not doing it for me. i have the same symptoms try charging it but it feels clogged i sure hope thats my problems too cus im going crazy with this weather. i will also be reposting wether not it is the problem when i get to it
insane3082 is offline   Reply With Quote
Old 07-21-2006, 09:02 AM   #12
gensic11
Evansville, IN
gensic11's Avatar
1997 XLT
Vehicle Specs
ok let us know.. i'm interested
__________________
OCU Baseball #11
Reply
Top of Page
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Search ExplorerForum
US Flag
We Support Our Troops!
Explore the site!
Contact Us
This web site is not affiliated with or endorsed by the Ford Motor Company.
Ford Explorer is a registered Trade Mark of the Ford Motor Company
The names of actual companies and products mentioned herein may be the trademarks of their respective owners.
All tips and information provided on this site by either "Serious Explorations®" or it's contributors are for use at your own risk and discretion.
Modifying the suspension on any vehicle will cause changes to it's handling characteristics.
Some modifications described within this website may void your factory warranty.
Copyright 2009 - 1996 Rick Horwitz Photography
