Ford Explorer Sport Trac Ford Ranger Mazda Navajo Mercury Mountaineer, Ford Aerostar Message Board®
Ford Explorer, Sport Trac, Mercury Mountaineer, Mazda Navajo, Ford Ranger, Ford Aerostar SUV Enthusiast Forums
Join the "Elite Explorers Today!"
Explorer4x4 Sportrucks EF Arcade Forums Elite Membership Product Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Repair - Tech - Modifications & Detailing Forums > Under the Hood > Explorer, Ranger, A/C & Heater systems HVAC
Notices
Explorer, Ranger, A/C & Heater systems HVAC Ford Explorer, Ranger, Mountaineer, Bronco II, Air Conditioning and Heating Systems.
Reply
Thread Tools
Old 07-21-2006, 12:20 AM   #1
vlm2
Marshall Mo
1997 Explorer Sport
Vehicle Specs
Unhappy AC HELPPPP 97 Explorer
The AC quit blowing cold last year, so we just used the windows untill this years. Our mechanic added some freon and run dye through the lines and couldn't find a leak. He said the stuff had a sealer in it also so if it did have a leak it should check it. SO anyway the air worked great for a while, now it still blows semi cool air but no where near cold.I had it check and it is still full.The air temp it blows is about 68 or 70 degrees.
PLEASE TELL ME WHAT TO DO Temps here are at 100 degrees with indexs of 110 .
Thanks
Vicky
vlm2@socket.net
vlm2 is offline   Reply With Quote
Sponsored Links (Less Ads)
Old 07-21-2006, 01:52 AM   #2
Glacier991
EF Tranny Guru
Sacramento, CA 95827
1992 XLT
Vehicle Specs
You had it checked and it still full ? Sounds to me like a small leak....resulting in a low charge state. Show said it was still "Full". This is not like checking tire pressures.It is full of variables. I', betting you are just in a low charge state. How frequently is the compressor clutch cycling ?
Glacier991 is offline   Reply With Quote
Old 07-21-2006, 04:03 AM   #3
vlm2
Marshall Mo
1997 Explorer Sport
Vehicle Specs
It wouldn't take anymore freon. That is why I say it is still full.The man at the automotive store checked it and tried to put more in and it would take any more. I even paid 10.00 for some booster stuff that was to make it even colder but it only helped a weeeeeee bit.
Tell me more please.
Vicky
Old 07-21-2006, 04:58 AM   #4
rookieshooter
Martinsburg WV
rookieshooter's Avatar
84 Bronco II & trailer
Vehicle Specs
You need to take it to someone who has a set of gauges and knows how to use them. They need to take some readings on the high side and low side while it is running and not just dummping more refregeant in the system. Those reading can tell you alot on what's happening. Is there a difference between low and high pressure or are they equalized? Bad valves in the compressor? Too high or too low. And if you take the reading right after running and the engine is off it will always show to high. Bet you got a slow leak if it did work for awhile after charging and then slowly got worse.
__________________
84' Bronco II All Tricked-Up with built Coilovers all 4 corners, with matching 84 trailer.
Petersen's 4Wheel mag ROTM. Voted 2008 Bronco II of Year
Quoted from not turbo...
Quote:
you just look at your stuff one day and say "Golly, what if...? and then get the sawz-all out
rookieshooter is offline   Reply With Quote
Old 07-21-2006, 09:45 AM   #5
Homerexplorer
Upstate NY
99 XLT 4WD
Vehicle Specs
Is the clutch engaging? Is the compressor getting warm/hot?
Homerexplorer is offline   Reply With Quote
Old 07-21-2006, 10:16 AM   #6
gensic11
Have u seen my baseball?
Evansville, IN
gensic11's Avatar
1997 XLT
Vehicle Specs
Quote:
i agree with rookieshooter - i tried using the "cheapo" guages at autozone and it was telling me i couldn't fill anymore freon into the system.. but then i finally grabbed some balls and took my truck to midas and they told me i was 2lbs low and so they recharged and wallah i have cold air again. Check your Accumulator (it's the tube looking thing that you filled your freon into at the auto store).. there should be a "blanket" around the tube. if you pull that blanket back you will probably see a lot of rust. this may be the source of your problem.. look into getting the accumulator replaced if you think it looks pretty bad. i know it's about a 50-70$ piece and fairly easy replacement if you have the right tools. i will probably have to get mine replaced within the next year if my newly charged A/C stops working again..
__________________
1997 XLT 4x4 v6 SOHC 86,XXXmi
Billit Grille, Rain/Bug Guards, Nerf Bars
Sony CD Player w/ 12" Sub, all new Infinity Speakers
OCU Baseball #11
http://www.oak.edu/athletics/baseball/frontpage.htm
gensic11 is offline   Reply With Quote
Old 07-21-2006, 08:24 PM   #7
vlm2
Marshall Mo
1997 Explorer Sport
Vehicle Specs
OK,I will make an appointment with Midas.I have no idea about the highs and lows or the Accumulator, but I will look for it.kEEP THE IDEAS COMING I AM STILL SWEATING.
YOU GUYS ARE GREATTTTTTTT
VICKY
Reply
Top of Page
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Search ExplorerForum
US Flag
We Support Our Troops!
Explore the site!
Contact Us
This web site is not affiliated with or endorsed by the Ford Motor Company.
Ford Explorer is a registered Trade Mark of the Ford Motor Company
The names of actual companies and products mentioned herein may be the trademarks of their respective owners.
All tips and information provided on this site by either "Serious Explorations®" or it's contributors are for use at your own risk and discretion.
Modifying the suspension on any vehicle will cause changes to it's handling characteristics.
Some modifications described within this website may void your factory warranty.
Copyright 2009 - 1996 Rick Horwitz Photography
