Ford Explorer Sport Trac Ford Ranger Mazda Navajo Mercury Mountaineer, Ford Aerostar Message Board®
Ford Explorer, Sport Trac, Mercury Mountaineer, Mazda Navajo, Ford Ranger, Ford Aerostar SUV Enthusiast Forums
Join the "Elite Explorers Today!"
Explorer4x4 Sportrucks EF Arcade Forums Elite Membership Product Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Repair - Tech - Modifications & Detailing Forums > Under the Hood > Explorer, Ranger, A/C & Heater systems HVAC
Notices
Explorer, Ranger, A/C & Heater systems HVAC Ford Explorer, Ranger, Mountaineer, Bronco II, Air Conditioning and Heating Systems.
Reply
Thread Tools
Old 07-21-2006, 03:44 PM   #1
uh60james
Fayetteville, NC
'93 Sport (Dora), '06 XLT
Vehicle Specs
Does the A/C actually cause poorer gas mileage?
When turning the A/C on at idle I notice a rise in RPM's, however when driving along at 65mph I can turn the A/C and the tachometer will not move at all, the same thing goes for turning the A/C off while at speed. This leads me to believe that the only time the A/C affects gas mileage is when sitting at idle at a stop light, parked with A/C on, etc. Anyone know if this is true or not?
uh60james is offline   Reply With Quote
Sponsored Links (Less Ads)
Old 07-21-2006, 04:15 PM   #2
410Fortune
ELITE BRONCO2ERER
Crawlorado
410Fortune's Avatar
B2 Mod
Vehicle Specs
yes
when the clutch on the ac compressor locks in the pulley is no longer free wheeling, it def robs some power (or more like takes power to turn)
the rpm's only move at idle because the computer adjsuts for the added drag you just put on the serpentine system.
Any pulley on that belt will use some potential power, if that pulley is used to pump or generate it will take even a bit more.
__________________
96 Explorer daily driver build-1996 XLT 5.0L AWD to 4x4 conversion complete on 33's
88 BII 5.0L conversion - BII 5.0l drivetrain thread
My Bronco II - 1988 Bronco II 4x4 V8 on 35's - registry and updates
410Fortune is offline   Reply With Quote
Old 07-21-2006, 08:27 PM   #3
shamaal
Friensdwood, Texas
91 Mazda Navajo
Vehicle Specs
At the lower RPM not enough energy is stored in the flywheel. When the compressor clutch kicks on, the PCM senses this and ups the rpm at the idle speeds. At higher rpm there is sufficient inertia that the rpms don't noticably drop on the tach. At WOT the compressor clutch opens.
As 410 says, yes, any accessory extracting power from the engine is preventing that power from reaching the drive train.
shamaal is offline   Reply With Quote
Old 07-21-2006, 10:05 PM   #4
KPT
Elite Drunk
NC
KPT's Avatar
'95 XL 4x4
Vehicle Specs
Quote:
WTF? Flywheel has zero to do with the ac compressor, they are on opposite side of the engine. Flywheel doesn't store energy either.
I loose 1.5-2 MPG with the ac on.
When I turn the ac on at idle, the RPM's will rise slightly and then drop back down to normal.
KPT is offline   Reply With Quote
Old 07-21-2006, 10:10 PM   #5
aldive
Sarasota, Florida
aldive's Avatar
1999 XLT
Vehicle Specs
Quote:
I loose no MPG with the AC on during highway driving.
__________________
Al Franklin
My truck
My Quest for 30
aldive is offline   Reply With Quote
Old 07-21-2006, 10:17 PM   #6
Rick
Admin
Pumpkin Pilot
Wayoutin, Aridzona
Rick's Avatar
'93 XL
Vehicle Specs
Sure about that??
Quote:
A flywheel is a heavy rotating disk used as a storage device for kinetic energy. They come as an alternative energy storage device. Flywheels resist changes in their rotational speed, which helps steady the rotation of the shaft when an uneven torque is exerted on it by its power source such as a piston-based, (reciprocating) engine, or when the load placed on it is intermittent (such as a piston-based pump). Flywheels can also be used by small motors to store up energy over a long period of time and then release it over a shorter period of time, temporarily magnifying its power output for that brief period. Recently, flywheels have become the subject of extensive research as power storage devices; see flywheel energy storage.
A momentum wheel is a type of flywheel useful in satellite pointing operations, in which the flywheels are used to point the satellite's instruments in the correct directions without the use of thrusters.
The kinetic energy stored in a rotating flywheel is
E = \frac{1}{2} I \omega^2
where I is the moment of inertia of the mass about the center of rotation and ω (omega) is the angular velocity in radian units. A flywheel is more effective when its inertia is larger, as when its mass is located farther from the center of rotation either due to a more massive rim or due to a larger diameter. Note the similarity of the above formula to the kinetic energy formula E = mv2/2, where linear velocity v is comparable to the rotational velocity, and the mass is comparable to the rotational inertia.
The flywheel has been used since ancient times, the most common traditional example being the potter's wheel. In the Industrial Revolution, James Watt contributed to the development of the flywheel in the steam engine, and his contemporary James Pickard used a flywheel combined with a crank to transform reciprocating into rotary motion.
__________________
Rick Horwitz, AB7FH "Serious Exploration's" Admin
Rick's '93/'98 Explorer
Dodge Dart 512 Resto/Race
2004 Mustang Mach 1
2003 Dodge Ram/Cummins Dually
Rick is offline   Reply With Quote
Old 07-21-2006, 10:20 PM   #7
uh60james
Fayetteville, NC
Vehicle Specs
Quote:
Thats what I assumed to be true. It only affects idle consumption.
Old 07-21-2006, 10:25 PM   #8
Rick
Admin
Pumpkin Pilot
Wayoutin, Aridzona
Rick's Avatar
'93 XL
Vehicle Specs
Quote:
I don't believe that's possible. The A/C compressor has two modes. One with the clutch disengaged and one with it engaged. There is NO WAY that the compressor requires the same HP to drive an engaged compressor as it does to turn the freewheeling pulley on the end of the compressor. The engine will use more fuel and you will have less available HP at the rear wheels with the compressor simple physics.
__________________
2004 Mustang Mach 1
Old 07-21-2006, 10:52 PM   #9
KPT
Elite Drunk
NC
KPT's Avatar
'95 XL 4x4
Vehicle Specs
I stand corrected. The flywheel does store some energy. It is more of a issue on smaller engines. The flywheel has stored enough energy at low rpm's though. If it did not, the engine might possibly stall when you turned the compressor on at idle.
And yes you will lose MPG with the ac on at highway speeds. It is less than around town driving, but it is still at least 1 mpg.
Old 07-22-2006, 12:15 AM   #10
aldive
Sarasota, Florida
aldive's Avatar
1999 XLT
Vehicle Specs
I beg to differ. I have tested this many times.
__________________
Al Franklin
My truck
My Quest for 30
Old 07-22-2006, 12:22 AM   #11
Rick
Admin
Pumpkin Pilot
Wayoutin, Aridzona
Rick's Avatar
'93 XL
Vehicle Specs
Physics fail to apply to your vehicle Al?
__________________
2004 Mustang Mach 1
Old 07-22-2006, 12:31 AM   #12
gensic11
Have u seen my baseball?
Evansville, IN
gensic11's Avatar
1997 XLT
Vehicle Specs
study has shown it does affect MPG but it's very minimal (as long as there are no other variables).. windows down cause an aerodynamic drag that's almost worse than having a/c on..
__________________
1997 XLT 4x4 v6 SOHC 86,XXXmi
Billit Grille, Rain/Bug Guards, Nerf Bars
Sony CD Player w/ 12" Sub, all new Infinity Speakers
OCU Baseball #11
http://www.oak.edu/athletics/baseball/frontpage.htm
gensic11 is offline   Reply With Quote
Old 07-22-2006, 01:25 AM   #13
Glacier991
EF Tranny Guru
Sacramento, CA 95827
1992 XLT
Vehicle Specs
I have read a study somewhere that showed the aerodynamic drag by windows down was a greater energy robber than AC with the windows up. I'll see if I can find it... but I swear I read that somewhere. Doesn't make it TRUE, but it looked legit to me.
Glacier991 is offline   Reply With Quote
Old 07-22-2006, 01:52 AM   #14
Rick
Admin
Pumpkin Pilot
Wayoutin, Aridzona
Rick's Avatar
'93 XL
Vehicle Specs
Mythbusters tried it and the vehicle with windows down got better economy than the vehicle with the A/C on and windows up. Their test used identical vehicles with the fuel line attached to a graduated cylinder filled with fuel. Others have mentioned that Mythbusters tested at 40mph and that the drag from rolled down windows wouldn't become apparent until 50mph or greater.
However if you are just testing the parasitic effect of the A/C compressor at highway speed you would need to run the no A/C test with the windows rolled up to eliminate that variable.
__________________
2004 Mustang Mach 1
Old 07-22-2006, 02:09 AM   #15
Glacier991
EF Tranny Guru
1992 XLT
Vehicle Specs
I've been a pilot for almost 40 years, so have had an interest in things aerodynamic for a long time. I had a college buddy studying to be an Aerodynamic engineer. I learned a lot of neat stuff through him as a result of my interest and his chosen field. I was very interested in parasitic drag and icing potentials related thereto. One thing I remember learning was that parasitic drag does not really start to mean much until a certain airspeed is reached, and it increases exponentially thereafter (well maybe not exponentially but not linearly). 40 MPH is not a fair test of parasitic drag from windows down on a car IMHO. I think what I read was a test done at freeway speeds. Around town I think there is no doubt AC uses more fuel than windows down. In a 500 mile interstate trip... I doubt it does. But then, what the h*ll do *I* know.
ps. it was 102 and muggy in Sacramento today. I drove around town. Wanna guess which I chose? AC or windows down?
DING DING DING we have a winner!
Old 07-22-2006, 07:00 AM   #16
aldive
Sarasota, Florida
aldive's Avatar
1999 XLT
Vehicle Specs
Quote:
This is true; I have tested it. However, only at 70 MPH in my testing.
__________________
Al Franklin
My truck
My Quest for 30
Old 07-22-2006, 07:02 AM   #17
aldive
Sarasota, Florida
aldive's Avatar
1999 XLT
Vehicle Specs
Quote:
Originally Posted by Rick
However if you are just tneedesting the parasitic effect of the A/C compressor at highway speed you would to run the no A/C test with the windows rolled up to eliminate that variable.
That is exactly how I have evaluated it.
__________________
Al Franklin
My truck
My Quest for 30
Old 07-22-2006, 08:52 AM   #18
Homerexplorer
Upstate NY
99 XLT 4WD
Vehicle Specs
Glacier991 is correct - drag is nearly linear at low speeds where the Drag Force is =~ -b*v, where b is a constant dependant on the fluid and v is velocity. At higher speeds, it does increase exponentially where drag force = -0.5*p*v^2*A*Cd. The v^2 indicates the exponential effect of speed on drag. I'm not sure of the transition point for an Explorer, but 40 mph definately qualifies for the high drag equation. Stick your hand out the window and this will give you an idea of how drag force changes with speed.
When the AC is on, it has to have a negative impact on gas mileage, otherwise it defies every law of physics. Whether or not one is using equipment sensative enough to detect it is another story. As we all know, the compressor has to do work in order to recompress the fluid. It gets this energy from the engine, therefore some energy that would be used to move the wheels is now going to run the compressor. Unfortunately, you can't get something for nothing - you can only use as much as you generate, no more.
Whether or not it is more efficient to run AC or have the windows open is going to depend on the vehicle drag properties and the evaluation speed. Assuming temperatures and humidity, etc. are all constant, the energy required by the compressor will be constant at all speeds (independent of speed). Drag, on the other hand, is going to increase with speed, so the net impact of having the AC on is going to decrease with speed. That's why you are going to notice a greater affect at lower speeds than highway speeds. Either way, I think most people would rather be comfortable than slightly more efficient.
Homerexplorer is offline   Reply With Quote
Old 07-22-2006, 09:30 AM   #19
aldive
Sarasota, Florida
aldive's Avatar
1999 XLT
Vehicle Specs
Quote:
Your theory is sound. The ability to measure minute changes in gas mileage would require some elaborate testing equipment. In all of my testing by the usual method of calculating gas mileage, I have not observed any difference. I have made many long 300-500 mile highway runs testing this.
Have you actually tested this?
__________________
Al Franklin
My truck
My Quest for 30
Old 07-22-2006, 09:32 AM   #20
aldive
Sarasota, Florida
aldive's Avatar
1999 XLT
Vehicle Specs
No, however real world testing does.
__________________
Al Franklin
My truck
My Quest for 30
Reply
Top of Page
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Search ExplorerForum
US Flag
We Support Our Troops!
Explore the site!
Contact Us
This web site is not affiliated with or endorsed by the Ford Motor Company.
Ford Explorer is a registered Trade Mark of the Ford Motor Company
The names of actual companies and products mentioned herein may be the trademarks of their respective owners.
All tips and information provided on this site by either "Serious Explorations®" or it's contributors are for use at your own risk and discretion.
Modifying the suspension on any vehicle will cause changes to it's handling characteristics.
Some modifications described within this website may void your factory warranty.
Copyright 2009 - 1996 Rick Horwitz Photography
