Ford Explorer Sport Trac Ford Ranger Mazda Navajo Mercury Mountaineer, Ford Aerostar Message Board®
Ford Explorer, Sport Trac, Mercury Mountaineer, Mazda Navajo, Ford Ranger, Ford Aerostar SUV Enthusiast Forums
Join the "Elite Explorers Today!"
Explorer4x4 Sportrucks EF Arcade Forums Elite Membership Product Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Repair - Tech - Modifications & Detailing Forums > Under the Hood > Explorer, Ranger, A/C & Heater systems HVAC
Notices
Explorer, Ranger, A/C & Heater systems HVAC Ford Explorer, Ranger, Mountaineer, Bronco II, Air Conditioning and Heating Systems.
Reply
Thread Tools
Old 07-25-2006, 04:13 PM   #1
LXNavajo_94
Hendersonville,NC
1994 navajo lx
Vehicle Specs
fan some times works some times doesnt
easy enough I thought it might just be a bad connection or the switch was bad I checked both connections the one on the switch and the one on the fan motor neither were loose so Im thinking that the switch is going bad is this a good assement or is there something else I need to check first
LXNavajo_94 is offline   Reply With Quote
Sponsored Links (Less Ads)
Old 07-25-2006, 06:50 PM   #2
shamaal
Friensdwood, Texas
91 Mazda Navajo
Vehicle Specs
I assume we are talkng about the blower fan. My only experience with an intermittent one involved hitting the dash or a bump and it would start up. Replacing the fan (engine compratment, firewall, passenger's side) fixed it.
shamaal is offline   Reply With Quote
Old 07-26-2006, 11:10 AM   #3
ma96782
Vancouver, WA
'94 XLT, 4dr
Vehicle Specs
I had the same problem yesterday...........so, I'm thinking:
I've had this problem before (fan won't work, switch in all positions). Last time........I left the switch on "MAX with the A/C ON"..........after driving for 10 miles or so..........it suddenly kicked on.
So, I'll put the switch "ON MAX" again...........humm......still not working.
So, I begin thinking:
It's possible that the elec. switch (bad connection) or the relay or the fan motor contact. Or bad ground or broken wire.
Perhaps, if I could test the fan? OK, I could run direct 12v see if the fan still works.
As for the switches.........I'll have to take the switch out of the dash. Then, I guess I could do an continuity test across the contacts w/ the switch in different positions.
Relay..........well KOEO........and test if I'm getting power (at both ends).
Then......it could also be that the reisistors that regulate the power (so fan can go slow, fast or very fast)..........may be burnt.........I'll have to find those resistors, first.
Wires or ground.........I'll have to test for that too.............most of the time I'm just "lucky."
Oh well.......it's working again.......so, I won't bother with it, there are a lot of other projects I'm working on.
Aloha, Mark
ma96782 is offline   Reply With Quote
Old 07-26-2006, 05:22 PM   #4
LXNavajo_94
Hendersonville,NC
1994 navajo lx
Vehicle Specs
thanks I was thinking it might just be the motor going bad mine does this some times when you hit a bump sometimes when you hit the brakes and some times when you forget to turn it off when you park today on the way home from work it didnt work at all any way Ill try testing every thing and see what comes up Ill keep you posted
Old 07-26-2006, 08:22 PM   #5
ma96782
Vancouver, WA
'94 XLT, 4dr
Vehicle Specs
Could be.......(I forgot to mention) just a bad connection. Where the wire is connected to the motor. Going over a bump or a sudden jar could be affecting the contact.
BTW.....it happened again, today. This happened just after spending a $390 to get the A/C fixed.
I'd be concerned if it didn't work for a week straight. Right now, I got a lot of other things to be worried about.
Aloha, Mark
Old 07-29-2006, 02:29 AM   #6
ma96782
Vancouver, WA
'94 XLT, 4dr
Vehicle Specs
It's working again............fixed itself.........just driving around.
Haynes Manual has a step by step check.....................Chapt 3........Titled:
Heater and air-conditioning blower motor and circuit check.
Aloha, Mark
Old 07-29-2006, 07:44 AM   #7
JDraper
Thirsty?
McVeytown, PA
JDraper's Avatar
'05 SCrew
Vehicle Specs
Aloha, Mark
That's what mine was doing. It would work for a while, then quit. I'd drive around and it would just turn itself back on. It got progressively worse to the point I decided to do something about it, and it was the relay overheating and refusing to work.
__________________
Moderator..Home Improvement/Explorer 911
You took my breath away....and now I want it back....
'66 Mustang Coupe, '04 Mustang Mach 1, '05 F-150 Lariat SCrew, '08 Focus
"Ex"plorer's: '92 Sport, '94 Sport, '01 XLS
Our Crappy Website
JDraper is offline   Reply With Quote
Old 07-30-2006, 09:51 PM   #8
ma96782
Vancouver, WA
'94 XLT, 4dr
Vehicle Specs
JDraper,
You mean the relay under the hood? Power Distrubution Box...Heater/Blower relay #28?
Aloha, Mark
Old 07-31-2006, 07:31 AM   #9
JDraper
Thirsty?
McVeytown, PA
JDraper's Avatar
'05 SCrew
Vehicle Specs
JDraper,
Aloha, Mark
Yes. That's the one that was fried in my truck...Blower randomly turned on and off (worked more often on lower settings than higher settings). I could tap the relay and change the behavior of the blower. New relay=smooth fan operation.
__________________
Our Crappy Website
Old 08-01-2006, 03:45 PM   #10
Grovebaby
Suffield, ct
91 xlt
Vehicle Specs
I think I'm having the same problem on my 91 xlt. Where would I find that relay?
Grovebaby is offline   Reply With Quote
Old 08-01-2006, 05:06 PM   #11
Jason94sport
South FL
94 XLT Auto ----Sold
Vehicle Specs
Yeah that's it. Heater/Blower relay. Mine had the same problem & a new relay for $9.99 from Ford fixed it. It's located in the under hood fuse box. It's labled.
__________________
1994 XLT 4X4--- Sold
Jason94sport is offline   Reply With Quote
Old 08-02-2006, 01:53 PM   #12
netmovements
PHL, PA
'97 Mountianeer
Vehicle Specs
A/C only blows cold sometimes, ususally only blows hot air.
Been to the shop several times, no luck. They said it wasn't a pressure issue, or bad compressor. They thought it might be a switch, but ordered it 3 times and either never got the right one in, or it never did the trick. I eventually had to just pick up the truck before they figured it out. Any ideas? Not sure if i'm posting in the correct spot, but this thread seemed pretty close?
netmovements is offline   Reply With Quote
Old 08-02-2006, 04:13 PM   #13
Lt.Jim
Elite Doglegs
South Central Pennsylvania/NorthernMaryland
Lt.Jim's Avatar
94 XLT
Vehicle Specs
Quote:
This sounds more like a blend door issue. Try doing a search on that and see. Here is a link to the blend door repair thread. http://www.explorerforum.com/forums/...+door+fix+pics
__________________
"Stupidity does not discriminate! It affects everyone!"
"You don't have to be crazy to work here but it helps"
http://www.cardomain.com/ride/862362
http://www.myspace.com/sirronkcuhc
Lt.Jim is offline   Reply With Quote
Old 08-02-2006, 04:24 PM   #14
ma96782
Vancouver, WA
'94 XLT, 4dr
Vehicle Specs
Grovebaby,
On the '91.....it's different than the '94.
Per shamaal (on another thread):
Quote:
91 relay box is under distribution box
..............in the engine compartment.
Aloha, Mark
Old 08-02-2006, 09:52 PM   #15
shamaal
Friensdwood, Texas
91 Mazda Navajo
Vehicle Specs
On my 91 Mazda Navajo (and the explorers) there is a relay box underneath the power distribution box. In the relay box are the Fuel Pump, EEC Power and WOT relays (back-front). According to the Autozone schematic, there is no blower motor relay for the 91s (figure 8)
http://www.autozone.com/servlet/UiBr...3d800ba9c7.jsp
If some one has a real factory manual it could be verified.
When my blower motor went bad, it would work whenever I went over a bump, slammed the door or banged on the dash. Replacing it fixed all the problems.
Old 08-03-2006, 02:44 AM   #16
ma96782
Vancouver, WA
'94 XLT, 4dr
Vehicle Specs
OK..........I should have added that "I COULD BE WRONG......AS I DON'T OWN A '91 EXPLORER."
I apologize, Shamaal (and to Grovebaby).....for any mis-understanding to have caused.
____________________________
But, you may wanna also, look at the thermo limiter and blower resistors......before condeming the blower motor.
Aloha, Mark
PS..........on my Chevy, it (blower motor) didn't work at all, switched in any position, or going over "rough roads," or "slamming the door", even tried the direct wire test. The direct wire test, was for me, the deciding factor to get a new blower motor. Anyway, I did as Shamaal did.
I just replaced the blower motor........and viola........it worked.
Changing a motor of course (most of the time) is more expensive than a relay.
Old 08-05-2006, 10:18 PM   #17
LXNavajo_94
Hendersonville,NC
1994 navajo lx
Vehicle Specs
My relay was bad. I replaced it today fan works like a brand new one now. Parts were 8.99 plus tax at local parts shop. Took me like 2 minutes to replace it. for those that have a 94 its number 28 in the relay box. Thanks for all the help.
Old 08-06-2006, 05:25 PM   #18
ma96782
Vancouver, WA
'94 XLT, 4dr
Vehicle Specs
Good to hear that it's fixed.
Aloha, Mark
Old 08-15-2006, 02:50 PM   #19
mfg3502
Buffalo,NY
1996 xlt
Vehicle Specs
I have a 96 with the exact same problem.Is the relay location the same for a 96 as for a 94.It was quoted as "Power Dist. box-Heater/blower relay #28".Looked under the hood didn't see the same set-up.Any help would be greatly appreciated.I'm in north-east going to start getting cold pretty soon.
mfg3502 is offline   Reply With Quote
Old 08-15-2006, 03:12 PM   #20
ma96782
Vancouver, WA
'94 XLT, 4dr
Vehicle Specs
The quote, "Power Dist. box-Heater/blower relay #28," was for my '94 Explorer.
Now.............."I COULD BE WRONG......AS I DON'T OWN A '96 EXPLORER."
Your location and number on the relay.............would/might/will.............be different.
I would guess that the set up is different.................though, the relay would probably "look similar." (After checking out the parts page on RockAuto.Com) So, that being said.............look on your wiring diagram.............it would possibly be described using, "similar terms." Then, trace the wires............to the relay.
Wire diagrams are available online at Auto Zone's site.
Aloha, Mark
Reply
Top of Page
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Search ExplorerForum
US Flag
We Support Our Troops!
Explore the site!
Contact Us
This web site is not affiliated with or endorsed by the Ford Motor Company.
Ford Explorer is a registered Trade Mark of the Ford Motor Company
The names of actual companies and products mentioned herein may be the trademarks of their respective owners.
All tips and information provided on this site by either "Serious Explorations®" or it's contributors are for use at your own risk and discretion.
Modifying the suspension on any vehicle will cause changes to it's handling characteristics.
Some modifications described within this website may void your factory warranty.
Copyright 2009 - 1996 Rick Horwitz Photography
