Ford Explorer Sport Trac Ford Ranger Mazda Navajo Mercury Mountaineer, Ford Aerostar Message Board®
Ford Explorer, Sport Trac, Mercury Mountaineer, Mazda Navajo, Ford Ranger, Ford Aerostar SUV Enthusiast Forums
Join the "Elite Explorers Today!"
Explorer4x4 Sportrucks EF Arcade Forums Elite Membership Product Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Repair - Tech - Modifications & Detailing Forums > Under the Hood > Explorer, Ranger, A/C & Heater systems HVAC
Notices
Explorer, Ranger, A/C & Heater systems HVAC Ford Explorer, Ranger, Mountaineer, Bronco II, Air Conditioning and Heating Systems.
Reply
Thread Tools
Old 07-26-2006, 06:03 PM   #1
Phantom5.0
Spokane, WA
'00 Limited 5.0
Vehicle Specs
A grand later and still warm!
First off- thanks to those that helped me the other day. I was stuck in Seattle with a smoked compressor.
Had a dealer (only people with an open schedule!!) replace the compressor/clutch, orifice tube, and drier. They flushed the system twice and recharged and retested.
Sent me on my way.
I discovered about halfway back to Spokane that my compressor clutch engages and disengages about once every three seconds. But only with engine speeds over 1k. If the motor is idling, it'll run all day, but the second the revs get up over about 1200, it disengages, and about 3 sec later, engages for about 2-3 sec.
SO- I talked to the dealer again- was told to replace the pressure switch. I did that yesterday. No change.
I've now spent over $1100 on this whole thing and have warm air. I had a perfectly fine system a week ago- now all the components are new, and the air sucks!
Do you think I have a leak they didn't find, or did they maybe not recharge it correctly?
Should I go back to a Ford dealer since they will "warranty" the work they did- and wait four more days to do it while it's 95+ here, or say screw it and go somewhere else to have it checked and/or recharged?
Phantom5.0 is offline   Reply With Quote
Sponsored Links (Less Ads)
Old 07-26-2006, 08:15 PM   #2
410Fortune
ELITE BRONCO2ERER
Crawlorado
410Fortune's Avatar
B2 Mod
Vehicle Specs
either you have a leak and your refrigerant has seeped out or they simply did not put enough refrigerant into the system.
__________________
96 Explorer daily driver build-1996 XLT 5.0L AWD to 4x4 conversion complete on 33's
88 BII 5.0L conversion - BII 5.0l drivetrain thread
My Bronco II - 1988 Bronco II 4x4 V8 on 35's - registry and updates
410Fortune is offline   Reply With Quote
Old 07-26-2006, 09:36 PM   #3
Blee1099
Mean Moderator
Elkridge, MD
Blee1099's Avatar
91
Vehicle Specs
First thing I'd suggest doing is getting a set of R134a manifold gauges. Definately check the PSI's on the low pressure & high pressure sides.
Blee1099 is offline   Reply With Quote
Old 07-28-2006, 06:49 PM   #4
Phantom5.0
Spokane, WA
'00 Limited 5.0
Vehicle Specs
Gonna check if I have a leak- if I do, I'll fix it. If the refridgerant is low, Ford will fix it.
Old 07-28-2006, 06:56 PM   #5
410Fortune
ELITE BRONCO2ERER
Crawlorado
410Fortune's Avatar
B2 Mod
Vehicle Specs
if you have a leak and you paid for the vacuum/pressure test then it would be their fault it was not found....
__________________
Old 07-31-2006, 11:22 AM   #6
Phantom5.0
Spokane, WA
'00 Limited 5.0
Vehicle Specs
Well, I took it into Ford Sat. morning. They checked it again. It was 2/3 of a pound low. So they fixed me up and I now have cold air. And the Ford dealer that did the original work is paying for it.
Maybe I'm just noticing things a little more, but it still seems like the compressor is cycling a lot. In outside air of about 84, and the EATC set at Auto 74 it would run about 10-11 sec. both on and off. My service guy said that's a little excessive, but to keep an eye on it this week.
On the plus side, it'll freeze me out of there again.
Old 07-31-2006, 03:59 PM   #7
410Fortune
ELITE BRONCO2ERER
Crawlorado
410Fortune's Avatar
B2 Mod
Vehicle Specs
sounds normal to me, the compressors on each truck seem to vary just a bit.....on my 5.0L is comes on for like 5 seconds then goes off....repeat, on my buddies 95 (I just charged his AC for him this weekend) it stays on for about 8 second then cycles off...I think there are just many variables to have them all function the same (idle speed, coolant level, system pressure, outside temps, compressor age, etc)
__________________
Old 07-31-2006, 06:10 PM   #8
Phantom5.0
Spokane, WA
'00 Limited 5.0
Vehicle Specs
Yeah- I kinda figured there would be. I guess maybe my compressor had been going bad, 'cause I never really noticed it before. Or maybe dumping 1100 into the AC system has got me a little more conscious of what's going on.
Reply
Top of Page
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Search ExplorerForum
US Flag
We Support Our Troops!
Explore the site!
Contact Us
This web site is not affiliated with or endorsed by the Ford Motor Company.
Ford Explorer is a registered Trade Mark of the Ford Motor Company
The names of actual companies and products mentioned herein may be the trademarks of their respective owners.
All tips and information provided on this site by either "Serious Explorations®" or it's contributors are for use at your own risk and discretion.
Modifying the suspension on any vehicle will cause changes to it's handling characteristics.
Some modifications described within this website may void your factory warranty.
Copyright 2009 - 1996 Rick Horwitz Photography
