| Explorer4x4 | Sportrucks | EF Arcade | Forums | Elite Membership | Product Reviews | Explorer Photo Gallery |
| Notices |
| Explorer, Ranger, A/C & Heater systems HVAC Ford Explorer, Ranger, Mountaineer, Bronco II, Air Conditioning and Heating Systems. |
Thread Tools |
#1 |
Wannabe Elite Explorer
WHITE OAK , PA.
93XLT
blower fan just quit .
Hi , I'm New To This. I Hope Someone Can Help. We Have A 94 .the Other Day The Blower Fan Wouldn't Shut Off When I Turned Off The Ignition , Had To Use The Fan Switch . Came Out Later And Turned The Fan Switch On And The Fan Worked For A While Then Quit .checked The Fuses And They Are Good . Could This Be In The Ignition Switch ? I'm Lost .any Help Greatly Appreciated . Thanks .
| Sponsored Links (Less Ads) |
#2 |
Thirsty?
McVeytown, PA
'05 SCrew
My '94 just did the exact same thing. I had a bad relay in the relay box under the hood on the passenger's side. I could tap the relay to turn the fan on, and tap it again to turn it off.
__________________
Moderator..Home Improvement/Explorer 911 You took my breath away....and now I want it back.... '66 Mustang Coupe, '04 Mustang Mach 1, '05 F-150 Lariat SCrew, '08 Focus "Ex"plorer's: '92 Sport, '94 Sport, '01 XLS Our Crappy Website |
#3 |
WHITE OAK , PA.
93XLT
Thanks ,i'll Try That Next.
#4 |
Elite Doglegs
South Central Pennsylvania/NorthernMaryland
94 XLT
My 94 just had a similar problem. I had the a/c on full blast, Shut the truck off to go into a store, came out and turned the key to the on position and the blower was on, started the truck and no blower. Half hour later and two more stop/starts and the blower is back to normal.
__________________
"Stupidity does not discriminate! It affects everyone!" "You don't have to be crazy to work here but it helps" http://www.cardomain.com/ride/862362 http://www.myspace.com/sirronkcuhc |
#5 |
Vancouver, WA
'94 XLT, 4dr
#6 |
Elite Doglegs
94 XLT
New relay seems to have fixed the problem. Thanks Jeff!
__________________
#7 |
NC
94 EXPLORER
it worked
jdrapers idea tapping relays under passengerside hood worked thanks for the info
| Bookmarks |
| Thread Tools | |
