JOEZ33
- February 22, 2008
- The PIZZEL, FL
- 98 Eddie Bauer
I've read through most of the posts involving this random problem the SOHC engine has with a high rev at startup. Just to recap the problem, some owners will suddenly have a new problem where during a cold start (engine not warmed up) the engine starts like you have the accelerator floored, and it screams quickly to 2,000 rpms before oil pressure even shows a reading. This causes some pretty awful noises in the engine, and probably eventual damage.
About 6 months ago I had flashed my computer to a towing mode, from the previous economy mode. Suddenly it was starting with a high rev. After a week of towing, I reflashed the economy tune, and the starting was normal again. This lead me to believe it's completely 100% related to the computer, and not a vacuum leak, or IAC problem, or throttle body problem that has so far all been suspected. People have posted quite a few attempts to clean or change all these parts with absolutely no cure to the problem, they always still have a high rev at startup.
So fast forward to last month, the high rev problem showed up after an oil change, and never went away. I reflashed the computer twice, with no change at all, did not fix the problem.
Yesterday I decided to unhook the battery for the afternoon while I was at work. I reconnected the battery to drive home. When I restarted it, it did a slight rev to 1700, but not too quickly and no loud noises. Today (this morning) I started up, and it didn't even come close to revving high at all! It started completely normal, slowly went to about 1300 rpm, then dropped to 1,000 for a few min while warming up. It actually started quickly without excessive cranking, as in- the second I hit the key it was already running.
I think that quite a few other people have all had the same high rev problem start immediately after their oil was changed. Somehow the computer learns something during that first start with no oil pressure and it stores it for future start ups. This is my belief. Reflashing changes certain parameters, but does not erase everything that is learned during normal driving. (another novice belief). Unhooking the battery lets 100% of the learned variables to be deleted, and gets rid of what was causing the high rev on start up.
So since this problem is quite common on the SOHC engines, and some people don't even know they have the problem since they don't pay attention, I figured I would share the info with everyone. Hopefully it will solve everyone else's high rev on start up problem also.
JOE
JOE
