Ford Explorer Sport Trac Ford Ranger Mazda Navajo Mercury Mountaineer, Ford Aerostar Message Board®
Ford Explorer, Sport Trac, Mercury Mountaineer, Mazda Navajo, Ford Ranger, Ford Aerostar SUV Enthusiast Forums
Join the "Elite Explorers Today!"
Explorer4x4 Sportrucks EF Arcade Forums Elite Membership Product Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Repair - Tech - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Sport Trac and Sport use the 1995-2001 forum.
Reply
Thread Tools
Old 10-26-2009, 10:00 PM   #1
1tufgt
Bluegrass St.
2003 XLT Sport Trim
Vehicle Specs
Exclamation Engine dies when slowing down?
This has been happening for a year. It doesn't always do it but occasionally will on the initial start up and drive of the day and be fine the rest of the day.
I will be driving it down the road then have to come to a stop. Then when it's stopped it will die. Sometimes it surge before it dies and I have to hold the brake so it won't hit a car in front of me or put me in traffic.
Anyone had this issue? Could it have something to do with the IAC?
1tufgt is offline   Reply With Quote
Sponsored Links (Less Ads)
Old 10-27-2009, 08:03 PM   #2
xlt03
Bay Point, CA
2003 XLT 4.6 4X4
Vehicle Specs
Does it happen when you're going straight or when slight turn ( curve)? Had similar problem and had PCM flashed and no more problem. Idle speed was too low. Mines stalled out on slight right curve and usually when vehicle was not fully warmed and happens only once.
xlt03 is offline   Reply With Quote
Old 10-27-2009, 09:58 PM   #3
Premier03
Louisville, KY
2003 Mountaineer Premier
Vehicle Specs
Had the same problem recently ended up being a whole in the 90 degree vacuuming hose elbow on the top part of the engine. Ran fine when i slowed down it would hesitate and then stall.
__________________
03 Premier 4.6 V8, CAI, 6K Hids, Tinted Tails
Premier03 is offline   Reply With Quote
Old 10-28-2009, 04:39 PM   #4
yellowford
Gardner Kansas
yellowford's Avatar
02 XLS 4.0
Vehicle Specs
Quote:
But does the v6 have this same 90 degree hose I've looked for it but have came up with no luck as mine is doing the same thing as described above.
__________________
2002 Explorer brown wire mod
sold
yellowford is offline   Reply With Quote
Old 10-29-2009, 05:47 PM   #5
1tufgt
Bluegrass St.
2003 XLT Sport Trim
Vehicle Specs
No this will be on a straight shot.
I have the 4.6L V8 btw.
Old 11-01-2009, 10:31 PM   #6
1tufgt
Bluegrass St.
2003 XLT Sport Trim
Vehicle Specs
Bump..........
Old 11-04-2009, 06:49 PM   #7
1tufgt
Bluegrass St.
2003 XLT Sport Trim
Vehicle Specs
Anyone?
Old 11-04-2009, 06:57 PM   #8
clarks2001
Ashburn, Virginia
2002 Explorer Limited
Vehicle Specs
Mine occasionally stumbles when at a stop. Or when i go from reverse to drive. I am figuring its the IAC or maybe a clogged fuel filter. I plan on cleaning the IAC sometime soon and see if it helps, you may want to try that also.
clarks2001 is offline   Reply With Quote
Old 11-04-2009, 07:08 PM   #9
Premier03
Louisville, KY
Vehicle Specs
I can have a pic of it for you (the elbow) also check your intake make sure nothing is lose. Mine was lose when i installed my k&n and it would stumble at stop lights the pcm was reading to much air and was trying to control it.
Will
__________________
Old 11-04-2009, 10:27 PM   #10
Premier03
Louisville, KY
Vehicle Specs
__________________
Reply
Top of Page
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Search ExplorerForum
US Flag
We Support Our Troops!
Explore the site!
Contact Us
This web site is not affiliated with or endorsed by the Ford Motor Company.
Ford Explorer is a registered Trade Mark of the Ford Motor Company
The names of actual companies and products mentioned herein may be the trademarks of their respective owners.
All tips and information provided on this site by either "Serious Explorations®" or it's contributors are for use at your own risk and discretion.
Modifying the suspension on any vehicle will cause changes to it's handling characteristics.
Some modifications described within this website may void your factory warranty.
Copyright 2009 - 1996 Rick Horwitz Photography
