Ford Explorer Sport Trac Ford Ranger Mazda Navajo Mercury Mountaineer, Ford Aerostar Message Board®
Ford Explorer, Sport Trac, Mercury Mountaineer, Mazda Navajo, Ford Ranger, Ford Aerostar SUV Enthusiast Forums
Join the "Elite Explorers Today!"
Explorer4x4 Sportrucks EF Arcade Forums Elite Membership Product Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Repair - Tech - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo > Stock 1991 - 1994 Explorers
Notices
Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. No modification questions.
Reply
Thread Tools
Old 10-31-2009, 03:43 AM   #1
GotA94for600
Boston
94 Explorer V6, Auto
Vehicle Specs
Can I adjust the WP Pulley?
I just replaced the belt, and now there are some bad sounds, whoshing and "churing". Looking at the belt its off at the Water Pump by about a 1/4" twords the front , So can the pully be adjust ? or can anything elce be adjusted to get it back in wack.
Thanks.
__________________
Le Bon La Brute Le truand.
GotA94for600 is offline   Reply With Quote
Sponsored Links (Less Ads)
Old 10-31-2009, 08:09 AM   #2
Blacksheep Josh
Slinky+Escalator=Fun
Statesboro, GA
Blacksheep Josh's Avatar
1993 Ford Explorer XLT
Vehicle Specs
The belt is on correctly everywhere else? Just not the water pump?
__________________
"Thunder" Registry
Ask me about replacing your stock subwoofer. See what I have to say.
Blacksheep Josh is online now   Reply With Quote
Old 10-31-2009, 02:47 PM   #3
GotA94for600
Boston
Vehicle Specs
Yes its on right. Or could it be backwerd. Then again it could be that all the other pullys are out of wack.
__________________
Old 10-31-2009, 11:18 PM   #4
marragtop
balt, md
91 xlt, 92 xlt, 95 xlt
Vehicle Specs
Did you have a problem before you changed the belt? Take the belt back off and check the idler pulley.
__________________
'88 F150 4x4
'91 Explorer XLT 4x4
'92 Explorer XLT 4x4
'95 Explorer XLT 4x4
If it don't = 16 (4x4), it ain't worth driving...
marragtop is offline   Reply With Quote
Old 11-02-2009, 10:56 PM   #5
GotA94for600
Boston
Vehicle Specs
Yeah, no problems like this befor. Even taking off and putting back on the belt had no effect(x2). After doing that I noticed that the belt was out of wack on two of the pullys, the water pump and the crank shaft. The belt is off the both of them about the same, 1/4".
__________________
Old 11-03-2009, 05:40 AM   #6
marragtop
balt, md
Vehicle Specs
Are you sure you have the correct belt, and did you follow the diagram under the hood?
__________________
'88 F150 4x4
Old 11-03-2009, 02:08 PM   #7
GotA94for600
Boston
Vehicle Specs
Yes, and yes.
__________________
Old 11-04-2009, 07:18 PM   #8
GotA94for600
Boston
Vehicle Specs
Can I adjust the pullys? and if so how?
__________________
Old 11-04-2009, 07:59 PM   #9
Maniak
Moderator-Stock 91-94
Vail, Arizona
Maniak's Avatar
1992 XLT 4x4
Vehicle Specs
Short answer is no.. The water pump pulley is just bolted on. In "theory" you "could" use washers as spacers to pull the pump out some, but you should never need to do that. Something else must be wrong.
~Mark
Maniak is online now   Reply With Quote
Old 11-05-2009, 12:30 AM   #10
GotA94for600
Boston
Vehicle Specs
Ah, so I shouln't have to. Well I'm gonna go with that cus I have to drain my radiator at some point soon.
Thanks.
__________________
Reply
Top of Page
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Search ExplorerForum
US Flag
We Support Our Troops!
Explore the site!
Contact Us
This web site is not affiliated with or endorsed by the Ford Motor Company.
Ford Explorer is a registered Trade Mark of the Ford Motor Company
The names of actual companies and products mentioned herein may be the trademarks of their respective owners.
All tips and information provided on this site by either "Serious Explorations®" or it's contributors are for use at your own risk and discretion.
Modifying the suspension on any vehicle will cause changes to it's handling characteristics.
Some modifications described within this website may void your factory warranty.
Copyright 2009 - 1996 Rick Horwitz Photography
