Ford Explorer Sport Trac Ford Ranger Mazda Navajo Mercury Mountaineer, Ford Aerostar Message Board®
Ford Explorer, Sport Trac, Mercury Mountaineer, Mazda Navajo, Ford Ranger, Ford Aerostar SUV Enthusiast Forums
Join the "Elite Explorers Today!"
Explorer4x4 Sportrucks EF Arcade Forums Elite Membership Product Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Repair - Tech - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Sport Trac and Sport use the 1995-2001 forum.
Reply
Thread Tools
Old 11-04-2009, 07:05 PM   #1
youngexplorer48
Formerly Bakersfield, CA Currently Saginaw, MI
02 Eddie Bauer
Vehicle Specs
Bad idle!!!!!
I havve been looking for information on the idle problems that several of our trucks have and i cant seem to narrow it down to what is the problem and what i can do to fix it, i have cleaned the mass air and the iac valve i have the check engine light on due to the egr pressure sensor being bad but that is fixed now, theres no check engine light on, at stop lights the truck surges and feels like its going to die (it has died once or twice) and it just idles so bad, and my gas mileage has dropped drastically to about 14 or so, WHAT CAN I DO???
youngexplorer48 is offline   Reply With Quote
Sponsored Links (Less Ads)
Old 11-04-2009, 08:53 PM   #2
Limited02
Gardner, KS
'02 Limited V8
Vehicle Specs
This could be vaccum lines being cracked, maybe your COPS's going bad, 02 senors, bad spark plugs, etc. Start with the cheapest and go from there. (fuel filter, then spark plugs, etc)
Does it run fine when driving? Any hesitation during normal acceleration, WOT? Or just when you are at idle?
__________________
2002 Explorer Limited 4X4 V8 w/Flowmaster 70 and 2.5 single exhaust, EF and SCT3 tune from Hensonperformance. 1/4 mile in 15.22 at 88.47mph.
"Speed cost money, how fast do you want to go?"
Limited02 is offline   Reply With Quote
Old 11-05-2009, 08:56 AM   #3
youngexplorer48
02 Eddie Bauer
Vehicle Specs
if im just driving it it does hesitate from time to time and while at wot i kinda does what it wants because theres days where its a monster and days when its just a slug, and i probably will be changing the fuel filter today along with the plugs, and i was thinking that maybe my intake manifold seals could have gone bad because that seems to be common
Old 11-07-2009, 10:21 AM   #4
Jayness@psn
Muskego, Wisconsin
02 XLT 4.6
Vehicle Specs
i had mine happen like that. I replaced a bad coil over #5 and then #8 after plug shoot out.
Jayness@psn is offline   Reply With Quote
Old 11-07-2009, 10:39 AM   #5
cheeech
Vehicle Specs
I have had a rough idle and super rough starts on a cold morning.
Changed the upper intake plenum gaskets and fixed the problem.($4.39 w/tax)
Other areas to check....Throttlebody gasket, EGR gasket, IAT valve.
cheeech is offline   Reply With Quote
Old 11-07-2009, 11:34 PM   #6
youngexplorer48
02 Eddie Bauer
Vehicle Specs
sorry i havent said anything the passed two days ive been down with the flu for a bit, i tried to change the fuel filter but i guess the disconnect tool that i bought didnt work out too well for me i dont know if it was because it was platic but i wrestled it for about 30 minutes if not longer but its a bit funny that my mileage has gone up to 17, maybe its me driving feeling kinda crappy, but when i first got the truck i messed with that little plastic cover and i kept messing with the screw for a bit and then i did it again days later for just as long and then realized there is 2 screws for that cover, could this have damaged my iac gasket?
Old 11-08-2009, 12:18 AM   #7
Limited02
Gardner, KS
'02 Limited V8
Vehicle Specs
When using the fuel disconnect tool, I find it easiest to push the hose toward the tool while pushing the tool into it. Like say if the hose was off and then you put it on, give it an extra push on while pushing the tool into it.(make sense?) You then should feel a little snap and then the hose should pull right off. Sometimes it's easy, sometimes it's not.
Also, didn't notice if you have the V6 or V8?
__________________
Old 11-09-2009, 07:38 PM   #8
youngexplorer48
02 Eddie Bauer
Vehicle Specs
ive got a v6 and i guess i would have to try it that way, i just think i need to lift it a little higher, and did you have those 5 spoke boss wheels on your truck before
Reply
Top of Page
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Search ExplorerForum
US Flag
We Support Our Troops!
Explore the site!
Contact Us
This web site is not affiliated with or endorsed by the Ford Motor Company.
Ford Explorer is a registered Trade Mark of the Ford Motor Company
The names of actual companies and products mentioned herein may be the trademarks of their respective owners.
All tips and information provided on this site by either "Serious Explorations®" or it's contributors are for use at your own risk and discretion.
Modifying the suspension on any vehicle will cause changes to it's handling characteristics.
Some modifications described within this website may void your factory warranty.
Copyright 2009 - 1996 Rick Horwitz Photography
