| Explorer4x4 | Sportrucks | EF Arcade | Forums | Elite Membership | Product Reviews | Explorer Photo Gallery |
| Notices |
| Ford Explorer - Ranger Tires & Wheels Want to know what size tire or wheel combo will work with your Ford Explorer or Ranger based vehicle? Interested in Beadlocks or Dubs? Learn all about them here. |
Thread Tools |
#1 |
Wannabe Elite Explorer
Flint, Midland, Ann Arbor, Alpena; all in Michigan
98 Contour SVT
This is my next stage in my never ending search for a big/cheap tire for my X. I will have a 2" lift with TT and a add-a-leaf. The tire is at www.tyres1.com but the General link is http://www.generaltire.com/tire_deta...ame=GRABBER+MT
They are the General Grabber MT. Does anyone here run these? I'm not sure if they will fit. I would get the 235/85/R16. The specs are: diameter: 32.0" rim width: 6-7" tread width: 7.3" tread depth: 18/32" section width: 9.5" load capactiy:3042 lbs max inflation: 80 psi Are these going to be too wide? Usually the sizes I've been looking for were around 275/65/R16. What is the main difference betwwen these two sizes? Are these going to be thinner or wider than the BFG's? The best part is their price. Usually the R16 are a ton of $$. These are only $96.
__________________
1994 F250 powerstroke 5 speed, Stage 1 injectors, Beans elec fuel delivery, Intake/exhaust, South Bend Clutch, Tony Wildman tunes 2007 Ford 3.8L supercharged rock buggy |
| Sponsored Links (Less Ads) |
#2 |
Mesa, AZ
'97 4x4 Sport
The 235 is the width of the tire in milimeters. The next number is the aspect ratio. 85 means that the tires will have 85% of the width (235mm) above the rim and below the rim. The 16 is the rim size in inches. The tires would be 30mm narrower than the 265 tires you were looking at. However they will be about two inches taller since they have a much higher profile than the 65 have. The 265 tires calculate out to be 29.6" tall by 10.4" wide. The 235 tires calculate out to be 31.7" tall by 9.25" wide.
__________________
4.56 Powertrax No-Slip, SOHC V6, SuperChip, K&N FIPK (#57-2513-1), Borla cat-back (#14748), 2" torsion lift, 3" PA body lift (#853), Monroe Reflex shocks, 285 75R16 BF Goodrich T/A ko, 2WD mod Earnhardt Ford, Berge Ford, U-Haul ![]() My Explorer |
| Bookmarks |
| Thread Tools | |
