| Explorer4x4 | Sportrucks | EF Arcade | Forums | Elite Membership | Product Reviews | Explorer Photo Gallery |
| Notices |
| Ford Explorer - Ranger Tires & Wheels Want to know what size tire or wheel combo will work with your Ford Explorer or Ranger based vehicle? Interested in Beadlocks or Dubs? Learn all about them here. |
Thread Tools |
#1 |
Los Angeles, CA
1997 Explorer Sport
33X10.50 fit?
Would 33x10.50 fit on just s TT/ shackle lift?
-Ray
__________________
FRONT: 3" lift spindle/1.25" TT REAR: 4" trailmaster spring 32x11.50 BFG M/T 15x8 eagle 589 RS5000/ES3000 Auburm Limited Slip Ray's FORD EXPLORER MODIFICATIONS |
| Sponsored Links (Less Ads) |
#2 |
Wannabe Elite Explorer
Flint, Midland, Ann Arbor, Alpena; all in Michigan
98 Contour SVT
I would have to say no. If you did some hardcore trimming, you might be able to pull it off, but I don't think it would be worth it.
You need to be carefull. You don't want to put a big tire on and drill a bump, have the tire coil up into the wheel-well too far and fold up your sheet metal. I've seen it happen, it's not pretty. I'de say buy a high quality 32", you're only loosing 1/2" of height anyways. As for the width, I think you should be fine. I just put the metric equivalent of 32" on mine, I have the TT and add-a-leaf, with no problems at all.
__________________
1994 F250 powerstroke 5 speed, Stage 1 injectors, Beans elec fuel delivery, Intake/exhaust, South Bend Clutch, Tony Wildman tunes 2007 Ford 3.8L supercharged rock buggy |
#3 | |
Los Angeles, CA
1997 Explorer Sport
Quote:
__________________
#4 |
Roll Over Posse Recruiter
Clarksville, TN
'00 XLT 4x4
SCExplorer,
You could fit them with very minor triming as far as turning is concerned. I had my 33x12.5's on for a few days with only a t/t and shackle. But you're going to have rubbing at the top under full compression, since I had that problem with my 31's. I figure you'd need 1 - 2 more inches of body lift to clear them nicely. Or you could get some fiberglass fenders. .
#5 |
Los Angeles, CA
1997 Explorer Sport
Yah, i'm just still deciding what path to take. If i'm gonna spend the money, i want it to be good.
-Ray
__________________
#6 |
salt lake city, Utah
99 Heep TJ
SCEXPLORER
I have a set of 33 10.50 with a 2 inch body lift you would need to trim some to make them work with out a body lift you can check my home page to see my truck
__________________
99 Heep Wrangler |
| Bookmarks |
| Thread Tools | |
