| Explorer4x4 | Sportrucks | EF Arcade | Forums | Elite Membership | Product Reviews | Explorer Photo Gallery |
| Notices |
| Ford Explorer - Ranger Tires & Wheels Want to know what size tire or wheel combo will work with your Ford Explorer or Ranger based vehicle? Interested in Beadlocks or Dubs? Learn all about them here. |
Thread Tools |
#1 |
Wannabe Elite Explorer
TORONTO, ONTARIO
1998 LIMITED 4X4 SOHC
Hi everyone I'm so confused about tires because I hear one thing from here and another from there.
Well I have a stock unlifted 98 4 door limited with 235/75/15 firestones on it and i want to buy a set of bfg at ko's in 31/10.50/15 I heard this is a 6% increase in tire height and this could possibly prematurely wear out ball joints, tie rod ends, U-joints etc etc. Is this true would I need a lift to compensate for the new 31" tires or would it be fine ? Please reply ASAP as I'm looking to install new tires this week !! Thanks
__________________
1998 LIMITED SOHC 4X4 K&N DROP IN , REFLEX SHOCKS BFG ALL TERRAIN T/A KO 31X10.50X15 , 3.55 GEARING NGK G POWER PLUGS |
| Sponsored Links (Less Ads) |
#3 |
Moderator
Elite Explorer ECX Member Ellicott City, Maryland
1996 XLT
You'll be fine. I ran 32's stock on my truck. I have put add-a-leaf's in and I am still running 32's with no problem. Don't worry about it. Tons of people here have and are running 31's without a problem.
#4 |
TORONTO, ONTARIO
That makes me feel better because i really want 31 " bfg's on my truck.
One more thing to consider is that i have 15" rims and i know that the newer (2000) limiteds have 16" rims . Would having my 15" rims still be o.k. and not cause premature wear ?
__________________
#5 |
Houston, TX
'07 XLT Ironman
The stock 15" rims will be just fine. As long as you don't put 12.5" wide tires on the stock rims, the tires will wear fine. In fact, 31x10.5s are my next move on my 15 inch stock rims.
#6 |
Moderator Emeritus
Rocky Mount, Virginia
'97 & '01 XLTs
I'm running the exact tire you want on my 15" stock rims. No problems at all. Stock suspension too. They look a lot better than the stock tire size also.
__________________
~ My Mugshot1997 XLT Try not. Do. Or do not. There is no try. ~ Jedi Master Yoda |
#7 |
IL
95 Sport 4x4
yep, 31x10.50x15 will be no problem with stock 15" wheels. one of the first mods i did when i bought my truck was put on 31x11.50x15 tires, no problems at all with stock wheels, stock height, etc etc. truck looked and handled a whole lot better too.
Rick H.
__________________
95 Sport 4x4, 3.73, torsion twist/shackles, K&N FIPK, 33X12.50X15 BFG T/A, 15X8.5 Centerlines, Pro Comp ES9000 shocks, Flowmaster Force II, ARB OME Leaf Springs, 2" BODYLIFT BY MATT GRNMACHINE |
| Bookmarks |
| Thread Tools | |
