| Explorer4x4 | Sportrucks | EF Arcade | Forums | Elite Membership | Product Reviews | Explorer Photo Gallery |
| Notices |
| Ford Explorer - Ranger Tires & Wheels Want to know what size tire or wheel combo will work with your Ford Explorer or Ranger based vehicle? Interested in Beadlocks or Dubs? Learn all about them here. |
Thread Tools |
#1 |
Wannabe Elite Explorer
32's or 33's
I have a '91 sport and am going to go with a 3" trailmaster lift. Should I go with 32's or 33's??
__________________
Drive it like you stole it!!! |
| Sponsored Links (Less Ads) |
#2 |
Inverness, Fl.
'91 sport
31 or 32 if you don't want to cut.....33 you will have to trim the inner fender at the rear/bottom..
#3 |
So stock I can fit 30's, but if I lift it 3" I can only fit 32's. Am I missing something?
__________________
#4 |
Mesa, AZ
'97 4x4 Sport
Lifting it up 3" only moves it one direction, up! The bottom of the rear fender is still next to the tire, only closer with the 33s. That is the way lifts work. Just because you lift it up 3" doesn't mean you can run 3" larger tires. Your suspension also has limits, mostly dealing with widths though. For instance my 32" equivalents rub on my swaybar at full lock. I could put a 6" lift on my Explorer (unfortunately none exist for my '97) and I still couldn't get a larger tire under it without it rubbing also without doing more mods than just the lift.
__________________
4.56 Powertrax No-Slip, SOHC V6, SuperChip, K&N FIPK (#57-2513-1), Borla cat-back (#14748), 2" torsion lift, 3" PA body lift (#853), Monroe Reflex shocks, 285 75R16 BF Goodrich T/A ko, 2WD mod Earnhardt Ford, Berge Ford, U-Haul ![]() My Explorer |
| Bookmarks |
| Thread Tools | |
