| Explorer4x4 | Sportrucks | EF Arcade | Forums | Elite Membership | Product Reviews | Explorer Photo Gallery |
| Notices |
| Ford Explorer - Ranger Tires & Wheels Want to know what size tire or wheel combo will work with your Ford Explorer or Ranger based vehicle? Interested in Beadlocks or Dubs? Learn all about them here. |
Thread Tools |
#1 |
Allendale, MI
2001 Eddie Bauer V-8 AWD
tires for 16" rims
whats the biggest size that'll fit on 16" rims on a stock 95 without rubbing?
__________________
2001 Eddie Bauer 5.0L V-8 AWD 152,000 miles...K&N drop-in...P275/70R16 Dueler A/T REVO (second set..first ones lasted 98,000 miles! ), OME rear suspension, TT in front, aletzzas, white gauges, painted interior
| Sponsored Links (Less Ads) |
#2 |
houston, texas
2006 Z-71 suburban
i'm curious about this, too. i am considering some 16's and know that there aren't any in the usual 30, 31, 32" sizes. i went to the bfg website and the 265 75 16" tires measure 31.7" x 10.5" and the 265 70 16" are 30.7" x 10.7. i am pretty sure the 265 70's would fit w/o the torsion twist and shackels (which i do have), but would the 265 75's fit? it seems to me that these are actually 32x10.5, but i am concerned about the fit. i do not want to cut anything, and i don't want to have to ga with a boby lift, but if i need to, i guess i could. any assistance would be greatly appreciated.
__________________
doug moore houston, tx 06 z-71 suburban(mine) & 03 trailblazer lt 2wd(hers) 66 mustang dougs truck drmoore@houston.rr.com |
#3 |
Allendale, MI
My dad's company has a 97 Eddie bauer with the 265/70's on it without mods or rubbing, but i was thinking more in terms of like 275's? I do not know if I want to go any taller, because at full compression my 255/70's contacted the upper front wheelwells. it wa not bad, but they did rub at full compression. I was just looking for something a bit wider.
__________________
#4 |
Wannabe Elite Explorer
Phoenix, AZ
'95 Eddie Bauer
I too, am looking for new, taller tires. I installed a 3" liftkit on my 95 Eddie Bauer and wanted to installe taller tires. I currently have the stock, wich are Firestone Wilderness AT P255/70R16. Ford is recalling all the 15 and 16 inch Wilderness AT, they said they would give me $110 for each tire, if I bought them elsewhere. so here I smy oportunity to get a good deal on some tires. Any recomendations out there???
Thanks, Hector
__________________
95' Eddie Bauher 4X4, v-6 |
#5 |
Allendale, MI
I saw some 285/75 on a 2001 Sport Trac.
__________________
#6 |
Mesa, AZ
'97 4x4 Sport
I think that is the size Gerald has on his Explorer. They work out to about a 33" diameter tire.
__________________
4.56 Powertrax No-Slip, SOHC V6, SuperChip, K&N FIPK (#57-2513-1), Borla cat-back (#14748), 2" torsion lift, 3" PA body lift (#853), Monroe Reflex shocks, 285 75R16 BF Goodrich T/A ko, 2WD mod Earnhardt Ford, Berge Ford, U-Haul ![]() My Explorer |
#7 |
Allendale, MI
those won't fit under a stock truck, will they?!?!
__________________
#8 |
Allendale, MI
Robert,
In order to fit the 265/75 under your truck did you have to do the 2" lift or can I run 265/75 on my stock truck?
__________________
#9 |
Moderator
Elite Explorer ECX Member Ellicott City, Maryland
1996 XLT
I rode on 265/75R16's stock for a while. Not problems with rubbing or anything. I put in add-a-leaf's, but I didn't have to twist my bars as for some reason they were already a little higher. I am thinking about putting on a 3 inch body lift and going with a set of MT 34x11.5R16's Baja Belteds. But that would be a long time off when these 265's wear down.
#10 | |
Mesa, AZ
'97 4x4 Sport
Quote:
__________________
#11 |
Allendale, MI
I know what your saying about the rubbing ont ehy plastic. both sides of my truck have experianced that rubbing with the 255's
__________________
| Bookmarks |
| Thread Tools | |
