Ford Explorer Sport Trac Ford Ranger Mazda Navajo Mercury Mountaineer, Ford Aerostar Message Board®
Ford Explorer, Sport Trac, Mercury Mountaineer, Mazda Navajo, Ford Ranger, Ford Aerostar SUV Enthusiast Forums
Join the "Elite Explorers Today!"
Explorer4x4 Sportrucks EF Arcade Forums Elite Membership Product Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Repair - Tech - Modifications & Detailing Forums > Ford Explorer - Ranger Tires & Wheels
Notices
Ford Explorer - Ranger Tires & Wheels Want to know what size tire or wheel combo will work with your Ford Explorer or Ranger based vehicle? Interested in Beadlocks or Dubs? Learn all about them here.
Reply
Thread Tools
Old 05-28-2001, 03:53 PM   #1
Petech
New York, NY
1998 Eddie Bauer
Vehicle Specs
DOES FULL SIZE SPARE FIT??
Hi I wanted to get the 265/75R16 tires. Will that size fit in the stock spare tire location under my 1998 eddie bauer that came with the 255/70R16? Also, will there be room for me to add a receiver hitch later? THanks
Petech is offline   Reply With Quote
Sponsored Links (Less Ads)
Old 05-28-2001, 04:04 PM   #2
jimbo74
Elite Ranger
Nor*Cal
jimbo74's Avatar
98 XLT Supercab 4x2
Vehicle Specs
255/70/16=30.1"
265/75/16=31.6"
Difference of 1.5"
It should fit without a problem, with or without a hitch
__________________
My Truck
jimbo74 is offline   Reply With Quote
Old 05-28-2001, 04:07 PM   #3
Rob2000XLT
Charlotte, NC
'00 XLT
Vehicle Specs
Hey Petech,
Do you have the 265/75's on right now. They don't fit with out the torsion twist and shackles right?
__________________
2000 XLT 4dr 2wd Explorer 4.0 SOHC
Westin Safari Bar with Hella 500's and Piaa 520's
Saleen Rear Sway Bar with ES Polyeurthene Bushings
Pioneer Premier DEH-P740MP with JL Audio TR570-CX
Rob2000XLT is offline   Reply With Quote
Old 05-28-2001, 05:23 PM   #4
Petech
New York, NY
1998 Eddie Bauer
Vehicle Specs
No I don't have them on now. I am trying to decide if I should get them or not. Since they seem to fit however with only slight trimming and no suspension lift, I may get them. Thanks all for your help.
Old 05-28-2001, 11:17 PM   #5
Robert
Mesa, AZ
Robert's Avatar
'97 4x4 Sport
Vehicle Specs
The 265 75/16 should fit with very minor trimming. I had to trim about a 1 square inch piece of plastic behind my front tires. No lift was required to fit the tires. Fortuntately your '98 has more room than my '97. My '97 came with a 225 70R15 temporary spare even though it came with 255 70R16 tires. There is no way to get a larger spare under mine with my round tube hitch unless I deflate it first. My spare is already up against my hitch in two places. Your best bet is to look under yours and see if if you have about an inch of clearance around your current spare. If you do, then you should be able to fit the 265 under there. a hitch may be another story though. You might get by with a square one that goes under the bumper rather than a round tube which tucks behind the bumper.
__________________
4.56 Powertrax No-Slip, SOHC V6, SuperChip, K&N FIPK (#57-2513-1), Borla cat-back (#14748), 2" torsion lift, 3" PA body lift (#853), Monroe Reflex shocks, 285 75R16 BF Goodrich T/A ko, 2WD mod
Earnhardt Ford, Berge Ford, U-Haul
My Explorer
Robert is offline   Reply With Quote
Old 05-29-2001, 01:28 PM   #6
ACBlessing
Spokane, WA (eastern Washington state)
2000 Mercury Mountaineer
Vehicle Specs
Petech asked specifically if 265-75-16 would fit in the spare location along with a receiver hitch.
Yes on all counts. I have a 265-75-16 mounted in the spare location with room to spare plus I have the U-Haul bolt-on tubular hitch receiver as well. No problems whatsoever.
AC
__________________
ACBlessing, Spokane, WA
2000 Merc Mountaineer V8
ACBlessing is offline   Reply With Quote
Old 05-29-2001, 01:40 PM   #7
Rob2000XLT
Charlotte, NC
'00 XLT
Vehicle Specs
AC,
Do you have done the torsion twist and shackles??
And is the hitch you have the tubular on that you can barely see because it wraps in under the bumper or the one that is very visible underneath your bumper.
I think you may have been responding to a prior post of mine about 265/75/16 fitting on a stock Explorer. So do they fit without modification??
Thanks for the input,
Rob
__________________
Old 05-31-2001, 11:54 AM   #8
ACBlessing
Vehicle Specs
Yes, I have 265-75-16s all the way around. In the rear, they bolted on no problem. In the front, while I was getting the tires mounted, the guy did a slight torsion twist and shimmed the front bumper out with washers (four regular washers per bolt) instead of cutting the lower plastic. What's funny is that you can't even tell the bumper is shimmed out slightly. The torsion twist is free and the washers for the four bolts that hold the bumper on cost less that a dollar.
I was skeptical too and didn't go to a larger tire til I was positive I wouldn't have to cut anything, etc. but I'm glad I finally got over it as my ride is higher, smoother, greater on cornering etc. Ford shoulda done this at the factory.
-AC
__________________
Old 05-31-2001, 12:00 PM   #9
ACBlessing
Vehicle Specs
Ooops, about the trailer hitch...it's the nice black tubular that wraps under the bumper and looks very nice. If you want to see exactly what I have, go to UHaul.com, look up hitches for 2000 Xs and it'll show you a pict of exactly how it looks. The hitch bolts right on in 10 minutes with four bolts, no drilling.
In the rear, I ended up getting 3" add-a-leafs which leveled my ride after the torsion twist. Then, I had the Warrior 153 shackles put on (since the tire place refused to do it) and now the rear end sits slightly higher than the front, which is the look I was going for.
I can't tell you how happy I am riding higher, smoother and cornering better. I'm now seeing the girls in the espresso stands way better than before...and their rear ends are already lifted.
AC
__________________
Old 05-31-2001, 12:18 PM   #10
Dannyboy
Asian Thunder #2
Scottsdale, AZ(WI native)
Dannyboy's Avatar
91 4 do'
Vehicle Specs
Just to let everyone know. I have a 32X11.5 under my 94 which was intended for a 235/75/15 and I also have a Putnam class 3 hitch. I deflated the tire quite a bit but have a compressor on board. This is like 4" larger than stock.
Dannyboy is offline   Reply With Quote
Reply
Top of Page
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Search ExplorerForum
US Flag
We Support Our Troops!
Explore the site!
Contact Us
This web site is not affiliated with or endorsed by the Ford Motor Company.
Ford Explorer is a registered Trade Mark of the Ford Motor Company
The names of actual companies and products mentioned herein may be the trademarks of their respective owners.
All tips and information provided on this site by either "Serious Explorations®" or it's contributors are for use at your own risk and discretion.
Modifying the suspension on any vehicle will cause changes to it's handling characteristics.
Some modifications described within this website may void your factory warranty.
Copyright 2009 - 1996 Rick Horwitz Photography
