| Explorer4x4 | Sportrucks | EF Arcade | Forums | Elite Membership | Product Reviews | Explorer Photo Gallery |
| Notices |
| Ford Explorer - Ranger Tires & Wheels Want to know what size tire or wheel combo will work with your Ford Explorer or Ranger based vehicle? Interested in Beadlocks or Dubs? Learn all about them here. |
Thread Tools |
#1 |
Wannabe Elite Explorer
warrington PA
91' EXPLORER 4.0 4X4 XL
285/75/16
hey guys, happy new year... i have a 91 x 4x4 5-speed . it has a 3 inch. body lift and 2 skyjacker lift. i want 285/75/16 will they fit and do i have to change my gears
__________________
91 X 4x4 4.0 5 speed 4 door- 3" PA body lift- 2000 X 16" Alum. wheels -33x11.5R16(285x75x16) flomaster force 2 exhaust. JVC head unit 45x4, 2 MTX 12" , MTX 4oowatt amp - speed grill- clear corner lights- 5% tinted windows, k&n custom air cleaner, custom 60/40 bench set to twin buckets conversion> wish list 4:10s and perry front fenders |
| Sponsored Links (Less Ads) |
#2 |
Moderator
Huntington Beach, CA
'92 Eddie
They should fit just fine. You won't need to regear, but you will get worse gas mileage and low end power. I fit 33s on my truck with a 4" lift with no trimming. Good luck.
#3 |
Isla Vista, California
'91 XLT
A 285/75/16 is a load range D. Explorer's use a load range C. You could use these without problems, but they are a lot heavier and will make your ride a lot stiffer.
#4 |
ECX Member New Bern, NC
'95 Explorer "Expedition"
Can you expliain more about the load rating to me? Does a 265/75/16 have the same rating?
__________________
1995 Explorer "Expedition" 4.0 4x4 1987 Bronco II XLT 2.9 4x4 1988 Bronco II XLT 2.9 4x2 1997 Explorer XLT 5.0 4x2 My Truck |
#5 |
'91 XLT
The load range has to do with how much weight a tire can hold. Explorers, and most small SUV's, use a load range C tire because it has relativly soft sidewalls for a comfortable ride. Bigger trucks, like and F-250 use load range D, and sometimes E tires to hold more weight. The load range is determined by how many plys the tire has. For example, a C is 2 ply, a D is 4 ply. My dad's new F-550 has load range G tires that have 14 plys. They are extremely stiff but the truck has a GVW of over 17,000 lbs.
#6 |
'91 XLT
I forgot. I know that Michelin LTX AT is a D, but I don't know about other brands. My dad had them o his F-250 for while so that I how I know.
#7 |
Mesa, AZ
'97 4x4 Sport
It depends on the size, not the tire for load range. My Michelin LT26575R16 LTX AT tires are load range C, The LTX ATs come in load ranges from C-E according to their catalog for the LT version. They also make 3 P series sizes of the LTX ATs of a lower load range.
__________________
4.56 Powertrax No-Slip, SOHC V6, SuperChip, K&N FIPK (#57-2513-1), Borla cat-back (#14748), 2" torsion lift, 3" PA body lift (#853), Monroe Reflex shocks, 285 75R16 BF Goodrich T/A ko, 2WD mod Earnhardt Ford, Berge Ford, U-Haul ![]() My Explorer |
#8 |
'91 XLT
Your right. I remember seing a C 265-75. But I have never seen a 285/75 that was a C. My uncle and 2 of my cousins have them on there trucks (all of which are different brands) and 2 of them are D's and one is an E. So some tires have an option of load range, but the 285 is not a C.
#9 |
Mesa, AZ
'97 4x4 Sport
Probably due to Michelin being considered more of a luxery type tire maker than an off-road tire maker. BFG TA KO in a 265 75R16 tire is a load range D as opposed to the LTX AT which is a load range C. I never noticed that before. It looks like if I do decide to go up to a 285 75R16 tire when my current ones wear out, I will have to get the load range D tire.
__________________
#10 |
AZ
1995 Explorer Expedition
285s
Going to the D is not bad as it can make up in stiffer sidewall what you lose in handling with a taller tire vs a shorter tire with a softer sidewall.
I went from 30" to 32" to 32.8 with the 285s and the 285s actually gave me better handling on the highway than the 30" tires did. Of course the 30" tires were Firestone Wilderness tires... The 33x12.5x15s that I have been trying to cram under the truck are a little sloppier handling than the 285/75R16s. Rick
__________________
95 Explorer Expedition 3" Body Lift / 2" Suspension Lift 33x12.5/15 MTRs K&N, Flowmaster, Powertrax No-Slip, Mobil 1, Rancho, Garvin, Hella... 2008 Wrangler Unlimited Rubicon 1969 Wildcat Custom Convertible w/430ci |
#11 |
Theodore, AL
'96 XLT 5.0
Mine are Michelin LTX A/T 31x10.5-15 they have a load range of c and say the max load is 2250 and have 2 plie sidewall. I mean the load range from C to D shouldn't be all that noticeable. When i had my thornbirds ( they had a 6 plie sidewall and felt like 1/2 inch thick) the truck
felt the same except the damn vibration from the knobs. The ride was actually the same though. |
| Bookmarks |
| Thread Tools | |
