Ford Explorer Sport Trac Ford Ranger Mazda Navajo Mercury Mountaineer, Ford Aerostar Message Board®
Ford Explorer, Sport Trac, Mercury Mountaineer, Mazda Navajo, Ford Ranger, Ford Aerostar SUV Enthusiast Forums
Join the "Elite Explorers Today!"
Explorer4x4 Sportrucks EF Arcade Forums Elite Membership Product Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Repair - Tech - Modifications & Detailing Forums > Ford Explorer - Ranger Tires & Wheels
Notices
Ford Explorer - Ranger Tires & Wheels Want to know what size tire or wheel combo will work with your Ford Explorer or Ranger based vehicle? Interested in Beadlocks or Dubs? Learn all about them here.
Reply
Thread Tools
Old 01-08-2002, 02:26 PM   #1
KSMike
Kansas
It rains Fords here.
Vehicle Specs
Question Tires, how big will fit?
What are the largest tires that will fit on the 95-00 body style with no lift? I want to try to get 285/75R16's on.
__________________
Mike
00 Explorer Sport 4.0 SOHC
01 Explorer XLT 4.0 SOHC
96 Bronco XLT 5.8
KSMike is offline   Reply With Quote
Sponsored Links (Less Ads)
Old 01-08-2002, 02:32 PM   #2
ChuckyD
Moderator Emeritus
ECX Member
Oceanside, NY
ChuckyD's Avatar
03 4Runner SR5
Vehicle Specs
I doubt those will fit...
__________________
ChuckyD's Mugshot and Info.. NEW PICTURE!!!!!!!! 10/02
My Xplorer Page
"We know what we are, but know not what we may be." -- William Shakespeare
http://www.myspace.com/therealsicilian9
ChuckyD is offline   Reply With Quote
Old 01-08-2002, 02:32 PM   #3
Campo
Elitus Explorus
White City, KS
Campo's Avatar
99 XLT 4x4
Vehicle Specs
Hey KSMike,
what part of KS you from?
From everything I've read on this board the biggest you can go w/o a lift is 31x10.50 or 265/75 you might have to do a little trimming up front.
I'm gonna do a 2" shackle and TT lift and try to fit some 32x11.50's under it some time next week...
__________________
If it ain't broke, fix it till it is.
99 XLT 4x4 SOHC V6 2"TT/AAL 31" Kelly AT's aka Blue Mistress
96 Ranger ExCab 4x4 OHV V6 31" Goodyear RT/S's (not for long)
KC Area Explorers
Campo is offline   Reply With Quote
Old 01-08-2002, 03:58 PM   #4
ChuckyD
Moderator Emeritus
ECX Member
Oceanside, NY
ChuckyD's Avatar
03 4Runner SR5
Vehicle Specs
265/75 r15 that is....
a 265/75 r16 is just about the same size as a 32 x 11.5
__________________
My Xplorer Page
Old 01-08-2002, 04:18 PM   #5
Campo
Elitus Explorus
White City, KS
Campo's Avatar
99 XLT 4x4
Vehicle Specs
ummm. a 265/75r15 is a 31x10.50
here a link to tirerack specs on the Dunlop radial rover ( only one I could find with both spec's)
http://www.tirerack.com/tires/Spec.j...al+Rover+A%2FT
but the 265/75r15's outer diameter is 30.7" and the
31x10.5r15 is 30.4"
for most tire manufactures this is true...
{EDIT} I just noticed the 16
__________________
KC Area Explorers
Old 01-08-2002, 07:28 PM   #6
Fusion213
Jacksonville, NC
'98 XLT 5.0L
Vehicle Specs
On my 98 XLT V8, I put on 265/75R16 which are about 32"x10.5". These tires fit but when going over bumps, you can hear it rub on the top of the fenderwell and when turning at full lock, it rubs on the sway bars. Also, if you have factory running boards, it'll rub on the front part of them.
I recommend getting shackles and doing the TT if you get these size tires, or at least the TT because the back fits fine. Oh, and another thing, watch out for the tires rubbing on the e-brake cable.
__________________
98 5.0L SAS
Fusion213 is offline   Reply With Quote
Old 01-08-2002, 09:22 PM   #7
X24
RAMajama
Pleasant Valley, NY
X24's Avatar
05 RAM 2500 TURBO DIESEL
Vehicle Specs
what about a 265/70R16? will there be any rubbing with that? I dont want any rubbing and I dont want to lift or trim anything. How about a 275/60R16? Too wide? The overall diameter of the 275/60R16 is very close to the 235/75R15's that I have on now. It is approx .4% larger.
X24 is offline   Reply With Quote
Old 01-08-2002, 09:52 PM   #8
2001ExpSport
Chicago, Il
2001ExpSport's Avatar
2001 Sport
Vehicle Specs
The biggest you can fit without ANY rubbing is a 30". If you want a 31" you'll have a little rubbing on large bumps. Anything bigger forget it.
2001ExpSport is offline   Reply With Quote
Old 01-09-2002, 04:55 AM   #9
KSMike
Kansas
Vehicle Specs
Warform,
What is the actual tread width of your BFG's? I cant find specs for these.
__________________
Mike
96 Bronco XLT 5.8
Old 01-09-2002, 09:40 PM   #10
2001ExpSport
Chicago, Il
2001 Sport
Vehicle Specs
Quote:
Originally posted by KSMike
Warform,
265/75R16 BFG AT KO
Rim width 6.5-8.0
Overall diameter 31.75
Tread width 8.62
Section width 10.3
Old 01-09-2002, 10:41 PM   #11
Fusion213
Jacksonville, NC
'98 XLT 5.0L
Vehicle Specs
What's tread width? I know how wide the tire is... almost 10.5"
so it's almost equivalent to 32"x10.5"
__________________
98 5.0L SAS
Old 01-10-2002, 10:08 PM   #12
2001ExpSport
Chicago, Il
2001 Sport
Vehicle Specs
Warform, 10.3 is the section width. The actuall width of the tread is 8.6 inches.
Old 01-10-2002, 10:25 PM   #13
KEbert
Isla Vista, California
KEbert's Avatar
'91 XLT
Vehicle Specs
Ya, withiut any lift, you won't be able to fit anyhting bigger than a 30x9.5 on a 15 or a 255/70 on a 16. A 265/75 is a lttle bigger than a 31, depending on the make and model. Por ejemplo (for examlpe for you single language folks) my LTX AT's are a 30.9" tire. A MT/R 31 is 30.4". So it just depends.
KEbert is offline   Reply With Quote
Reply
Top of Page
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Search ExplorerForum
US Flag
We Support Our Troops!
Explore the site!
Contact Us
This web site is not affiliated with or endorsed by the Ford Motor Company.
Ford Explorer is a registered Trade Mark of the Ford Motor Company
The names of actual companies and products mentioned herein may be the trademarks of their respective owners.
All tips and information provided on this site by either "Serious Explorations®" or it's contributors are for use at your own risk and discretion.
Modifying the suspension on any vehicle will cause changes to it's handling characteristics.
Some modifications described within this website may void your factory warranty.
Copyright 2009 - 1996 Rick Horwitz Photography
