Ford Explorer Sport Trac Ford Ranger Mazda Navajo Mercury Mountaineer, Ford Aerostar Message Board®
Ford Explorer, Sport Trac, Mercury Mountaineer, Mazda Navajo, Ford Ranger, Ford Aerostar SUV Enthusiast Forums
Join the "Elite Explorers Today!"
Explorer4x4 Sportrucks EF Arcade Forums Elite Membership Product Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Repair - Tech - Modifications & Detailing Forums > Ford Explorer - Ranger Tires & Wheels
Notices
Ford Explorer - Ranger Tires & Wheels Want to know what size tire or wheel combo will work with your Ford Explorer or Ranger based vehicle? Interested in Beadlocks or Dubs? Learn all about them here.
Reply
Thread Tools
Old 01-10-2002, 11:17 PM   #1
prerunexp
El Segundo CA
93 ranger
Vehicle Specs
33's or 32's???
ok i have a 93 "X" sport and i will be doing a 4.5 inch custom suspension lift (no widening , no moving front wheels forward ) and front fiberglass fenders
i had a couple of people tell me not to go any bigger than 32 x 11.5 on an X but i really think it will look dumb with the 32's and i really want 33's i see all of you guys with 35's and up on your X's will th 33's rub on things i cannot trim out i.e. frame, sway bar, floor,
i dont want to settle for 32's but if thats all i can do i guess i will have to settle
prerunexp is offline   Reply With Quote
Sponsored Links (Less Ads)
Old 01-10-2002, 11:50 PM   #2
KEbert
Isla Vista, California
KEbert's Avatar
'91 XLT
Vehicle Specs
What is your custom lift consisting of? If you are getting fiberglass fenders, I would say at least 33's and possibly 35's. Fenderguy has a 4" lift with fibergalss fenders and 35's and as far as I know it is a good setup. If you are going for a prerunner setup, then 35's would be best.
KEbert is offline   Reply With Quote
Old 01-11-2002, 12:10 AM   #3
BislamJoe
Texarkana Texas
1993 Explorer 4x4 XLT
Vehicle Specs
Fenderguy has a Trailmaster 4" lift, and the 'glass fenders. Not even a trick cut-and-turn arrangement. He runs those 35's with NO RUB at all. I think he might have hammered back his firewall just a little, and maybe the front wall. But still - NO RUB. Go for 35's man. Is your truck a 4x4? What kind of lift, also? You going cut-and-turn?
__________________
David Nash
"Can ya hear me now?"
BislamJoe is offline   Reply With Quote
Old 01-11-2002, 12:32 AM   #4
prerunexp
El Segundo CA
93 ranger
Vehicle Specs
it is 2wd
the lift i am going for is from camburg and is a performance kit for a ranger
bent i beams
ebiach coil springs
heim joint radius arms
allignment cams
steel braded brake lines
custom coil buckets
2.5" sway-a-way race shocks
limit straps / bump stops
about 15 inches of travel
they say it is a 5 inch lift on a ranger but will settle down to about 4 - 4.5 inches on the X
no cut and turn i will not weld on the I beams
they say DO NOT BEND, HEAT, WELD right on the beams because theyre cast bending is ok under a certain process but no welding
yes i want it to be a pre-runner, i think i will go with the 33 x 12.50's those are definately big enough
the stock car with 28" tires already works good
it takes curbs, those things in the parking lots, hard off roading good stock the fiberglass is only made specificaly to handle 33"s
thanks
Old 01-11-2002, 12:41 AM   #5
BislamJoe
Texarkana Texas
Vehicle Specs
Right - On a 2wd, it's bent beams, same idea though. Sound like a really nice kit. You going to go to a coilover in the future? Your truck should be really slick either way.
What fiberglass are you getting? Seriously, on the tires, if you can fit 35's no rub, go 35's. You'll like the extra clearance, plus it'll look meaner
Whatever you choose, though, good luck!
__________________
David Nash
Old 01-11-2002, 08:30 PM   #6
prerunexp
El Segundo CA
93 ranger
Vehicle Specs
im getting perrys fab and fiber
oh and i wont go coilovrs it takes alot of work to install an engine cage and get the coilovers right plus i dont have the money also the race shocks and some good coils will already be more than i will need
Old 01-11-2002, 08:46 PM   #7
KEbert
KEbert's Avatar
'91 XLT
Vehicle Specs
I would still say get 35's over 33's. Prerunners need to be able to take a lot of abuse and 35's will help a lot more with going over terrain. Perry's fender's should serve you well and allow enough room for 35's.
Old 01-11-2002, 08:58 PM   #8
FROADER
Moderator
Huntington Beach, CA
FROADER's Avatar
'92 Eddie
Vehicle Specs
Alright, If you're getting the Camburg 5" lift with fiberglass you should get 35s. If you're worried about 32s looking funny, with all that room under the glass, 33s will look the same. You don't even need to get the glass with 33s. Mine didn't rub at all when I first lifted it with the 4" lift, 33s and stock fenders. Since you are getting extended radius arms, you will rub your tires on them near full lock both ways no matter what size tire you get. That is no big deal, they can rub those as much as they want with no harm. As BislamJoe said I did hammer the firlwall back as much as I could and since I don't have extended radius arms (yet) I don't rub anywhere, even at full bump,lock...anything. If photopoint was up I could show you the stages of my truck being lifted and since I'm not an elite yet I can't show you anything. Soon though, soon. Anyway, to answer your question, I would get 33s out of those 2, but you really should get 35s to make it a pre-runner. Good luck. I didn't look where you were from, are you going to Truck Haven?
Aslo Camburg doesn't use the pre '89 beams to bend? Wierd...oh well.
One last thing. If those glass fenders are made specifically to handle 33s, I'm going to be in serious trouble when I get 37s on mine!! :p
__________________
Colin Ignacio
FORUM RULES
My Explorer - My F-150 - My vBGarage - My Videos
FROADER is offline   Reply With Quote
Old 01-11-2002, 11:19 PM   #9
KEbert
KEbert's Avatar
'91 XLT
Vehicle Specs
How do you plan on fitting 37's Colin? Those are pretty dang big!
Old 01-12-2002, 05:23 AM   #10
FROADER
Moderator
FROADER's Avatar
'92 Eddie
Vehicle Specs
Can't be worried about cutting and banging.
As long as you can't see it from the outside, you might as well do what you can if it will help.
__________________
Colin Ignacio
FORUM RULES
Old 01-12-2002, 12:06 PM   #11
prerunexp
El Segundo CA
93 ranger
Vehicle Specs
i might go to truck haven i cant decide do you think it will be worth it it would be cool to see your trucks and all but i would prbally have to bring my moms stock 96 explorer , mine is messed up right now and my dad doesn't want to hear my exhaust the whole way, also my dad probally wont let me offroad it very much he hates the idea of offroading in a car if i do bring mine it is sort of embarrasing right now, not cause its stock , because i messed it up also it isnt very far from stock either
but if you guys think it would be cool to come up there for a day with a stock car and be pretty resticted than i might
also do you know when the next event is around here possibly in 3 months
Reply
Top of Page
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Search ExplorerForum
US Flag
We Support Our Troops!
Explore the site!
Contact Us
This web site is not affiliated with or endorsed by the Ford Motor Company.
Ford Explorer is a registered Trade Mark of the Ford Motor Company
The names of actual companies and products mentioned herein may be the trademarks of their respective owners.
All tips and information provided on this site by either "Serious Explorations®" or it's contributors are for use at your own risk and discretion.
Modifying the suspension on any vehicle will cause changes to it's handling characteristics.
Some modifications described within this website may void your factory warranty.
Copyright 2009 - 1996 Rick Horwitz Photography
