Ford Explorer Sport Trac Ford Ranger Mazda Navajo Mercury Mountaineer, Ford Aerostar Message Board®
Ford Explorer, Sport Trac, Mercury Mountaineer, Mazda Navajo, Ford Ranger, Ford Aerostar SUV Enthusiast Forums
Join the "Elite Explorers Today!"
Explorer4x4 Sportrucks EF Arcade Forums Elite Membership Product Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Repair - Tech - Modifications & Detailing Forums > Ford Explorer - Ranger Tires & Wheels
Notices
Ford Explorer - Ranger Tires & Wheels Want to know what size tire or wheel combo will work with your Ford Explorer or Ranger based vehicle? Interested in Beadlocks or Dubs? Learn all about them here.
Reply
Thread Tools
Old 01-27-2002, 12:48 PM   #1
Doug
Combat Sexy
Fort Meade, MD
Doug's Avatar
97 Sport
Vehicle Specs
will these tires fit?
Im lifting my 96 explorer sport 2" via the rear shackles and a TT i was wondering if any one knew if 32s would fit? and if they do is any trimming required?
__________________
97 Explorer
Life's hard. Wear a helmet.
Doug is offline   Reply With Quote
Sponsored Links (Less Ads)
Old 01-27-2002, 01:06 PM   #2
TarHeel085
Whats your bean situation
Raleigh/Greenville, NC
TarHeel085's Avatar
'99 Sport 4wd
Vehicle Specs
ok, first: you have sag in the back, measure it and then factor it in to the 2". second: what size tires are your stock ones and that size rim?
__________________
Curtis
My truck
'99 Saab 9-5 2.3t
TarHeel085 is offline   Reply With Quote
Old 01-27-2002, 01:15 PM   #3
Doug
Combat Sexy
Fort Meade, MD
Doug's Avatar
97 Sport
Vehicle Specs
ive got 235/75/r15s and the rear is about a half inch lower.
__________________
97 Explorer
Old 01-27-2002, 01:21 PM   #4
TarHeel085
TarHeel085's Avatar
'99 Sport 4wd
Vehicle Specs
235/75/15 is a 29" tire, so you would theoretically need 3"+ to runs 32's unless you are willing to trim your fenders. a lot of people in you position can only fit 31's. but i mean you could think about puttin in 4 door leafs that would only run you about $100 or less. they would remove the sag and you can geta real 2". hope this helps.
__________________
Curtis
My truck
'99 Saab 9-5 2.3t
Old 01-27-2002, 01:27 PM   #5
Doug
Combat Sexy
Fort Meade, MD
Doug's Avatar
97 Sport
Vehicle Specs
would leaf springs from a 1st gen 4dr fit? I saw some @ a junk yard but i dunno if i want to put used springs on my truck though i suppose theyll be better than monoleafs.
__________________
97 Explorer
Old 01-27-2002, 01:31 PM   #6
TarHeel085
TarHeel085's Avatar
'99 Sport 4wd
Vehicle Specs
um i dunno if they will fit, maybe someone else could shed light on this, but i think the general consensus was that you could do it (dont take my word for it!) but like you said, anything is better than the mono-leafs. i would suggest getting some leafs closer to your year, like '95-'97 range. caus ewhen i went to get mine, i could only get '98 and up. hope this helps!
__________________
Curtis
My truck
'99 Saab 9-5 2.3t
Old 01-27-2002, 01:37 PM   #7
Doug
Combat Sexy
Fort Meade, MD
Doug's Avatar
97 Sport
Vehicle Specs
it helps a bit ill have to start cruising the junkyards for springs. I wonder if springs from a ranger would fit...
__________________
97 Explorer
Old 01-28-2002, 12:12 PM   #8
shawnbru
Clawson, MI
'91 XL 4X4 4dr
Vehicle Specs
Ranger leaves are softer than Explorer leaves
This is the basis for the "Zimmerman Mod" where the eyelets on the main leaves of an Explorer are cut off at the ends and a Ranger main leaf is added to the pack so you can get more droop becuase the Ranger leaf is more flexible. IE: less lift and less stiffnes.
I asked the same question a couple of years ago. You might consider trying to find leaves off the rear of a V8. My grandpa has one, butt doesn't sag as much but the ride is stiff.
ShawnBru
__________________
91 XL 4dr, 4X4, Warrior Shackles, F-150 Coil Spacers, ES Bushings, Michelin LTX M/S, Borla Catback, Kenwood Stereo, Yakima Rack. 94 Ranger STX Supercab with BFG AT 31s, Mile Marker Hubs.
shawnbru is offline   Reply With Quote
Old 01-29-2002, 09:51 PM   #9
MoabRules
Albany NY
'98 Sport
Vehicle Specs
My vote depends on what your doing with your explorer...I have a 98 sport, and ran 265-75-16 (just shy of 32" tall) without any lift, and on stock alloys. Initially the only trimming I had to do was on the inside of the passenger side front fender well. After that I only noticed rubbing at full compression in the rear or full locked turns.
After installing the Warriors and TT, there is no rubbing, and the ride is alot better. It is true though about what to expect from the shackles in the rear. At best you may only get an 1" lift, seeing that the leafs are slightly sagging. And you only want to do the torsion twist to bring the front up level with the rear, and gain some wheel travel.
If your budget is just for tires now, and an economical lift, go with the 265/75/16...The cost difference is minimal, and the look is great. Depending on your gearing you probably won't notice a large drop in performance either.
MoabRules is offline   Reply With Quote
Old 02-20-2002, 10:33 PM   #10
taxx
Make em say Ugh
Indianapolis, IN
taxx's Avatar
73 EB
Vehicle Specs
The leaf springs I am running in the rear are off a 94.
__________________
73 EB
04 Evo
taxx is offline   Reply With Quote
Old 02-20-2002, 10:42 PM   #11
Jason_25
ECX Member
New Bern, NC
Jason_25's Avatar
'95 Explorer "Expedition"
Vehicle Specs
I am running the 265's in the rear and still rub under full compression and in the frong (with upgraded torsion bars), it barely rubs at all and the bars aren't even cranked at all yet!
OME lift here I come!
__________________
1995 Explorer "Expedition" 4.0 4x4
1987 Bronco II XLT 2.9 4x4
1988 Bronco II XLT 2.9 4x2
1997 Explorer XLT 5.0 4x2
My Truck
Jason_25 is offline   Reply With Quote
Old 02-21-2002, 09:31 AM   #12
becker69
Centennial, CO
01 Sport Trac
Vehicle Specs
So if my truck came on 255 70 16's (30.1") and I put on 32's @ 31.7", if I did the Torstion twist for 1.5" and the shackles for 1.75".... I should be ok at full compression with the factory bump stops? I haven't hit trails yet with the 32's so I am trying to guess if I will have probs bottoming out. Granted this only takes into acct. the diam of the new tires, and not the increased width taken up in the wheel well. I know the 265's are narrower, but how else can I guess if I will rub at full compression? Thanks.
__________________
Douglas.
TT/Warriors, 4.10's w/ LS, 32" Grabber AT2---stuff and other things---and--SLIDERS- -Armor to help the LONG wheelbase-
POW/MIA YOU ARE NOT FORGOTTEN
becker69 is offline   Reply With Quote
Old 02-21-2002, 12:20 PM   #13
Robert
Mesa, AZ
Robert's Avatar
'97 4x4 Sport
Vehicle Specs
If you are talking about putting on 265 75R16 tires, then they are still 10mm wider than your stock tires. The inside of them will rub the rounded corner of your swaybar at full lock and will still rub the top of your plastic fender liner under full compression. A body lift will eliminate the contact with the fender liner but options are limited with regards to the sway-bar contact.
The fender liner contact isn't a big deal though. I had my 265 75R16 tires on for a year before I did my body lift. The liner is soft, flexible plastic. It is the angular, rounded center section that it contacts and it only contacts under full compression. Mine is just a little less rounded and a little more flat where the tire hit it before my body lift. My driver's side contacted much more than my passenger side due to slightly different shapes in the fender liner. Neither side contacted enough to concern me.
The contact on my sway-bar isn't a big deal either. The middle part of my tire (about 1/2 way between the rim and the tread) contacts my sway-bar about where the bend is. My sway-bar has about a 2"x3" shiny spot on each side where my tire rubs it at full lock. My tires don't have any signs on them that they are contacting it (no wear marks). I just back off the steering a bit if I hit full lock if I am able. I'm not concerned about it either though since I have about 35K miles on these tires and you can't tell by looking at them that they hit my sway-bars.
__________________
4.56 Powertrax No-Slip, SOHC V6, SuperChip, K&N FIPK (#57-2513-1), Borla cat-back (#14748), 2" torsion lift, 3" PA body lift (#853), Monroe Reflex shocks, 285 75R16 BF Goodrich T/A ko, 2WD mod
Earnhardt Ford, Berge Ford, U-Haul
My Explorer
Robert is offline   Reply With Quote
Old 02-22-2002, 12:39 AM   #14
becker69
Centennial, CO
01 Sport Trac
Vehicle Specs
Robert thanks for the insight as to the rub spots; I just put 32's on this weekend, and I have the sway-bar rub ('shiny-spot') and I wasn't too concerned with it, but now I will definately not sweat it. I am real lucky that the Sport Trac's have huge wheel wells, but the tops of them aren't real deap at all (it's almost flat across the arc of the well).
__________________
Douglas.
Reply
Top of Page
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Search ExplorerForum
US Flag
We Support Our Troops!
Explore the site!
Contact Us
This web site is not affiliated with or endorsed by the Ford Motor Company.
Ford Explorer is a registered Trade Mark of the Ford Motor Company
The names of actual companies and products mentioned herein may be the trademarks of their respective owners.
All tips and information provided on this site by either "Serious Explorations®" or it's contributors are for use at your own risk and discretion.
Modifying the suspension on any vehicle will cause changes to it's handling characteristics.
Some modifications described within this website may void your factory warranty.
Copyright 2009 - 1996 Rick Horwitz Photography
