| Explorer4x4 | Sportrucks | EF Arcade | Forums | Elite Membership | Product Reviews | Explorer Photo Gallery |
| Notices |
| Ford Explorer - Ranger Tires & Wheels Want to know what size tire or wheel combo will work with your Ford Explorer or Ranger based vehicle? Interested in Beadlocks or Dubs? Learn all about them here. |
Thread Tools |
#1 |
FLExplorers Dallas, Texas. Stationed in Kaneohe, Hawaii
'04 Hemi
OK, I have had enough rubbing, I have finally decided to go ahead and trim to totally clear my tires. My problem as with most folks, is the front bumper/air dam and the bottom of the fender by the front door. It only rubs when turning fairly sharp. I went with M/T wheels which only come with 3-1/2" of back space so, I knew I was going to have to do this some day. Any suggestions or lessons learned?
Thanks.
__________________
'04 Dodge 1500 - got hemi? I respect everyone's opinion. But as an American Fighting Man, guarding your freedom to express your opinion, I reserve the right to let you know when YOU'RE WRONG. |
| Sponsored Links (Less Ads) |
#2 |
'04 Hemi
ttt
__________________
#3 |
Wannabe Elite Explorer
Chula vista ,CA
98 Sport 4x4
backspacing
hey addkev i have eagle 589's with 3-1/2 backspacing
and bfg 31x10.5 MT's i had to do some trimming on those same spots, all plastic. after that i had no problems with rubbing except at full lock with the suspension at full compression. you might have to do a tt and shackle combo.
#4 |
Poseur SUV
Sherwood Park, Alberta eh?
1992 XLT
I'm not sure about the newer ones but on my Explorer there is enough adjustment in the bumper to pull it far enough forward to clear very large tires. Loosen off the bolts that hold the bumper to the frame. Have a friend pull on the bumper until it is as far forward as it is going to go while you tighten the bolts again. You should be able to get at least one inch from that, maybe more.
#5 |
Poland
94 Limited
........but behind the tire you might want to consider cutting quite a bit off the plastic fender well.... that's where you probably get the most rub...... or the lower corner of the fender itself. What I've done I cut (using sawzall) straight from moulding down to about 1" at the bottom of the fender..... then I bent the lip back in and installed some tought plastic mud skirts to cover the butchered fender..... make sure you paint open metal first before it starts to corrode...... you can't even see the cut on mine.... like from the factory.
Good luck! |
| Bookmarks |
| Thread Tools | |
