Ford Explorer Sport Trac Ford Ranger Mazda Navajo Mercury Mountaineer, Ford Aerostar Message Board®
Ford Explorer, Sport Trac, Mercury Mountaineer, Mazda Navajo, Ford Ranger, Ford Aerostar SUV Enthusiast Forums
Join the "Elite Explorers Today!"
Explorer4x4 Sportrucks EF Arcade Forums Elite Membership Product Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Repair - Tech - Modifications & Detailing Forums > Ford Explorer - Ranger Tires & Wheels
Notices
Ford Explorer - Ranger Tires & Wheels Want to know what size tire or wheel combo will work with your Ford Explorer or Ranger based vehicle? Interested in Beadlocks or Dubs? Learn all about them here.
Reply
Thread Tools
Old 02-11-2002, 08:34 PM   #1
jasonb
Jackstand Wheeler
Suwanee, GA
jasonb's Avatar
'99 Sport 4x4
Vehicle Specs
stripped studs.. need to replace
ok.. i was doing a tire rotation this weekend and it was insane. the last time my wheels were removed was by the ford dealer when i got a free rotation (big mistake) with my oil change. they must have put the lug nuts back on with about 50000 ft/lbs of torque. it took me and a buddy with a short cheater bar to get most of them off. no way in hell i'd have gotten them off by myself on the side of the road. anyway, we ended up poping one of the studs and 2 were stripped horribly. all this on one wheel. i had an extra stud lying around for some reason so i fished it through the brake system and managed to pull it through and tighten it down. so i am on 3 lug nuts on the front passenger wheel now. i want to replace the other 2 studs that are stripped but i want to do it right. the one that i fished through isn't really ALL the way in, but it isn't moving and is not hitting anything! anyway, what is involved in properly replacing studs? thanks!
__________________
JasonB
--Thanks to all the great people in the military for keeping us safe.--
jasonb is offline   Reply With Quote
Sponsored Links (Less Ads)
Old 02-11-2002, 08:48 PM   #2
JDraper
Thirsty?
McVeytown, PA
JDraper's Avatar
'05 SCrew
Vehicle Specs
Easiest way to seat studs is to fish them through like you did, then put washers over them and draw it in with a lug nut. Make sure they are seated, because they WILL loosen up if you don't.
__________________
Moderator..Home Improvement/Explorer 911
You took my breath away....and now I want it back....
'66 Mustang Coupe, '04 Mustang Mach 1, '05 F-150 Lariat SCrew, '08 Focus
"Ex"plorer's: '92 Sport, '94 Sport, '01 XLS
Our Crappy Website
JDraper is offline   Reply With Quote
Old 02-11-2002, 09:27 PM   #3
jasonb
Jackstand Wheeler
Suwanee, GA
jasonb's Avatar
'99 Sport 4x4
Vehicle Specs
cool.. i thought there was a real way to do it. thanks for the response. i called the ford place to tell them thanks for their wonderful work (kinder than that) and she said it would take them about an hour per stud! WHAT! i did that one in like 5 minutes and it was the first one i'd done!
__________________
JasonB
Old 02-11-2002, 09:56 PM   #4
RFR2212
Typing Police
In the mug by Chitown
RFR2212's Avatar
95 JEEP Wrangler
Vehicle Specs
You could always take it to a place like Midas, or Merlins... they press them in for fairly cheap.
Pete
__________________
My Truck Registry
For those who can't spell, click HERE!!
RFR2212 is offline   Reply With Quote
Old 02-21-2002, 03:45 PM   #5
jasonb
Jackstand Wheeler
Suwanee, GA
jasonb's Avatar
'99 Sport 4x4
Vehicle Specs
JDraper..
ok, i'm going crazy. how do you pull them through? i was looking today and i can't remember how i did it that last time. i don't remember if i pulled the brake assembly off or not. i'm too young to be loosing memory! i feel really dumb now as it wasn't long ago when i did it the first time!
i'll try pete's way if i can't figure this out again.
__________________
JasonB
Old 02-21-2002, 04:25 PM   #6
JDraper
Thirsty?
McVeytown, PA
JDraper's Avatar
'05 SCrew
Vehicle Specs
Can't help ya on that one. I've never tried it on one of the newer X's
__________________
Our Crappy Website
Old 02-21-2002, 07:53 PM   #7
nicholtl
Los Angeles, CA
97 XLT
Vehicle Specs
If I were you I would have them replaced. You don't want to find a homemade solution for something as important as your wheels. Same thing happened to me and several times my tire almost flew off on the freeway. Thankgod I got to my shop safely, but I needed to replace the entire rim because it was so warped. GET IT DONE RIGHT.
__________________
97 Explorer 5.0 V8 * SUPERCHARGED * K&N FIPK * Gibson Exhaust * Bilstein Shocks * 3-inch suspension lift * 3-inch body lift * 33 Boggers with 4:10 gears * AR Rims * Conferr Rack * Alpine IVA-C800 * Alpine DVD Nav * 2 Eclipse Aluminum 15s * 4 Boston Pros 6.5 * Xtant 1001dx, 604x Amps * 10 PIAA lights * Clifford 7000 * Grille Guards * Limo Tint
nicholtl is offline   Reply With Quote
Old 02-22-2002, 09:00 AM   #8
CBoug76
Moderator
ECX Member
Dracut, MA
CBoug76's Avatar
1997 Sport
Vehicle Specs
Thats the way Most of us replace the Wheel Studs:
Feed them from the back thru the hole, and draw it on with the Lug Nut, using washers. It helps if you have an Impact gun, But you HAVE to Watch the back of the stud and stop the impct gun when you see the head is seated on the flange.
Wheel stud are easy and cheap to replace, If you break one, Replace it As Soon As Possible!!!!! The longer you wait the Weaker the Other wheel Studs will get.
CBoug76 is offline   Reply With Quote
Old 02-22-2002, 01:40 PM   #9
jasonb
Jackstand Wheeler
Suwanee, GA
jasonb's Avatar
'99 Sport 4x4
Vehicle Specs
cboug.. thats the thing. we did that to one but i can't remember how i did it. i can't find a way to feed it through without taking the brake assembly apart, and i don't remember doing that the first time! maybe my mind is going bad and im just forgetting stuff. do you have to take the brake assembly off or is there a space to feed it through without.
also.. the stripped studs are still in there.. should i just bang them out with a hammer or use a clamp or something? the other one broke off inside from torquing it and it feel out basically on its own. thanks for any help. i'm too yound to forget stuff so fast!
__________________
JasonB
Old 02-22-2002, 02:58 PM   #10
CBoug76
Moderator
ECX Member
Dracut, MA
CBoug76's Avatar
1997 Sport
Vehicle Specs
is it a front or rear wheel?
Old 02-22-2002, 03:12 PM   #11
jasonb
Jackstand Wheeler
Suwanee, GA
jasonb's Avatar
'99 Sport 4x4
Vehicle Specs
front passenger
__________________
JasonB
Old 02-22-2002, 03:37 PM   #12
CBoug76
Moderator
ECX Member
Dracut, MA
CBoug76's Avatar
1997 Sport
Vehicle Specs
Yes you have to take the Rotor off......
Old 02-22-2002, 05:25 PM   #13
jasonb
Jackstand Wheeler
Suwanee, GA
jasonb's Avatar
'99 Sport 4x4
Vehicle Specs
dang.. i really don't remember taking it off last time. i'm going crazy. thanks!
__________________
JasonB
Reply
Top of Page
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Search ExplorerForum
US Flag
We Support Our Troops!
Explore the site!
Contact Us
This web site is not affiliated with or endorsed by the Ford Motor Company.
Ford Explorer is a registered Trade Mark of the Ford Motor Company
The names of actual companies and products mentioned herein may be the trademarks of their respective owners.
All tips and information provided on this site by either "Serious Explorations®" or it's contributors are for use at your own risk and discretion.
Modifying the suspension on any vehicle will cause changes to it's handling characteristics.
Some modifications described within this website may void your factory warranty.
Copyright 2009 - 1996 Rick Horwitz Photography
