Ford Explorer Sport Trac Ford Ranger Mazda Navajo Mercury Mountaineer, Ford Aerostar Message Board®
Ford Explorer, Sport Trac, Mercury Mountaineer, Mazda Navajo, Ford Ranger, Ford Aerostar SUV Enthusiast Forums
Join the "Elite Explorers Today!"
Explorer4x4 Sportrucks EF Arcade Forums Elite Membership Product Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Repair - Tech - Modifications & Detailing Forums > General Explorations!!
Notices
General Explorations!! Closed to new posts. Place new posts in our new model year appropriate forum
Thread Tools
Old 08-08-2002, 05:29 PM   #1
Limited96
Grand Rapids, MI
96 Limited
Vehicle Specs
electronics problems..
ok.. lets see..
ive got grinding in my windows now thanks to an ******* mechanic who felt it was necessary to make sure my truck could take the abuse of off roading... jerk. anyway i think i might have sand or mud in there somewhere, and just want to know what i should do to remove it...
also.. my power locks went out.. they used to lock, but not unlock.. but now they dont do anything. i havent checked the fuses.. but im going to do that here in like 10 seconds.. but could it be the drivers side switch making them ALL mess up? if so.. yay.. but if not.. what else should i check???
my back passengers door wont lock either.. someone told me it was a bent rod.. i can see where the door had been hit before.. how hard would it be for me to fix... being im pretty much a novice... but have a few friends who work on cars rather avidly..
oh yeah.. should i change my front u bolts if i just had my back one's changed??? this guy told me i dont need it.. they had been changed recently. *(how recent i dont know..)* but i just am a bit worried. this guy really pulled one over on me.. im pretty damn upset.. and about 200 dollars later wiser to assholes who claim to be mechanics... so now on i do my work myself.. unless someone here is from the michigan area and is willing to help me out....
__________________
1996 v6 4x4 limited
ALWAYS UNDER CONSTRUCTION..
Limited96 is offline
Sponsored Links (Less Ads)
Old 08-08-2002, 08:02 PM   #2
Limited96
Grand Rapids, MI
96 Limited
Vehicle Specs
im bumping this up because i KNOW someone here can help...
__________________
1996 v6 4x4 limited
Old 08-08-2002, 08:02 PM   #3
dogfriend
Human-Animal Hybrid
Carmichael, CA
dogfriend's Avatar
'97 Sport 4x4
Vehicle Specs
door locks
I don't know about the other problems, but I'm fairly sure that your door lock problem is a failed solenoid. They start out by not locking all of the time when you push the button, and eventually they won't work at all. You can test this by looking for voltage at the connector which attaches to the solenoid and working the button.
Ive replaced two of them (pass door & rear hatch). It isn't too hard, but it is somewhat of a pain because you have to remove the door panel and it is difficult to get your hands in the part of the door where the solenoid is.
I would recommend getting a repair manual like Haynes or Chilton (I have both) so that you can look at the drawing that shows how everything is connected together.
Besides the normal hand tools, you will need a drill to drill out the rivet which holds it to the door. Ford includes a new rivet to install the new part, but I didn't have a rivet gun big enough to install it (it is a BIG pop rivet, usually installed with an air powered rivet gun). I found that I could substitute a #10 button head cap screw (a good hardware store will know what this is) for the rivet and still have clearance for the door to close (you can see the rivet head on the edge of the door near the bottom when the door is open)
good luck
dogfriend is online now
Top of Page
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Search ExplorerForum
US Flag
We Support Our Troops!
Explore the site!
Contact Us
This web site is not affiliated with or endorsed by the Ford Motor Company.
Ford Explorer is a registered Trade Mark of the Ford Motor Company
The names of actual companies and products mentioned herein may be the trademarks of their respective owners.
All tips and information provided on this site by either "Serious Explorations®" or it's contributors are for use at your own risk and discretion.
Modifying the suspension on any vehicle will cause changes to it's handling characteristics.
Some modifications described within this website may void your factory warranty.
Copyright 2009 - 1996 Rick Horwitz Photography
